painting rims
Discussion in 'Wheels & Tires' started by das56170, Dec 4, 2007.
  1. Dec 4, 2007 at 1:03 PM
    das56170
    das56170 [OP] Well-Known Member
    Orange County
    2007 Tacoma Access Cab 4X4 SR5 (sold), 2002 Tundra Access Cab 4x4 SR5, TRD Offoad
    Tacoma - Flowmaster cat-back exhaust, volant cold air intake, 3" lift with AAL, 285/75 r 16 pro comp xterrains, 1" differential drop, spare tire mod, hypertech in-line speedometer calibrator, debadged
    I saw a couple of threads where you guys posted pics of your trucks with painted rims. I have to say, they look pretty good. I've been wanting to get some black rims. But now I'm thinking about painting my stock rims. How do you think my truck would look if I painted these rims?
  2. Dec 4, 2007 at 1:04 PM
    Hotdog
    Hotdog My hair is all natural Moderator
    Hotdog
    2007 PreRunner SR5 Double Cab
    Wet Okole Underwear
    I love black rims. I say go for it.
  3. Dec 4, 2007 at 1:05 PM
    2003greenbean
    2003greenbean Carolina Alliance Costal Div
    socaste,sc
    03 trd
    cold air intake, step bars, custom grill, 3in lift,12 in audiobahn sub, 285/75/16 procomp tires, 20% tint,
    i think they would look good just use good spray paint
  4. Dec 4, 2007 at 1:11 PM
    Hotdog
    Hotdog
    Wet Okole Underwear
    And sand them down first.
  5. Dec 4, 2007 at 1:46 PM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    i just did a light wet sand before mine, 2 coats of black primer, and 3 coats of black paint. i only used one can of each and mine turned out great
  6. Dec 4, 2007 at 7:24 PM
    concrete jedi
    concrete jedi Well-Known Member
    Rochester N.Y
    06 Tacoma 4 door indigo blue
    Broken and scratched tailgate, cracked rear tail light lens, coffee stain in driver seat.
    Check out my gallery pix, I bought these rims on craigslist with the tires, got my aluminums in the shed waiting for the summer.
  7. Feb 18, 2008 at 11:01 PM
    Big Guns
    Big Guns Well-Known Member
    Temecula, CA
    07 PreRunner SR5 4.0L Indigo Blue
    Aero Turbine 2525 exhaust, Black Headlight Mod, DO Rock Sliders
    Sorry to dig up a "dead" thread, but how long did you wait for them to dry before reinstallin the wheels? I have read a couple how-to's on painting rims, and they go into some in depth stuff that i dont think i have the patience/time for. My truck is my DD and i need it for work, so i cant have my truck on jack stands for multiple days.
    I have been wanting black wheels for a long time, i just dont have the $$ lying around being a college student.
  8. Feb 19, 2008 at 3:35 AM
    TuRDTACO
    TuRDTACO Carolina Alliance: Midwest Firearms Division
    joliet, il
    HAD 07 TRD OFFROAD PRERUNNER
    small dent on the hood, new foglight bulb, roughed up bedliner, been smoked in, suspicious stains on the passenger seat, boogers on the drivers seat, dirty floor mats, girl doodles on the dirty windows, loose wiring
    i sprayed a coat on mine once every 10 minutes (several light coats), and i waited about 45 minutes to put them back on, then let the truck sit overnight to finish curing the paint. i half-assed mine about every way possible and they came out great...i was the first one to do this on here so let me know if you need any help
  9. Feb 19, 2008 at 7:38 AM
    wshsbears
    wshsbears Member
    central FL
    07 RR X-Runner
    C2C drop, BHLM, FL mod, Brembo drilled/slotted rotors, tailgate spoiler, CAI, TBS, rearview camera, bed net, Pioneer AVH-P5700 DVD, Cadence amp, xtreme creations with 10's and eclipse components, eclipse 4 chan, TTC dual traction bars, C2C eyelids, 8K HIDS, PA, Train horn, red gauge cluster LED's
    be sure to use wheel paint if your going to spray paint them. its a cheap and good alternative to powder coating. especially if u'll be doing a lot of offroading. u can touch it up whenever u like. another suggestion would be to prime it with black primer like said above, hit it with a good coat of the black paint ur using, wet sand that coat, apply another coat, wet sand that and put a good coat of clear coat on top. u can even apply 2 coats of clear. just be sure to wet sand inbetween. don't sand too rough. i would suggest something greater than 400 very wet. u just want to make a good smooth surface without the gloss for the next layer of paint.
  10. Feb 19, 2008 at 9:26 AM
    Big Guns
    Temecula, CA
    Yeah i figured i would let it sit overnight, but some of the walk throughs i was reading was recommending they sit for almost up to a week:eek: and i dont have the time for my truck to be out of commision that long. Just wanted to make sure it would be okay to dry on after just a night of drying. I would def avoind the dirt roads for a while.
    Yeah i was not going to spare expense on the paint seeing as i would rather this work and pay $40 than shell out $600 for some new wheels. And if it doesnt work, well then im getting new wheels anyways lol. But yeah i do off-road a lot and i thin it was TuRD that said no clear coat so i could shake and spray touch up.
    Update:
    Again i was doing some more reading and some of the reviews are saying to use a spray adhesive prior to priming/painting. Did any of you guys do this? Also, Some people i am reading about are using a can or paint PER wheel. DOes this sound like way over kill or am i just reading your guys' posts wrong?
  11. Feb 19, 2008 at 2:33 PM
    The_Hodge
    SC
    after that last coat was done drying, i put them back on. everything was fine until i got new tires put on friday and they nicked them up and added/removed weights....now i have to go back and touch them up. i think i'm gonna wait until after i put my black lugs on later this week before i fix it.
  12. Feb 20, 2008 at 9:17 AM
    wshsbears
    wshsbears Member
    central FL
    07 RR X-Runner
    they're definitely more fragile after spray paint vs powder coating them, but shouldn't be too bad.
    a can/wheel doesn't sound crazy, but maybe a little heavy.
    spray some adhesive promoter and do a lot of light coats of paint allowing them to dry fully after each coat. this will ensure a multiple layer paint job and will help with chipping esp. when offroading
  13. Feb 23, 2008 at 8:55 AM
    Willard
    Willard Member
    2008 Prerunner TRD
    4dr regular bed Silver with a Snugtop shell
    Have the rims powder coated
  14. Feb 23, 2008 at 2:19 PM
    Big Guns
    Temecula, CA
    I thought about powder coating, but i figured if im going to spend $200 on powdercoating, i could just save up and buy a set of wheels i like. I figured $30-$40 on some paint would hold me over till i could find a decent priced set of wheels. Ive been looking at the Raceline Renegade 6's or the Helo HE835. I know both will fit and are both around $130 a wheel.
  15. Feb 23, 2008 at 2:50 PM
    Willard
    Willard Member
    2008 Prerunner TRD
    Why dont they make more aftermarket rims with crimpable rim edge for weights. There's a reason all factory rims are this way.
  16. Feb 23, 2008 at 3:13 PM
    Big Guns
    Temecula, CA
    Umm... i dont know? Never really came to mind.
  17. Feb 23, 2008 at 5:43 PM
    TuRDTACO
    joliet, il
    i spent $15 painting my wheels and all it was for was to hold me over until i could buy the wheels i wanted
