Painting 4WD emblem on mud flaps; anybody do this?
Discussion in '1st Gen. Tacomas (1995-2004)' started by yota32, Jun 27, 2010.
  1. Jun 27, 2010 at 7:32 AM
    yota32
    yota32 [OP] Well-Known Member
    The 4WD emblem on my mud flaps is fadding; I'd like to repaint them but how? Anybody do this?
  2. Jun 27, 2010 at 7:47 AM
    yarik83
    yarik83 Well-Known Member
    Yuri
    Florida
    2016 TRD SR5 DoubleCab 4x4
    Lift kit, weight distribution hitch. Camper shell. Kayak Rack.
    2 ways.
    Painter's masking tape and then spray paint that works on rubber. Once paint is dry you will have to apply a few coats of clear coats.
    Or find a template with letters large enough to match letters on mud flaps. Ideally your template comes on a sheet so you peel away 4 then spray it white then clear coat then letter X then repeat and same thing with other 4.
    I would have to say that masking tape is a lot easier.
  3. Jun 27, 2010 at 8:04 AM
    Chad
    Chad Well-Known Member
    Chad
    Cary, NC
    09 V6 Access Cab TRD Sport
    Kenwood DMX-7704S Headunit -- Blackvue DR-470 Dashcam -- Pioneer TS-A1685R Speakers in Front -- Suntek CXP 40 Front Tint -- Access Vanish Roll-up Tonneau -- Wet Okole Seat Covers -- Fog Lights on Anytime -- PnL Powered Tailgate Lock -- DTRL "Stealth Mode" -- LED Footwell and Cup Holder Lights -- Map Lights ON with Dome Light -- Shorty Antenna -- AC Line Extension Mod -- Access Cab Rear Headrest Removal
    :facepalm:
    Just buy them off someone and sell your rears.
  4. Jun 27, 2010 at 9:21 AM
    twfsa
    twfsa Well-Known Member
    Tom
    Omaha Ne
    04 TRD 4X4
    881 Front coils, Bilstien 5100's all the way front set to "0" Icon Dynamic's mini leafs in rear, stock tires.
    Those flaps are expensive!
  5. Jun 27, 2010 at 4:05 PM
    yota32
    Thanks bro...I'll give it a shot.
  6. Jun 28, 2010 at 7:28 PM
    x2468
    x2468 Well-Known Member
    '02 TRD 4wd V6 Xcab Sr5
    i would take the mud flap off, get some tracing paper and trace the 4wd emblem. then get something spray paint proof and use your trace to cut out the 4wd emblem. then place your cut out over the mudflap and line up the cut out with the 4wd emblem and then spray paint white.
  7. Jun 28, 2010 at 7:29 PM
    tacomakid96
    tacomakid96 Lions Not Sheep
    Phil
    Out n' about
    1996 Tacoma / 2000 4.7 Tundra TRD
    There was a second gen on here that painted his blue cant remember his name maybe he'll post
  8. Jun 28, 2010 at 7:30 PM
    tim920
    tim920 Never seen Forest Gump
    Tim
    Boston, MA
    2005 4Runner Limited V6
    I forgot who it was but he colormatched his. SWB
  9. Jun 28, 2010 at 7:38 PM
    tacomakid96
    Phil
    Out n' about
    Well said Keith stone, LOL badass avatar:D
  10. Jun 28, 2010 at 7:40 PM
    jandrews
    '09 FourDubDee TRD OR
    Just cut that shit off...the factory flaps are way too long anyway.
  11. Jun 28, 2010 at 7:43 PM
    CUtigerfan
    CUtigerfan Well-Known Member
    South Carolina
    04 Base
    Daystar 1.5" coil spacers, bedlined bumpers, clear corners, aftermarket stereo, 20% tint, half debadged
    littledvl was the one who color matched his. you might want to PM him to see what he did and how its holding up
  12. Jun 28, 2010 at 7:54 PM
    TacoTron
    TacoTron Tacotronn
    Anthony
    Denver, CO
    07 Toyota Tacoma
  13. Jun 29, 2010 at 2:37 AM
    WhatThePho?
    WhatThePho? Greg Graffin 2016
    Andre
    HCMC, VN
    2006 STi
    The things required to pull bitches
    Or paint them Black and get a Decal Cut and stick it on.
  14. Jun 29, 2010 at 6:14 AM
    Gr8WhiteTaco
    Gr8WhiteTaco bishes love my haircut
    Aaron
    Knoxville, TN
    SOLD 02 Double Cab TRD 4x4
    2005 Mazda 3S hatchback
    Just lose 'em.
  15. Jun 29, 2010 at 6:21 AM
    sirsaechao
    sirsaechao Well-Known Member
    Tim
    CA
    2002 Toyota Tacoma SR5 TRD 3.4L 4X4 V6
    A lift, some wheels, some tires, some performance, some cosmetic and then audio.
    I heard people taking the 4X4 off w/ some solvent...maybe afterwards just add some decals?
  16. Jun 29, 2010 at 10:31 AM
    Sirlight
    Sirlight 1337 h4x0r
    Orange County, CA
    2004 PreRunner Xtra Cab
    STOCK
    If you want to repaint do the following.
    Find the correct size 4x4 logo and print/trace it on tracing paper. ( or remove the flap and trace as best you can. )
    Get some clear overhead projector type blank 8.5x11 sheets.
    Put your tracing paper on top of 1 of the clear projector sheets.
    Use a new Xacto blade to cut out the 4x4 logo following the trace and in turn cutting through the plastic. ( put something under so you dont cut your desktop or surface )
    You can also purchase a spray can of the 3M adhesive spray and spray it on the reverse of the clear plastic sheet. ( they have one that is designed to be able to stick to surfaces and be removed without hassle/residue).
    Stick it on to whatever surface you want the stencil on and blast it with spray paint.
    Might i suggest some paint that will adhere to rubber and flex a bit.
    Save the stencil and repaint as needed. clear coat seems like overkill on a flexible rubber mudflap.
  17. Jun 29, 2010 at 4:43 PM
    TacoMike
    TacoMike Well-Known Member
    Pennsylvania
    '19 SR AC Utility 4x4
    Go to the classifieds. :notsure:
