Parking Lights Closest to the Grill
Discussion in 'Lighting' started by bigbeariuka, Jan 24, 2011.
  1. Jan 24, 2011 at 6:58 AM
    bigbeariuka
    bigbeariuka [OP] Well-Known Member
    How do you make them come on??
  2. Jan 24, 2011 at 7:00 AM
    cc350
    cc350 Retired Member
    Those are your turn signals or if equipped DRL.
  3. Jan 24, 2011 at 8:28 AM
    fvtalon
    fvtalon Well-Known Member
    Southern BC
    07 DC TRD/Yamaha
    285/65/18 BFG ATs on MKWs Leer Cap
    On my truck, with DRLs, if I have the truck on but the lights off those inside big amber ones come on, they stay on with the lights at the first setting (park lights) then they go off when I turn on the actual headlights.
    Then at any given time they will blink as one of the turn signals.
  4. Jan 24, 2011 at 8:34 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    You flip that level on the right side of the steering wheel. If you push it up, the right light will flash intermittently, and the oppositte will happen if you push it down. There's a button near the stereo controls with a red triangle on it, if you push that button, both will flash intermittently!! :eek:
    Sorry, I couldn't resist...
  5. Jan 24, 2011 at 10:37 AM
    bigbeariuka
    I know it is the flasher but quite often I see different taco's with these lights on during the day. Must be a Mod out there somewhere??
  6. Jan 24, 2011 at 11:07 AM
    Bama_TACO
    Bama_TACO ROLL TIDE!!!!!!!
    Winfield, AL
    2006 PreRunner Double Cab TRD SPORT
    If you are seeing them in the day, it's the daytime running lights. Search and you will find a thread on installing them if you don't have them. You can also rig the inside lights to come on with the park lamps. I did it to mine and it took all of about 10 minutes, 2 pieces of wire and 2 splices. I will look and see if I can find the post.
    Here is the post about installing the oem dtrl. http://www.tacomaworld.com/forum/technical-chat/1475-05-drl-daytime-running-lights-install-oem.html
    And this is the mod that I did to make mine come on with the park lamps. http://www.toyotanation.com/forum/t164710.html I didn't use the connector like he has here. I just stuck the wire in the hole and bent it over the prong and put it back together. Has worked flawlessly for 4 months now.
  7. Jan 26, 2011 at 4:58 PM
    jason smith
    jason smith loblk08taco
    Tennessee
    08 sr5 2wd 5sp 2.7
    flowmaster 40 series orig flo, cold air intake,painted headlights.Trex eyelids, xrunner wheels, street tacos 3"drop rear, djm 3" drop front
    those trucks are 2010 and up model
