PA Address Horn
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jackrules, Sep 11, 2010.
  1. Sep 11, 2010 at 8:29 PM
    jackrules
    jackrules [OP] Well-Known Member
    Jack
    San Diego
    10 PreRunner Double Cab SR5 TRD Sport LB
    Hi guys
    so I want a PA address horn on my tacoma just for the fun of it, so that on my ranch i can talk through it and stuff..
    Obviously most people do this through a CB Radio, but I wouldn't ever use the radio part of the CB radio..
    So i am wondering if any of you guys do it with another form of amplication than a CB or if I can use a cheap CB and not hook up an antenna or anything..
    I don't want one of those massive antennas on the back of my truck...
    BTW: this is the horn i'm looking at using http://www.radioshack.com/product/index.jsp?productId=2104031&tab=custRatings#showFullReviews
    Thanks for any help
  2. Sep 12, 2010 at 2:29 AM
    Gitmo
    Gitmo Well-Known Member
    Justin
    I just ordered the 100w speaker on radioshack for 35$ (actually picked it up in store) and have a cheap uniden cb radio on the way. I don't plan on having the antenna installed for a little while just because I only want the pa speaker as well. I bought the Uniden PRO520XL from Amazon for $48. So you can have your pa system for a total of $83 ;).
    Not exactly sure what else you could use instead of a cb radio.
  3. Sep 12, 2010 at 3:03 AM
    S.B.
    S.B. Well-Known Member
    Sean
    San Diego
    15 Taco
    LT, Glass, CBI Front bumper, NWTI Rear bumper, 35s
    Just make sure to keep the CB on the PA setting or it will fry the CB with no antenna.
  4. Sep 12, 2010 at 11:12 PM
    Gitmo
    Justin
    Ooo, that's good to know, thanks. Can I turn the radio on and switch it to pa without the antenna connected? Unless you can switch it to pa when its off heh..
  5. Sep 12, 2010 at 11:58 PM
    YumaTRD
    YumaTRD The Church Of @ODNAREM San Diego Chapter 1904
    David
    El Cajon, CA
    Solid Axle Yota
    Locked, Flat bed, 22R 5 speed, BFG KO2's
    A CB radio is not needed. Just an amplified speaker and a mic.
    A computer mic will connect to the speaker. Just get a speaker with a jack input.
