Painting Window Control Panels and Automatic Shifting Cover
Discussion in '2nd Gen. Tacomas (2005-2015)' started by LBCJ44, Jun 18, 2012.
  1. Jun 18, 2012 at 10:16 PM
    LBCJ44
    LBCJ44 [OP] Well-Known Member
    Clay
    Greenville, SC
    2006 Toyota Tacoma SR5 4WD Double Cab
    6in. body lift, 3in. Pro Comp suspension lift 35 tires, Moto Metal Chrome Wheels, Pioneer Head Unit, Leather Seats, 10 Sub
    I want to paint my window control panel and shifter panel a black color. Has anyone painted theirs? And what did you use? Primer, special paint? Thanks for info and tips!:D
  2. Jun 18, 2012 at 11:39 PM
    hemitruk
    hemitruk Old man , young boi truk
    Kurt
    Hawaii
    2010 Dbl Cab Sport,
    A few
    Clean good , plastic adhesion promoter and trim paint I used duplicolor trim paint .Trim paint doesnt chip as easy Kind of like a dye.
  3. Jun 18, 2012 at 11:46 PM
    ROGU3 PR3DATOR
    ROGU3 PR3DATOR Space Shuttle Door Gunner
    Jake
    Eagle River, Alaska
    MGM 2011 TRD Off-Road
    Lifted, Supercharged, Armored, and lots more
    I used krylon fusion. Held up great so far. Been several months now since I did it.
  4. Jun 18, 2012 at 11:49 PM
    Khaos
    Khaos Big Member
    Bryant
    Jacksonville, Florida
    2011 DC TRD SPORT Prerunner
    3” spacer lift, 285/75/17 KO2, Spidertrax 1.25” spacers
    Anyone used the Valspar Plastic paint? Lowes doesn't sell Krylon Fusion for some reason unknown to me.
    I had plastiderped the shifter surround, but after a month or two it began rubbing off. Looked cool though.
  5. Jun 19, 2012 at 9:49 AM
    Ostrichsak
    Ostrichsak Don't taze me bro!
    Jer
    Northern Colorado, USA
    Supercharged '10 Tacoma 4x4 TRD
    TRD Supercharger + too much stuff to list. Click sig pic
    I plasti-dipped my radio face plate, HVAC controls & center console cover. Easy to do, cleaning was the only prep and the best part is if I decide I no longer like it I peal it off in minutes.
  6. Jun 19, 2012 at 10:06 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    I'd use Krylon Fusion. It sticks well to plastics and the only prep required is a good cleaning with Dawn, then a light wipe down with some rubbing alcohol (don't go nuts with this step). Bake the panels to smooth out the overspray, clear coat and you're all set. Krylon Fusion is the stuff used for the BHLM.
  7. Jun 21, 2012 at 6:54 AM
    tbone11212
    tbone11212 Well-Known Member
    fayetteville NC
    07 Tacoma TRD 4x4
    Black Spyder Headlights Black LED Spyder Tail Lights Spyder Smoke Fog Lights HID Headlights and Fog Lights Black LED IPCW Third Brake Light De-badged plasti-dip power window panels plasti-dip center console modded A/C controls JVC 7inch double Din touch screen HD radio Extreme bull-bar color-matched billet grille Billet lower grille color-matched rear bumper 5% tinted windows LED fog lights added HID bulbs added for fog lights Fog light Mod high beam/ low beam mod LED bedlights LED under hood lights aux fuse box Image Dynamics front and rear speakers Blue accent lighting
    plasidiped my step boards window controls cup holder as well as other parts all holding up well on a high traffic area just do a couple extra coats
  8. Jun 21, 2012 at 11:26 AM
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    X2 on this..
    Duplicolor OEM trim paint is the shiz. I painted my Interior (window/door panels and shifter panel) my lower valence, and my mesh for my Satoshi. Matches the black trim on any vehicle. Super easy, just clean and paint.
    I also painted my gauge rings, steering wheel emblem, tweeter rings, and the chrome pieces on the shifter all white with krylon fusion. Just cleaned and painted, except for the chrome pieces.. had to sand, prime, and then paint.
    Check my build thread. I wrote a write up as well.
