Part numbers anyone?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by REDdawn6, Mar 14, 2018.
  1. Mar 14, 2018 at 10:41 AM
    REDdawn6
    REDdawn6 [OP] Well-Known Member
    Redlands CA.
    2011 Tacoma TRD 4x4
    Hey guys. My part searching skills suck ass! Im wanting to do a rear diff, front diff and transfer case drain and refill. 2011 TRD OR 4x4 Im worried about the bolts being fucked up when I remove them and maybe needing new ones.
    Is the front and rear diff the same fill and drain bolts? Part numbersi f you know them ?
    Is it smart to have replacement fill and drain bolts for transfer case on hand? Part numbers?
    I was going to ask gunny1005 but he has been MIA on his thread :(
    Thanks for looking and if someone has the numbers , tyvm!!
  2. Mar 14, 2018 at 10:42 AM
    REDdawn6
    Redlands CA.
    2011 Tacoma TRD 4x4
  3. Mar 14, 2018 at 12:54 PM
    PackCon
    PackCon Well-Known Member
    Connor
    2017 Subaru Forester Limited
  4. Mar 14, 2018 at 12:56 PM
    REDdawn6
    Redlands CA.
    2011 Tacoma TRD 4x4
    Thanks man
  5. Mar 14, 2018 at 1:41 PM
    dalero
    dalero Active Member
    dale
    RI
    2007 SR5 dcsb 6sp man 4x4 radiant red 70k
    alpine head ultra performance wheels new factory frame and leafs
    On my 07 the rear and transfer case have the same plugs. The front is different. (Allen heads) I'm sure yours are the same. 90341-24014 for the front 90341-18006 for the rear and transfer case. 90430-A0003 for the washers if you choose to change them. The synth Mobil oil is very good. Not sure if it's hypoid or that you require hypoid for lsd.
    REDdawn6[OP] likes this.
  6. Mar 14, 2018 at 1:52 PM
    REDdawn6
    Redlands CA.
    2011 Tacoma TRD 4x4
    On the rear and front diff, do they use the same bolt twice on each? Ie : fill and drain? Ty
  7. Mar 14, 2018 at 1:55 PM
    dalero
    dale
    RI
    yes same size
  8. Mar 14, 2018 at 2:05 PM
    REDdawn6
    Redlands CA.
    2011 Tacoma TRD 4x4
    Thank you
  9. Mar 14, 2018 at 2:16 PM
    REDdawn6
    Redlands CA.
    2011 Tacoma TRD 4x4
  10. Mar 14, 2018 at 3:04 PM
    dalero
    dale
    RI
    I'm sorry I believe the drains have a magnet and the fillers don't. I'll try to get #s.for fillers.
  11. Mar 14, 2018 at 3:07 PM
    Clearwater Bill
    Billy
    Largo Florida
    Always remove the fill plug first.
    If you drain the fluid, then find you can't remove the fill plug for some reason, you are now immobile.
    If you do the fill plug first, and can't get it out, at least you can drive it somewhere for help.
    Hardscrabble, REDdawn6[OP] and tomwil like this.
  12. Mar 14, 2018 at 4:15 PM
    dalero
    dale
    RI
    The part numbers I gave you are from receipts from the local Toyota dealership for a couple plugs I replaced. One front one rear and washers. I just changed my transfer and trans(manual)fluid last weekend and noted the plugs are the same size as the rear. Not having any luck finding specific oem drain vs fill numbers on line.
  13. Mar 14, 2018 at 4:59 PM
    08TacoTrD
    08TacoTrD Well-Known Member
    08 TRD Offroad
  14. Mar 25, 2018 at 8:42 AM
    mikalcarbine
    mikalcarbine Well-Known Member
    Phoenix, AZ
    2015 AC TRD OR
    I'll be changing my fluids soon, Amazon no longer lists Mobil 1 104361 for sale around $10/qt. I can only seem to find it locally for $12.99/qt. Any suggestions?
  15. Mar 25, 2018 at 8:48 AM
    REDdawn6
    Redlands CA.
    2011 Tacoma TRD 4x4
    The shipping the Amazon deal was not a prime free 2 day. I went to Pep Boys and they had for $10.99 , grabbed six.
  16. Mar 25, 2018 at 8:51 AM
    REDdawn6
    Redlands CA.
    2011 Tacoma TRD 4x4
    At least or me. They fluid pump I bought , has a bit of a shorter hose to the bottom of the bottle . Does not go all they way. So I grabbed a plastic cup, dumped from oil bottle and finished pumping that way.
  17. Mar 25, 2018 at 8:51 AM
    richiep
    richiep Well-Known Member
    Rich
    NY
    2006 Tacoma Access 4WD SR5
    Trd s/c 2.85 pully Walbro 255 f/p Urd stage 3 clutch Hurst core shifter Afe cai
    The drain on the rear end, transfer & front diffs have magnets in them.
  18. Mar 25, 2018 at 9:05 AM
    mikalcarbine
    Phoenix, AZ
    2015 AC TRD OR
    Pep boys is having 20% off sale, $8.79/qt!
  19. Mar 25, 2018 at 10:02 AM
    REDdawn6
    Redlands CA.
    2011 Tacoma TRD 4x4
    I ended up doing the front, rear diffs and the tc, this last week. I didn't mess up any bolts, only the front diff drain and fill were tougher to unscrew I added a little anti seize but I did replace all the gaskets/washers with new ones. Maybe about an hour with my son and me doing it.
  20. Mar 25, 2018 at 10:06 AM
    mikalcarbine
    Phoenix, AZ
    2015 AC TRD OR
    How many quarts did you end up using? How many miles on the fluid that came out?
