part id issue please help i think it is a brake leak!!!!
Discussion in '1st Gen. Tacomas (1995-2004)' started by sir1123, Jun 8, 2011.
  1. Jun 8, 2011 at 6:38 PM
    sir1123
    sir1123 [OP] Tacomas FTMFW!!!!
    Charleston
    99 SR5 Prerunner, Black,3.4L
    3"Ebaich with 5100 Bilstiens, K&N cai, 5% 3M Tint, Magnaflow 18", Hella 500s with 35w 3000k hid retro, 33x9.5x15 BFG A/T
    if you are looking at your rear axel from the back of truck. look to the left there is some sort of brake line that starts near the bed of truck then goes down to the right side connecting to the axel with some sort of connector. at the top of this line there is a type of rubber boot and this has some kind of oil on it ... what is this ? sorry if discription is horrible
  2. Jun 8, 2011 at 6:38 PM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    Take a picture of it
  3. Jun 8, 2011 at 7:11 PM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    ...too much shit to list.
    Pictured below is the stock rubber brakeline on a first gen. Is this what you're talking about? It connects the hard line on the frame to the hard line on the axle. If it's oily, then most likely it's brake fluid.
    You can get a steel braided replacement brake line from Wheelers for $35.
  4. Jun 8, 2011 at 8:20 PM
    sir1123
    Charleston
    no i am talking about that metal line that goes over the pumpkin and connects to the right side of the axle
  5. Jun 8, 2011 at 8:21 PM
    sir1123
    Charleston
    it is small and skinny and connects on some kind of shaft . i need to know what that box is that it is coming out of.
  6. Jun 8, 2011 at 8:45 PM
    sir1123
    Charleston
    ok i have found the part. i belive it is the rear brake valve assmbly. what exactly does this do. i still have good feel in the brakes but the is some fluid around this assembly is this somthing to seriously worry about.?
  7. Jun 8, 2011 at 9:07 PM
    Texoma
    Texoma IG: Triple C Chop Shop
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    A bunch a cool stickers, a bada ass MetalMiller Tx Longhorns grill emblem painted Hemi Orange, JBA long tube headers with o2 sims, Diff breather mod, Red LED interior lights, Fancy head unit that plays ipod n movies, Also DIY install factory stuff like, factory cruise control, factory intermittent wipers, OME nitro struts with 886x springs and toy tec top plate, JBA high caster UCA's for better alignmnet and dey beefier too, Old Man Emu Dakar leaf springs in da rear with the gear, U bolt flipper, Ivan Stewart TRD rims with 33" K Bro 2's, some bad ass weather tech floor liners so I don't muck up my interior, an ATO shackle flipper for mo travel in da rear wit the gear, also super shiny Fox 2.0 shocks back there too, all sorts of steal armor for bouncing off of the rocks like demello sliders, AP front skid, trans skid, n transfer skid, demello gas tank skid, and a tough as nails ARB bumper with warn 8k winch, I'm sure there's more
    Rear load proportioning valve you mean? It keeps the rear wheels from locking up.
  8. Jun 8, 2011 at 9:09 PM
    mjohn617
    mjohn617 Well-Known Member
    Petaluma, CA
    05 DC TRD sprt silver
    Haha...not doing it...can't make me!
    Dude pictures would be sooo nice right now!
  9. Jun 8, 2011 at 10:24 PM
    MowTaco
    MowTaco Well-Known Member
    Kansas
    16 Chevrolet Silverado
    If it's that thing to the right of the pumpkin that looks like a brass washer with a post coming out of it it's the Brake Proportioning Valve. It regulates rear brake pressure depending on the load placed in the bed.
  10. Jun 8, 2011 at 10:27 PM
    NelsonTacoma
    NelsonTacoma This is my derpawayinator!!!!!
    Tucson, AZ
    06 PreRunner TRD Sport 03 4Runner Limited 4wd
    Bilstein 5100's , 6000k HID Hi/Low Kit, Magnaflow Muffler, 1.5 inch AP Wheel Spacers, Mudflap Delete
    This^
  11. Jun 9, 2011 at 8:31 PM
    sir1123
    Charleston
    it is the proportioning assembly. is this a major problem?
  12. Jun 9, 2011 at 8:34 PM
    Texoma
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    Find out where it's leaking from. Get some brake clean spray and a rag and clean all of the leaks up. Then go pump the brakes and see where it comes from. Might just be something loose and all ya gotta do is tighten it. And yes, if you have a leak in your brakes, it's always serious. That's how you stop when you're going 80.
  13. Jun 9, 2011 at 8:52 PM
    jblair
    jblair Well-Known Member
    Colorado
    99 taco 2.7L I4
    lift, big boy tires, deck plate, no more sway bar, painted stuff
    how is that left?
  14. Jun 9, 2011 at 8:54 PM
    mjohn617
    Petaluma, CA
    It is serious, get it addresed...you what the purpose of that system is right...to stop...you can finish that thought. Keep an eye on your brake fluid reservoir if it gets too low your going to have some other issues...actually if you have a leak you might need to bleed your system anyways. Have you done a hydraulic purge/bleed before?
  15. Jun 9, 2011 at 9:01 PM
    sir1123
    Charleston
    if that is a siple bleeding the brakes then yes. and my fluid level is fine and so is the feel of my brakes. is there a certian spot where it would be leaking cause i cant nail where in the assembly it is exactly or could it just be a loose fitting?
  16. Jun 9, 2011 at 9:03 PM
    sir1123
    Charleston
    roger this i will do first thing tm mornig
  17. Jun 10, 2011 at 12:25 PM
    MowTaco
    Kansas
    I think he said it's leaking over towards the left... The assembly on the right doesn't have any fluid in it I don't think... It's just a mechanical arm that serves as the "sensor". The actual valve is over on the left.
  18. Jun 10, 2011 at 3:42 PM
    jblair
    Colorado
    99 taco 2.7L I4
    ah ok that makes more sense.
  19. Jun 12, 2011 at 8:13 PM
    sir1123
    Charleston
    yes it is the thing with the rubber around it
  20. Jun 13, 2011 at 3:22 PM
    sir1123
    Charleston
    why would that rubber boot have brake fluid in it?
