Parking Break bypass help
Discussion in 'Audio & Video' started by bowhuntingaddict, Jun 15, 2011.
  1. Jun 15, 2011 at 2:48 PM
    bowhuntingaddict
    bowhuntingaddict [OP] Well-Known Member
    I just installed a auto relay, and did everything the videos on youtube said except i soldered the wires to the relay. I can't figure out what I did wrong, the sound plays, but i can"t play a video???
  2. Jun 15, 2011 at 8:40 PM
    sun
    sun Well-Known Member
    Memphis
    2011 PreRunner
    Pioneer avic-z130bt with axxess aswc and rear cam mod, audiovox 10 flip down monitor, Pyle pl76d headrest monitors, kicker cvr tens wired down to one ohm with hifonics Brutus 1200.1, Clazzio seat covers, 20% tint on front windows, polished factory exhaust, peragon retractable bed cover, pop n lock tailgate handle with dei actuators for automatic lock, viper 5901 alarm remote start with viper smart start, hid bixenon 4500k headlights with 4500k fog lights, led map license plate lights and dome lights
    need more info what kind of radio model etc etc and how exactly did you wire up the relay
  3. Jun 15, 2011 at 10:11 PM
    bowhuntingaddict
    Its a pioneer AVH3300BT, I soldered the ground wires to 85 and 87 on the relay, the remote wire to 86 and the parking brake wire to 30. If you need anymore information or want me to post a picture just let me know.
  4. Jun 16, 2011 at 6:15 AM
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    That should work. Only thing different on mine is that 86 and 87 went to ground, 85 remote and 30 parking brake wire. That difference shouldn't matter though. Double/triple check your wires. Look here for relay details http://www.the12volt.com/relays/relays.asp
    Also, might check the relay health by energizing the coil (85 - 86) and listen for the "clunk" of the switch. Can also check continuity of the 30 -87 path with a multimeter, with the 85-86 energized.
  5. Jun 20, 2011 at 6:29 PM
    sun
    Memphis
    2011 PreRunner
    Yup that should work 85 and 87 to ground 86 remote wire and 30 to light green
  6. Jun 20, 2011 at 8:59 PM
    bowhuntingaddict
    Thanks for help, i got it working, awesome new head unit
  7. Jun 21, 2011 at 9:41 PM
    Durdum
    Durdum Member
    Travis
    Dfw
    09 double cab
    Audio!
    Avic411.com has a lot of neat stuff
