Paintin the wheels today
Discussion in 'Wheels & Tires' started by bt08231, Jul 20, 2009.
  1. Jul 20, 2009 at 4:37 PM
    bt08231
    bt08231 [OP] Well-Known Member
    Baltimore, MD
    09 Magnetic Grey SR5
    Stock
    So after months of research and searchin the web, I finally began the process of painting my 09 tacoma rims. I know this thread is useless without pictures but ill have them on here soon enough. I started today by removing a wheel and sanding the heck out of it. Took me about 2 hours to sand just one wheel and i think its sanded good enough, well i hope. I plan to use adhesion promoter and then painting them tomorrow, hopefully ill finish by tomorrow, so far they already look better without the gloss finish so they are going to look great satin black. Pics to come soon. Got some sweet new center caps to finish it off. This is my first mod and i know ive started something that will most likely never end:help:
  2. Jul 20, 2009 at 4:40 PM
    Death_Stalker
    Death_Stalker " The Master Ninja"
    Talha
    Cypress, TX
    2018 4Runner LE
    TRD Pro Wheels BFG AT Tires
    Hey why dont you do a step by step write up on your first MOD ? It will be helpful and awsome... just a sugestion thanks
  3. Jul 20, 2009 at 4:53 PM
    bt08231
    Baltimore, MD
    Stock
    Ya i can definetly do that, I just dont want it to be redundant as I have followed another write up that was already posted on here. But ya ill post my two cents worth
  4. Jul 20, 2009 at 4:53 PM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    Good luck with the paint shoot tmrw!! Can't wait to see the photos!!
  5. Jul 21, 2009 at 3:39 AM
    Capita
    Capita Well-Known Member
    Corner Brook, Newfoundland, Canada
    09 TRD Sport Double Cab
    It's a great idea. After taking off my black steel winter rims, my stock 09 rims don't look so well on my white truck. i'll be painting my rims too I think.
  6. Aug 18, 2009 at 5:26 PM
    bt08231
    Baltimore, MD
    Stock
    Finished product
  7. Aug 18, 2009 at 5:35 PM
    MUDFISH
    MUDFISH Well-Known Member
    Syracuse
    12 Double Cab SR5
    nice job... I like the TRD centercaps... nice touch...
  8. Aug 18, 2009 at 5:37 PM
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    BSP '10 4x4 TRD Off-Road DC
    See build thread in signature
    Looks good!
  9. Aug 18, 2009 at 5:38 PM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    I'm glad you came back with the finished photos...Looks great!!
  10. Aug 18, 2009 at 5:50 PM
    bt08231
    Baltimore, MD
    Stock
    So basically this is how I painted my rims. Total time it took was 11.5 hours, bear in mind, I was not working fast or cutting any corners. I wanted this paint to stick and to last so all in all i think of that 11.5 hours only about 1.5 to 2 hours was actually spent painting the wheels. The first step was to mark on the tire where the weights were and which ones went where and then remove them. The next step was to remove a wheel and to sand with what I believe was 400 grit sand paper. I sanded all the wheels for quite sometime until almost all the gloss was gone. I then wet sanded them all. After wet sanding I used a scotch bright green scrub pad, this worked very well getting around all the curves and in the crevices and edges and removed the gloss and dulled the aluminum quite well. This is where the majority of my time was spent as proper prep work is essential. I am sure what i did was overkill and some steps could have been bipassed but i figure I only wanted to do this one time if possible. After this the wheels were basically ready for paint. I washed all the wheels one at a time as thoroughly as possible. When I thought they were clean, I washed them again. I then wiped them down front and back with alcohol and clean rags and let dry. The next step in my process was to wedge the playing cards down in between the tire and rim to prevent any overspray. After this I applied the Bulldog adhesion premoter to the backs of the rims, I used 2 to 3 light coats to prevent running. Follow the directions on these things as different products require different times as well as weather conditions will have some effect. After this it was time for the paint. I did all the backs of the rims and then the fronts in order to avoid wedging the cards on each side more then once. Also, paint the backs first so once you do the front, if anything goes wrong it will mess up the side that no one sees. Several light coats is essential to the paint sticking. The paint I chose was rustoleum universal paint, it had some special trigger that worked well on only one can so beware, after all the prep work the second can started spitting drops of paint on some of the rims ruining some of the finish, but whatever. While the wheels dry, paint your wieghts. Reassemble. The TRD center caps had longer tabs that you can see in the pictures, I simply sanded them down on a bench mounted belt sander. I removed enough material until they were the length of the center cap tabs I was taking off. They fit very tight as if made for the rims and look great. They have been painted for a month and I have had no problems, they look incredible, they have held up very well so far. They completely change the look of the truck, you will love it and I highly recommend. Since then I have added a magnaflow 18" muffler as well to stock piping, also sounds awesome. Any questions just ask. Total cost: Center caps: $18 each, Paint: $6/ can(used two), Adhesion promoter: $15/ can (only needed 1) Sand paper $5, 11.5 hours of my time.
  11. Aug 18, 2009 at 5:54 PM
    Inked Tacoma
    Inked Tacoma GOT INK?????
    Jeremy
    Central Coast Cal
    2019 Tacoma TRD Sport DCLB
    2019 Tacoma TRD Sport DCLB De-Badged, Tent done Coming soon Bilstein set at 2 inch fronts rear 1.5 AAL 17 inch wheels and 265 BFG AT..... Speaker replacement sub and amp and of course window tent! Gone but not forgotten 08 Prerunner TRD Rugged Trail ICON Coil-overs/2.5 V.S. Series Remote Resi Shocks ICON Uni-Ball arms Camburg lift spindles ( Removed Swaybar) Dever 3 inch Lift Springs & Flip Kit, KMS XD Enduro 16x8 258/75 Mickey Thompson BAJA ATZ TRD Cat-Back Tint 30% side/Limo in back. The one that started it all 1999 Tacoma Preunner 6 inch Fabtech drop-bracket with custom kings all the way around AllPro 5 inch springs 35's custom paint and one bitch-en Alpine seystem for sound!!!
    Looks great and good use of playing cards lol !!!! :headbang:
  12. Aug 18, 2009 at 5:58 PM
    bt08231
    Baltimore, MD
    Stock
    ya the only thing that would make it look better would be better tires, but its kind of funny, in person, even the lame dunlop grandtreks look pretty badass on a black rim lol
  13. Aug 18, 2009 at 6:05 PM
    phynyx38
    phynyx38 Believe
    San Antonio, TX
    08 Tacoma PreRunner
    Great job, like the playing cards :D
  14. Aug 18, 2009 at 6:11 PM
    bt08231
    Baltimore, MD
    Stock
    I cant take credit for that ingenious idea, saw it in another write up. worked great
  15. Aug 18, 2009 at 6:18 PM
    06RedComa
    06RedComa Well-Known Member
    06 4x4 DC Sport
    Kings, Camburg 1.25" UCAs, Dakar leafs, TRD exhaust, Grillcraft grille, All-Pro APEX Bumper, Kenwood DNX6960, Avid Sliders, SnugTop Rebel, 285/75/16 Hankook Dynapro atm
    very nice, i was wondering what the part number on those center caps were, thanks
  16. Aug 18, 2009 at 6:18 PM
    ETAV8R
    ETAV8R Out DERP'n
    MGM 09 AC 4WD V6 TRD-OR w/ Tradesman Shell
    Just the basics
    Awesome job!
  17. Aug 18, 2009 at 6:18 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    good job on the wheels man.......they look great!
  18. Aug 18, 2009 at 8:42 PM
    beginah
    beginah Well-Known Member
    Looks good! Just a question on how durable it is. Does it scratch easily? Thanks!
  19. Aug 18, 2009 at 8:52 PM
    NumNutz
    NumNutz One of the original 7928
    Virginia Beach, VA
    07 Tacoma 4x4 - Kings, TC, Dakars, broken stuff
    Lots.
  20. Aug 18, 2009 at 8:54 PM
    REVHARD25
    REVHARD25 Well-Known Member
    so cal
    RUGGED TRAIL PACKAGE
    Tint on front windows. Dnx7120 kenwood. Rear tsb springs. Wet okoles seat covers UWS truck box Weathertech floor mats TSB floor mat hook grommets Satoshi grill AFE drop in filter Fumoto drain valve Bed mat
    You used a whole deck of cards to paint the rims..i must admit ive never seen that..why not just masking tape and newspaper? i guess index cards would work also..interesting:cool:
