P2445 Secondary air Injection....
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Woundedyak, Mar 11, 2019.
  1. Apr 9, 2019 at 4:07 PM
    DesertRatliff
    DesertRatliff Well-Known Member
    Mt. Hood, OR
    Mas Tacos Por Favor
    JustDSM likes this.
  2. Dec 20, 2019 at 12:03 PM
    Artsan713
    Artsan713 New Member
    I filed a complaint on the NHTSA website
  3. Dec 21, 2019 at 7:18 PM
    Nachomama2001
    Nachomama2001 Well-Known Member
    South Carolina
    2013 Tacoma TRD OR prerunner
    Bilstein 6112+5160s Air pump delete-Hewitt Technology Rear view mirror switch Hawk pads G2 BAK flip Roadmaster active suspension Seat lifters HVAC AJT knobs
    Hewitt Technologies makes a nice bypass kit. PnP.
    hewitt-tech, jkuniverse and Artsan713 like this.
  4. Jul 14, 2020 at 6:58 AM
    gnossdrawkcab
    gnossdrawkcab Member
    Do you remember which relay it was? I'm having the same P0418 and P2445 code in my '15 Tacoma and the pump does not turn on at all. I'm only seeing the 10A fuse labeled AIR PMP HTR, which I assume is for the air intake system.
  5. Jul 11, 2021 at 9:07 AM
    Jpiskura
    Jpiskura Well-Known Member
    Bumping this up.. I just got the P2445 on my 13’ went into limp mode. I pulled over checked it with the scan gauge and cleared it, drove home and turn my truck off and got the whistle sound.. I guess I’ll
    Wait for the code to pop back up but I can’t make a clear heads or tails of what the actual problem here is.. I have had the unifilter mod done for a long time now, but I still don’t know or understand that the issue is here with this system..
  6. Jul 11, 2021 at 10:25 AM
    steelcity2
    steelcity2 Well-Known Member
    Pittsburgh Pa
    2013 MGM DCSB TRD sport
    Bilsteins 5100's all 4 corners 1 inch rear spacer
    :popcorn:
  7. Jul 14, 2021 at 9:10 AM
    Jpiskura
    Did you ever figure this out? I am getting the exact same two codes pop up in my truck right now.
  8. Oct 12, 2022 at 12:01 PM
    hewitt-tech
    hewitt-tech Dont Replace SAIS, Bypass It!
    Lexington, SC
    Secondary Air Injection System Bypass Kit
    @Nachomama2001 We appreciate you recommending the HT SAIS Bypass Kit. Wanted to provide some additional resources for anyone comes across this thread in the future.
    What Does the Secondary Air Injection System Do?
    https://www.tacomaworld.com/threads/what-does-the-secondary-air-injection-system-do.780847/
    What Do My Secondary Air Injection Error Codes Mean?
    https://www.tacomaworld.com/threads/what-do-my-secondary-air-injection-error-codes-mean.780848/
    How to Fix Secondary Air Injection System?
    https://www.tacomaworld.com/threads/how-do-you-fix-the-secondary-air-injection-system.780849/
    JDAM likes this.
  9. Oct 13, 2022 at 8:59 AM
    JDAM
    JDAM Well-Known Member
    J
    Worshington
    12 DCSB TRD OR
    thanks! the kit has been on my list for a while. I had mine fixed once under warranty but those days are over. And it sucked to be stranded and needing a tow truck to the dealership.
    hewitt-tech[QUOTED] likes this.
  10. Mar 9, 2023 at 9:54 AM
    emlaabs
    emlaabs New Member
    2009 Tacoma Access cab 4x4 2.7L
    I had codes 2441 and 2445 pop up after doing some maintenance where I had to remove the air intake manifold... I did a cold start and could feel the SAI pump whirring; Moved on to look at the SAI valve and I noticed the vacuum line dangling. Looks like I forgot to plug it back into the MAF after my maintenance. I cleared the codes and now I'll drive around for a while and see if they ever come back. Will post and update.
    (also found out about the pump filter modification and the OEM plastic cover while reading about this system. Will be installing the clamp on filter and cover to the pump when the parts arrive)
    steelcity2 likes this.
  11. Mar 11, 2023 at 6:40 AM
    emlaabs
    emlaabs New Member
    Update: reconnecting the vacuum line seems to have fixed it! Happy to have it be a simple one! Hopefully someone else runs into this easy fix as well!
    b_r_o likes this.
  12. Oct 19, 2024 at 7:02 PM
    Sterling_vH111
    Sterling_vH111 Go do something real instead.
    Sterling
    socal
    2012 DCLB Prerunner V6
    Secretly Long Travel & Supercharged
    Bump on this thread,
    I’ve got codes:
    P2441; switching valve bank 1 stuck closed
    P2443; switching valve bank 2 stuck closed
    P2445; pump stuck off bank 1
    codes today along with limp mode while at work. I also noticed the SAS pump didn’t run on the cold start this morning.
    I’ve put power to the pump directly, as well as the diverter valve connectors that has two little valves that allow air into either bank of the cylinders.
    All three will function when connected directly to 12v.
    I also checked the fuse inside my main engine box, the one labeled for the SAI pump or whatever. It has continuity with a multimeter.
    from what I can see, there is no other fuse or relay on the system. I’m thinking I either have an issue with the ECU or SAIS Control unit sending the signal for everything to operate, or possibly a wiring issue in the harness side.
    Less likely on the harness, is all my codes are for mechanical malfunctions.
    Anyone know exactly where the relay for the system is? If there is one?
    I’m thinking about going ahead and replacing the diverter valves, as it seems to be the thing that fails most often along with the pump. Just don’t want to throw parts and money. These parts are all pretty expensive for what they are. lol.
    I have another pump that I think is good, I plan on testing with this upcoming week.
    Anyone know how often the control unit for the system might go bad?
    Seems unlikely and Rarely the issue, if ever, but it’s a possibility I am considering.
  13. Oct 19, 2024 at 9:39 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Pretty uncommon for the Air Injection Driver to go bad, have you verified Power on Connector A6 Pin 1 (White) and Connector A7 Pin 5 (Blue/White) and Ground on Pin 1 (White/Black) at the Air Injection Driver as well as Ground on Pin 4 (White/Black) at the Air Pump?
    Sterling_vH111 likes this.
  14. Oct 19, 2024 at 10:58 PM
    Sterling_vH111
    Sterling
    socal
    Haven’t gotten to testing the harness yet. I’ll try to do those Monday.
