parking break light
Discussion in '1st Gen. Tacomas (1995-2004)' started by tacomatrd98, Oct 29, 2009.
  1. Oct 29, 2009 at 7:54 PM
    tacomatrd98
    tacomatrd98 [OP] New Member
    encinitas, CA
    TRD 4x4
    I have a 1998 taco 3.4 liter and my parking break light goes on and off while im driving. It just started doing this recently. Is there anyway i can disconnect the light? anything helps. thank you!
  2. Oct 29, 2009 at 8:09 PM
    humanoid
    humanoid bite me
    Sunny SoCal
    I had a '99 Xtra Cab PreRunner SR5 V6
    You don't want to do that, it's there for a reason. Check your brake fluid level. Low fluid level means your brakes may need to be serviced as well, so check out your fluid first and then your brake pads and shoes.
  3. Oct 29, 2009 at 10:13 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    Well providing that yours is like mine (emergency brake handle pulls out) It sounds like your detent button is sticking and/or shorting out . When you release the brake handle it slides down back under the dash & depresses a small push button switch that "shuts off " the brake release light, see pics my finger is right on it, I'd spray a little WD40 or some other shit & push on the button a few times to loosen things up, try this & hopefully it'll go away...... good luck & hope this helps ....:cool:
  4. Oct 30, 2009 at 5:48 AM
    wolfgang123
    wolfgang123 Well-Known Member
    Skyler
    Charlotte, NC
    1997 TACOMA - 4x4
    mine did the same thing. all i did was top of the brake fuild. you have to fill it up a little past the fuel line.
  5. Oct 30, 2009 at 6:14 AM
    98tacoma27
    Ben
    Not Beech Creek
    Mine used to do this and it was the lever on the rear drum that had "frozen' to the clevis.
  6. Oct 30, 2009 at 7:16 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Check Ebrake pull (pull ebrake handle)- how many clicks do you get when pulling the handle?
  7. Nov 3, 2009 at 5:41 PM
    tacomatrd98
    encinitas, CA
    TRD 4x4
    thanks for all the posts! i added brake fluid and it fixed the problem.
  8. Feb 17, 2010 at 4:16 AM
    cswires
    cswires New Member
    TN
    05 Tacoma Access 4x4
    My 05 is doing the same thing. What am I looking for on the shoes and pads? Serviced 25k ago and had 75% pad left. I have 105K on it now.
  9. Feb 17, 2010 at 8:18 AM
    2003 TRD Man
    2003 TRD Man Well-Known Member
    Edison N.J.
    03 TRD automatic
    Do you have to use emergency brake all the time?
    I never do--
  10. Feb 28, 2010 at 11:34 AM
    MowTaco
    MowTaco Well-Known Member
    Kansas
    16 Chevrolet Silverado
    Mine sticks a little when it's cold. The brake isn't engaged, just far out enough to turn the light on. Just try messing around with the button, I've had to do some tinkering with my clutch interlock too.
