Parking brake light, band aid fix?
Discussion in '1st Gen. Tacomas (1995-2004)' started by stonecutter908, Feb 18, 2009.
  1. Feb 18, 2009 at 5:26 AM
    stonecutter908
    stonecutter908 [OP] Member
    West Chester, PA
    95 Ext Cab v6
    I have the annoying parking brake light flicking on and off and I have determined that it is just the button not staying depressed. I tried to tape it down but that only holds for a day or so. I read old threads where owners have closed the circuit on the switch. But I'm not up to that task with my limited electrical skills. Are there any other simple solutions? Right now, I just fiddle with the handle until the ligjht goes back out.
    I should note that I have a manual tranny and use the pb daily. The tension seems fine and it is working without indication of a bigger problem.
    Also brake fluid is topped off. My problem is definitely at the button switch tied to the light.
  2. Feb 18, 2009 at 5:59 AM
    TicTacOma
    TicTacOma UnderWater Monopoly Champion
    Anastatia Beaverhausen
    Columbia,SC
    I'm Thinking...Oh Yeah...An FJ
    It's all in my head at the moment...
    Use the search feature. There are at least 2 threads on this complete with answers if not solutions.
    Good luck, And Welcome to TW.
  3. Feb 18, 2009 at 6:58 AM
    Whataboutbob
    Whataboutbob Allow myself to introduce myself...
    city of champions,Boston
    4x4 sr5 v6 6-spd.
    seatbelt ding mod,billet alum. shft knob,K&N air filter, alum. pedal covers
    My '98 had the same problem, I used a wire tie so it would always be off.
  4. Feb 18, 2009 at 7:04 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Do you have the pull-handle parking brake lever?
    If yes - pull the handle out and count the 'clicks' - It should be 12-18 clicks before it gets tight. If you have more than that, you need to adjust the cable tension. Cable can 'stretch' over time.
    Have you inspected the rear drum brakes?
    If your rear drum brakes are getting 'thin' - the parking brake can get loose.
    Each time you replace the shoes in your drum brakes, you should inspect & re-adjust the parking brake tension.
    Here's a write-up on how I adjusted the cable tension
    http://www.lieblweb.com/tacoma/Mechanical/EbrakeAdjustment/ebrakeadjustment.htm
  5. Feb 18, 2009 at 9:56 AM
    higherlux
    higherlux Well-Known Member
    Blake
    middle of S.C.
    1998 tacoma 2.7l 4wd/1986 POS
    Mall crawler status
    u could use electrical tape or just umplug the plug behind the swich
    like i did:D
