Parking brake issue and now the brake pedal
Discussion in '2nd Gen. Tacomas (2005-2015)' started by bruinsrme, Jun 1, 2010.
  1. Jun 1, 2010 at 8:13 AM
    bruinsrme
    bruinsrme [OP] Well-Known Member
    Scott
    Worcester
    BRM 2010
    I engaged the parking brake the other day for the first time.
    When it was disengaged it was still somewhat engaged.
    After cycling the parking brake a number of times it fully disengaged.
    Now when I hard brake the pedal will return to the ready position about 50% of the way, paused and then pop to the ready position.
    The truck in in the shop as we speak getting the leaf TSB and trd exhaust as well as getting the brake looked at.
    Anyone have such an issue? Was there a fix.
    Truck has 2500 miles on it.
  2. Jun 1, 2010 at 10:02 AM
    bruinsrme
    Scott
    Worcester
    BRM 2010
    Turned out the hack the dealer had install the remote starter did a shitty job and was interferring with the break pedal.
    Dealer gave me crap about it may not be a warranty issue and i would need to leave tr car for the day. No loaner.
    Really, after some yelling they offered up a 24 hour rental at their expense.
  3. Jun 1, 2010 at 10:27 AM
    wlmuncy
    wlmuncy Well-Known Member
    William
    Knoxville, TN
    2007 Double Cab Manual 4*4
    Dealers are the worse scum on earth. They install and not cover their own work. Worthless 100%. They make lawyers and politicians look like saints.
  4. Jun 1, 2010 at 11:29 AM
    bruinsrme
    Scott
    Worcester
    BRM 2010
    Couldn't agree more.
    The dealer I went today screwed up and ordered the wrong parts for the tsb and trd exhaust. The installed the skid plate (no that much work) and synthetic oil change upgrade for free.
    Although they were kinda busy charging $525 for a front wheel bearing replacement, and another older person $75 for a cabin air filter and rear window wiper replacement.
  5. Jun 7, 2010 at 6:45 PM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    Parking brakes are cable operated. If not used frequently, they can hang up. It can stay partialy or fully engaged. Have it checked. If inclined, check it yourself. Pull the wheel and drums. Have someone else actuate while you watch.
    Good luck!
