Painting 2003 Tacoma
Discussion in '1st Gen. Tacomas (1995-2004)' started by TTaco03Prerunnin, May 22, 2016.
  1. May 22, 2016 at 10:48 AM
    TTaco03Prerunnin
    TTaco03Prerunnin [OP] New Member
    Dave
    2003 Black TRD Tacoma
    Stock Currently
    Good Afternoon,
    I have owned my Taco since high school, and am coming upon the 10 year reunion. I have used the truck from anything from offroad/trail use, motocross riding, salt water fishing(canoe on top of truck), and the paint is done. It is time to repaint, but the lowest, I have seen around is 3-4 thousand for the whole truck. Doing roof/hood(bad parts) roughly 800-1000. Does anyone know of anyone in Tampa Bay who is trust worthy/ reasonably priced? I have been considering having it painted to the Skyway blue the newers Tacomas come in. It is currently black.
  2. May 22, 2016 at 1:25 PM
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    I wouldn't do just the roof because the paint would never match to the 14 year old stuff.
    Cant recommend someone near you but private shops can be cheaper and found in local listings.
    Looks like you use the truck offroad a bit. Have you considered doing the whole truck in bedliner? Nowadays you can get it in any color not just black.
  3. May 22, 2016 at 1:49 PM
    TTaco03Prerunnin
    Dave
    Stock Currently
    Yeah that's the first question I asked was if the paint could be feathered to match. They said it could, cause other than roof/hood the paint is in pretty decent shape. I have considered the rhino lining the whole truck, I still haven't ruled it out. The truck sitting currently is around 245,000 miles. Do you know approximate cost to cover the whole truck with bed liner?
  4. Jun 25, 2016 at 12:17 AM
    norcal_cyclist
    norcal_cyclist Well-Known Member
    1998 Tacoma TRD
    Bilstein lift kit
    Black is black unless it's a metallic, paint will always match...
  5. Jun 25, 2016 at 12:34 AM
    eon_blue
    Azusa, CA
    You could always just Plasti Dip the whole truck in whatever color you want for less than $75 most likely. Just touch up with a few sprays here and there when needed, and it pulls right off when youre ready to go another route. Did all the chrome on my 04 with black plasti dip and it looks/holds up great.
    Theres a member on here that dipped his entire Tacoma, cant remember his username but the pics looked good
  6. Jun 25, 2016 at 1:23 AM
    westhumboldt
    westhumboldt Well-Known Member
    Arcata,Ca
    97 Tacoma sc 4x4
    Doug Thorley headers, urd 7th and Trd Supercharger, bilstein lift, trd locker just installed.
    diy monstaliner is looks good comes in all types of colors has best texture and is tough as nails if prep is done correctly. I got a quote for line x and it was like 2500-3000 and up and only comes in black. Monstaliner is the route I am going in like 5 yrs when my paint is even worse. There is a few members on here that have done it.
  7. Jun 25, 2016 at 3:00 AM
    DustStorm4x4
    DustStorm4x4 BBC 2020
    U S A
    04 Jeep LJ
    Dalandser likes this.
  8. Jun 25, 2016 at 3:53 AM
    Clearwater Bill
    Billy
    Largo Florida
    B&M Bodywerks in Clearwater should be on your shopping list.
    No good shop is going to be cheap to do a full repaint, as the prep is time consuming and the materials are very pricey. When you consider decent housepaint is over $40/gal now, imagine what 1st rate automotive paint runs!
    You can always get a budget job at a box store like Macco. Some aren't bad if they have managers/staff who care about prep work. But the details of removing things & overspray cleanup will be limited, and the paint quality is usually second tier. If it lasts a couple years you'll be lucky.
    It's hard to spend that much on a vehicle that age and mileage, especially since you use it as it was meant to be used. So, I second the Monstaliner consideration. www.monstaliner.com
    While the spray versions look great, the roller versions are quite acceptable too. And you could do that at home, one panel at a time. Just something to consider.
