Painting chrome flares on a 96?
Discussion in '1st Gen. Tacomas (1995-2004)' started by austinramsay, Jun 20, 2012.
  1. Jun 20, 2012 at 12:25 AM
    austinramsay
    austinramsay [OP] Well-Known Member
    Austin
    Yuma, Arizona
    2001 Tacoma TRD Doublecab
    Ive been wanting to paint the chrome on the flares on my 96 but im not sure how to prep it correctly and if it would hold up with flat black spray paint? If anyone has any tips or if theyve done it give me some advice?
    Thanks :D
  2. Jun 20, 2012 at 8:40 AM
    Madjik_Man
    Colorado Front Range
    Sand it down real well. I'd start with 150 grit and work your way up to 1000 grit to get it nice and smooth. Then prime. Then paint. Then clear coat. Should hold up well.
  3. Jun 20, 2012 at 8:43 AM
    DoubleTake
    DoubleTake Well-Known Member
    What about Plastidip? I am in the same situation and was just going to use plastidip.
  4. Jun 20, 2012 at 8:48 AM
    Madjik_Man
    Lot of people swear by it. My only experience with it sucked. I peeled it off and will never use it again. Could have been user error for sure, but I am not down with the derp.
  5. Jun 20, 2012 at 8:50 AM
    DoubleTake
    I guess if I dont like it I will peel it off and paint. You think spray paint will hold up on the fender trim. I want flares, but painting the fender trim will be a cheap alternative.
  6. Jun 20, 2012 at 10:33 AM
    Madjik_Man
    I think if you prep it well and paint/clear it well, it should hold up.
    If you're down with the plastidip, do it first. And see if it holds up. Like you said, if it doesn't or you don't like the way it looks, just peel it off.
