Park brake not releasing
Discussion in '2nd Gen. Tacomas (2005-2015)' started by prairiesailor, Sep 30, 2016.
  1. Sep 30, 2016 at 12:41 PM
    prairiesailor
    prairiesailor [OP] New Member
    2009 Tacoma Access 4X4 Standard
    After launching my sailboat (with the rear wheels submerged), truck was parked for a few hours. Then when retrieving the boat and setting the park brake on the launch ramp, the left park brake refused to release. After trying several things, a tap on inside of the rear wheel assembly did the trick and it did release. This locking has happened other times after launching the boat but never to this extent. The truck is a 6 speed standard 4X4, the park brake is used all the time and works flawlessly, EXCEPT in these circumstances. What should I look for? How do I resolve the problem.
  2. Sep 30, 2016 at 12:45 PM
    Texoma
    Texoma IG: Triple C Chop Shop
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    A bunch a cool stickers, a bada ass MetalMiller Tx Longhorns grill emblem painted Hemi Orange, JBA long tube headers with o2 sims, Diff breather mod, Red LED interior lights, Fancy head unit that plays ipod n movies, Also DIY install factory stuff like, factory cruise control, factory intermittent wipers, OME nitro struts with 886x springs and toy tec top plate, JBA high caster UCA's for better alignmnet and dey beefier too, Old Man Emu Dakar leaf springs in da rear with the gear, U bolt flipper, Ivan Stewart TRD rims with 33" K Bro 2's, some bad ass weather tech floor liners so I don't muck up my interior, an ATO shackle flipper for mo travel in da rear wit the gear, also super shiny Fox 2.0 shocks back there too, all sorts of steal armor for bouncing off of the rocks like demello sliders, AP front skid, trans skid, n transfer skid, demello gas tank skid, and a tough as nails ARB bumper with warn 8k winch, I'm sure there's more
    Pull the drums off and blast everything that has to do with the rear brakes with brake clean. Make sure you get every piece of dirt and brake dust out of there. You may need about 4 cans to do the job. Then when your done and everything is dry, lube all the contact points, the adjuster, and anything else metal on metal that will move and rub beside your shoe and drum surface of course. That should mitigate any future problems. Do this every time you rotate your tires and you should be good.
    Tex-Tac, 12TRDTacoma and Dynosports like this.
  3. Sep 30, 2016 at 3:11 PM
    08TacoTrD
    08TacoTrD Well-Known Member
    08 TRD Offroad
    I've had this happen launching my boat and I've found that riding the brakes a little before parking dries the drums and shoes enough to avoid sticking.
    Torspd and landphil like this.
  4. Sep 30, 2016 at 4:39 PM
    BlindingWhiteTac.
    BlindingWhiteTac. Well-Known Member
    Thomas
    Vancouver, WA
    07 LQ4 4L80E
    Just the essentials and no extra fluff.
    It happens when I wash my truck. I just don't set the parking brake.
  5. Oct 1, 2016 at 7:00 AM
    mshultz
    mshultz Well-Known Member
    Michael
    Wooster, Ohio
    Barcelona Red
    I have had that happen too after I hosed out the underbody. I had to put the truck in reverse the last time to get one of the rear brakes to unlock. Someone suggested the semi-metallic brake pads are rusting fast to the brake drums. I leave the parking brake off now after I have hosed out the underbody.
  6. Oct 1, 2016 at 7:43 AM
    hotrod53
    hotrod53 Well-Known Member
    Lynd
    Pittsburgh, PA
    ‘14 DCLB Sport, ‘18 TCH, ‘13 TCH
    Weathertech floor liners moded to hold OEM floor mats, weathertech vent visors, Toyota bed mat, LEER 100XL cap, hood gasket mod to stop whistling.
    That happened on my '06 at 125k, the E brake cables were toast.
  7. Oct 1, 2016 at 7:53 AM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    My first thought was that the internals just froze up based on the circumstances behind it because of the water or may had gotten grit and dirt inside of it. Like stated previously just get tour stuff lubed up and you should be good to go.
  8. Oct 1, 2016 at 8:05 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Disk conversion. :D
  9. Oct 1, 2016 at 9:51 AM
    JeffreyB
    JeffreyB Well-Known Member
    Jeff
    2015 Access Cab 2.7 5 Speed 4X4
    I believe you are experiencing flash rust which is making them stick together. Hard to avoid. Not sure how steep the launch is but you could probably get away with leaving it in park/reverse depending which transmission you have.
