Paint code location
Discussion in '2nd Gen. Tacomas (2005-2015)' started by hardtaco, Dec 2, 2010.
  1. Dec 2, 2010 at 4:45 AM
    hardtaco
    hardtaco [OP] Well-Known Member
    Sarasota, FL
    08 PreRunner DCSB
    I want to pick up some duplicolor touch up paint for my 08 PreRunner D-cab, and would like to know where the paint code is located. She's a silver one.
  2. Dec 2, 2010 at 7:08 AM
    NicksRig
    NicksRig Well-Known Member
    Kenora, Ontario
    07 Tacoma DC TRD Sport
    Blacked out Skid plate, block heater, bug deflector, blacked out headlights, tinted fronts, OME 3" lift, Toytec AAL, Revenge-Fab Sliders, K&N Air Filter
    Its in the door on the sticker with all the other info.
  3. Dec 2, 2010 at 11:58 AM
    Dadic 78
    Dadic 78 Well-Known Member
    Fil
    Edmonton, AB CANADA
    08 Double cab TRD
    It's a black/white sticker either in your drivers' door jamb, or inside the actual door. The paint code is usually in the bottom left corner. Toyota codes are typically Number/Letter/Number (i.e. 3R3).
  4. Dec 2, 2010 at 2:57 PM
    05Moose
    05Moose Middle-Aged Member
    Jim
    In the snow (NorCal)
    '05 4x4 DC LB SR5 #8 (LSD, Tow Pkg)
    '05 4x4 DC LB SR5 (LSD & Tow Pkg), Timbrens, AAL, 5100s (1.75), Owned: 12/3/04 Mods: Fog, Map/Dome Light, Illuminated 4wd Switch, Washable Cabin Air Filter
    On the placard on the driver's door jamb. It's in the lower left corner of the sticker and will say "C/TR" and be followed by a 4-digit paint code with a slash then a 4-digit trim code (C=Color/TR=Trim).
