Painting sliders
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Mitch, Dec 2, 2011.
When should I spray paint?
Poll closed Jan 1, 2012.
  1. Paint before you weld them on the truck?
    18 vote(s)
    94.7%
  2. Weld, then paint the sliders (mask the fuck out of the truck)
    1 vote(s)
    5.3%
  1. Dec 2, 2011 at 2:09 PM
    Mitch
    Mitch [OP] Somebody call for a Wambulance?
    Mitch
    Spokane, WA
    2007 Access Cab SR5 4x4
    Lights, Siren, Drugs, Needles, Electricity
    I'm getting a set of Elite sliders hopefully come monday. I plan on welding them on next week. But, what should I do?
    Spray paint before the weld? Or Weld, then spray paint?
  2. Dec 2, 2011 at 2:12 PM
    deadhed61
    deadhed61 :notsure:
    Santa Barbara, Ca
    The Black Pearl
    A little lift and a little armor
    Paint everything but where you're welding, then weld, then paint again! You're going to need to spray your bare frame after welding anyways to prevent rust.
  3. Dec 2, 2011 at 2:12 PM
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
    paint everything besides where you weld, after you weld on the truck paint the welds
  4. Dec 2, 2011 at 2:12 PM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    I'd paint before you install them, that way you know for sure you got every inch painted off.
  5. Dec 2, 2011 at 2:13 PM
    deadhed61
    deadhed61 :notsure:
    Santa Barbara, Ca
    The Black Pearl
    I would say you stole my idea, but looks like mine made it up first! :D
  6. Dec 2, 2011 at 2:14 PM
    JLee
    JLee The Man! Vendor
    Jerry
    Benicia, CA
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    X2 it's way easier to spray the sliders before you weld them on just stop about 1 or 2" from the ends of the legs so you have a clean surface to weld.
  7. Dec 2, 2011 at 2:29 PM
    Mitch
    Mitch
    Spokane, WA
    Reason I ask, is because my buddy who is going to do the welding, said if I painted before hand, then I would need to watch out for weld spatter ruining the paint
  8. Dec 2, 2011 at 2:34 PM
    deadhed61
    deadhed61 :notsure:
    Santa Barbara, Ca
    The Black Pearl
    True, but you're welding almost completely under the truck so all the said "spatter" should not be directed towards your sliders. They'll be just fine man. If not, the touch up will be way easier then having to completely paint then after it's welded on.
  9. Dec 2, 2011 at 3:20 PM
    Tepidy
    Tepidy Well-Known Member
    Ted
    upstate NY
    11 tacoma 4x4
    Toytec Coil Overs 3.00" DSM UCA's (Desert Products) TSB 4 Leaf w/AAL by Pro Comp Bilstein 5100 rear 1"ToyTec SwayBar Drops 1" diff drop Detroit Trutrac Rear Diff Nitro 4.56 Gears Doug Thornley Header MagnaFlow Cat Back Exhaust Custom Built Rear Plate Bumper Custom Built Front Plate Bumper 4X Innovations Rock Sliders ATO Front Skid BAMF Rear Diff Skid Uniden 510XL Pro CB Raceline Renegades BF Goodrich Mud Terrains KM2's 265x75x16 WeatherTechs Rear Diff breather Relocate Intake Resonator Removed Yellow Wire Mod
    If your mig welding them on just check your gas pressure and your feed and amperage and you should be fine with very little spatter. If you using a stick welder switch to DC current and it will help. I welded mine outside with 035 wire and my pressure was set at 12psi.
  10. Dec 3, 2011 at 4:49 AM
    T-Rex266
    T-Rex266 Elon Musk Moderator
    Paint with primer first
    Paint with black bed paint
    Weld
    Paint over welded spots
