Part #s Needed: Plugs
Discussion in '1st Gen. Tacomas (1995-2004)' started by seabeegt, Dec 21, 2020.
  1. Dec 21, 2020 at 11:46 AM
    seabeegt
    seabeegt [OP] Well-Known Member
    Greg
    03 Tacoma 3.4L V6
    4” Lift, Exhaust Pipe
    So I decided to swap out all the gear oil in my 03 Taco (3.4L). Didn’t go so well. I don’t think anyone’s ever cracked these plugs open... that or they over tightened them (majorly). Anyways, I did some damage to a few of the plugs while removing them and I’d like to get to proper part #s to replace them:
    Transmission (manual)
    Transfer Case
    Front diff
    Rear diff
    Thank you for the help!
  2. Dec 21, 2020 at 2:14 PM
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    These are plugs.......holding non-pressure fluid. Use new gaskets, then tighten to a firm snug, like the oil pan drain plug. They don't need a gorilla torque.
    If you damaged the plugs, then you should replace them. They're not expensive. A damaged and over tightened plug will be a major PITA at the next service.
  3. Dec 21, 2020 at 4:56 PM
    seabeegt
    Greg
    03 Tacoma 3.4L V6
    Yeah, I know. I just finished cracking the last of em open. The prior owner either never serviced them or put threadlocker on. I just need the part #s now... the microfiches are really hard to read.
  4. Dec 21, 2020 at 6:15 PM
    MikeWH
    MikeWH Well-Known Member
    Colfax, CA
    1999 TRD 4x4 (x2)
    Get a Lexus plug for the front diff so you don't have to use allen keys. 90341-24016 on Lexuspartsnow.com
    Also you should replace the crush washers each time.
    Sorry I don't have the part numbers handy.
  5. Dec 21, 2020 at 11:53 PM
    seabeegt
    Greg
    03 Tacoma 3.4L V6
    Thx for the lead. I’m using Yotashop to get the right #s
