Panel lights
Discussion in '1st Gen. Tacomas (1995-2004)' started by rico334, Dec 5, 2010.
  1. Dec 5, 2010 at 5:19 PM
    rico334
    rico334 [OP] Active Member
    Rick
    Texas
    Tacoma TRD 2 WD
    I think it used to be lit up, just can't remember for sure. The hot/cold dial is not illuminated. Also my gear selector on the auto transmission console does not light up. Guess I will need to figure out how to get into those spots and replace bulbs.
  2. Dec 5, 2010 at 7:14 PM
    TacomaJPP
    TacomaJPP To secure peace, is to prepare for war
    East TN
    03 4WD TRD XTD Cab
    Snugtop Camper Brushguard
    The panel sucks. It is super fragile. Please note: the lights are installed from the backside. They utilize a turn and twist type of install. I accidentally broke my panel and now half my lights won't work...I guess I'll order the ridiculously overpriced part someday.
  3. Dec 5, 2010 at 7:38 PM
    tacotime95
    tacotime95 Member
    upstate, sc
    95 4x4 stock
    deck plate mod and 1/8 stainless skidplate
    yea mine worked then i installed a cd player and they dont work either and i didnt do anything but take the face plate and knobs off so i dont know how i would have broke them
  4. Dec 5, 2010 at 7:51 PM
    TacomaJPP
    East TN
    03 4WD TRD XTD Cab
    Hmmm. It's been awhile since I've installed a CD player, but, isn't there a wire that sends a signal to the CD player so that it knows when you have turned your light on and adjusts your interior lights to a dimmer setting? Maybe that's the culprit...just not sure how that could be screwed up as I imagine you used a wire harness kit.
  5. Dec 5, 2010 at 8:00 PM
    VTGrrr
    VTGrrr Well-Known Member
    Pt.
    Vermont
    01 2.7L i4 access cab | The Grrr.
    drop in k&n for now. Deckplated. Got rid of the intestinal airpipe and baffleys. Replaced with shiny big pipe of more straightness.
    Fuse?
