Parking Brake Replacement
Discussion in '1st Gen. Tacomas (1995-2004)' started by sikora8, Sep 2, 2015.
  1. Sep 2, 2015 at 12:39 PM
    sikora8
    sikora8 [OP] Active Member
    04' SR5
    Has anyone tackled a parking brake replacement on an 04' 4x4 Tacoma? I'm even having trouble finding the replacement parts. Any info is appreciated.
  2. Sep 2, 2015 at 1:01 PM
    Mush Mouse
    Mush Mouse Club Soda Not Seals
    mush
    where ever you want me to be
    2013 SR5
    its a Toyota truck and that's all the modifications needed
  3. Sep 2, 2015 at 11:56 PM
    Snowman
    Snowman I have a problem for your solutionÂ…
    Craig
    Somewhere in Canada
    Check out my build
    What are you trying to replace? The cable? The bell cranks? The drums? Shoes?
  4. Sep 3, 2015 at 6:33 AM
    sikora8
    04' SR5
    I basically need to replace all the external hardware...everything is rusted and each time I use the brake it sticks on. As a result, I have to lube the hell out of it and smack the shoes loose with a hammer. Plus the light stays on which drives me nuts.
    MR2 likes this.
  5. Sep 3, 2015 at 4:42 PM
    geodude
    geodude Well-Known Member
    http://www.dormanproducts.com/gsear...&parttype=Parking Brake Bell Crank&origin=YMM
    Replace both bell crank assemblies with this kit which is $30 on Amazon; it's not worth trying to reuse the old rusted hardware.
    Use a quality brake grease on all contact surfaces but don't over-do it since when the brakes heat up it can melt onto the shoes and affect braking.
    Also I'd suggest replacing both adjustment assemblies (not the exact part for your truck) as they tend to be seized as well if the parking brake hasn't been fully functional for a while.
    Lastly, wire-brush and grease all pivoting points along the parking brake line to make sure that wont be causing any hang up for your new hardware.
    MR2 likes this.
  6. Sep 4, 2015 at 12:45 PM
    sikora8
    04' SR5
    Thanks partner....
  7. Oct 15, 2016 at 11:01 AM
    cyclecuse
    cyclecuse New Member
    2001 TRD OffRoad 3.4L
    Can anyone confirm the part number for the front parking brake cable for a manual transmission, 4x4, Xtra cab? Via Lakeland, Sunnyside and some other parts sites, I get 46103D010.
    Confusion is mostly over whether or not this is correct for the manual trans. Thanks!
  8. Nov 3, 2016 at 5:25 PM
    Benwaah
    Benwaah Member
    Gunnison, Colorado
    97 2.7L 5-speed 4wd
    Hi, have you found the correct part # by chance? Or the correct length? I have to purchase one as well
  9. Nov 3, 2016 at 7:38 PM
    Kerrigan911
    Kerrigan911 Well-Known Member
    Dan
    05 TRD OR, AC, 4x4, V6
    I used the dorman kit above, its amazing how rusted the oem setup was
  10. Nov 3, 2016 at 8:22 PM
    CodeSeven
    CodeSeven LOC: 33.781461, -115.867251
    Serge.
    Coachella Valley
    '00 Taco 3.4 4x4 TRD ( <3), '06 Taco Prerunner 4.0 (totaled)
    3 inch lift. bluetooth stereo. blue transparent skulls shift knobs
    do you have drums in the rear or disk?
