Parts Catalog Finally Updated - Information
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Jeff Lange, Aug 19, 2015.
  1. Nov 6, 2015 at 11:26 AM
    #201
    tacomanamedolga
    tacomanamedolga Well-Known Member
    SeviervilleTn
    2015 trd offroad
    I thought I would. Unpainted, the plastic ones from the off-road model.
  2. Nov 6, 2015 at 12:41 PM
    #202
    Jeff Lange
    Jeff Lange [OP] Well-Known Member
    Calgary, Canada
    '86 AE86, '05 NCP13, '11 GSE21
    75871-04060 - Front, RH
    75872-04060 - Front, LH
    75873-04090 - Rear, RH
    75874-04090 - Rear, LH
    75395-35070 - Clip, Orange (Qty: 16)
    75396-35020 - Clip, Blue (Qty: 22)
    90159-60603 - Screw (Qty: 28)
    90189-06013 - Grommet (Qty: 4)
    Jeff
    HoneyBadgerJr likes this.
  3. Nov 6, 2015 at 1:08 PM
    #203
    tacomanamedolga
    SeviervilleTn
    2015 trd offroad
    Thanks again
  4. Nov 7, 2015 at 10:36 PM
    #204
    ToyoTacoma08
    ToyoTacoma08 Well-Known Member
    06 Tacoma Regular Cab
    Where do we go to order or get a diagram of this?
  5. Nov 9, 2015 at 9:52 AM
    #205
    Jeff Lange
    Calgary, Canada
    Your local Toyota dealership and/or a dealership that sells parts online.
    Jeff
  6. Nov 10, 2015 at 10:45 AM
    #206
    Dean724
    Dean724 Well-Known Member
    Upland, CA
    Thanks for all the info you've provided thus far Jeff. Would you happen to know if the fog lamp housing is the same for the 2016?
    2015 PN:
    LH Lamp Assy 81220-08020
    RH Lamp Assy 81210-08020
  7. Nov 10, 2015 at 1:24 PM
    #207
    Jeff Lange
    Calgary, Canada
    The 2016 uses two types of fog lights, either the same as the 2012-2015 or the newer low-wattage type (81210-02160 / 81220-02160).
    Jeff
    Dean724 likes this.
  8. Nov 14, 2015 at 3:26 PM
    #208
    MannyS
    MannyS Well-Known Member
    Republic of Texas
    Jeff - Is the chrome SR5 rear bumper cover available as an individual part for each side or must I purchase the entire right and left bumper in order to obtain the chrome rear bumpers on each side? Thanks!
  9. Nov 18, 2015 at 4:14 PM
    #209
    tacomanamedolga
    SeviervilleTn
    2015 trd offroad
    What's the intermittent wiper switch part number and cost? If you could check that would be awesome! Thank you
  10. Nov 20, 2015 at 8:56 PM
    #210
    Mrharper68
    Mrharper68 Member
    Richard
    Spokane
    2020 DCLB OR 4wd
    none
    The OR uses the wide angle fog lights with 55watt H11 bulb.
    if your bulb is the narrow angle it uses a 19watt H16 Bulb
  11. Nov 21, 2015 at 7:16 AM
    #211
    Haikin
    Haikin Well-Known Member
    Hey Jeff do you know the part # for the painted flares? I am particularly looking for black. I apologize if you already listed them. I just didn't see it in the thread.
    Thanks
  12. Nov 21, 2015 at 12:44 PM
    #212
    Jeff Lange
    Calgary, Canada
    The chrome pieces are separate. That said, the parts catalog is somewhat vague on this. I only seem to see the plain black SR pieces, the painted without sensors and painted with sensors. I don't see a listing for the chrome. It is super odd. I will look into this more.
    84652-06340 - USA-Spec
    84652-06240 - Canada-Spec
    If that is indeed the difference, the Off-Road is the same fog light assembly as the 2015, while the narrow angle used is not.
    75871-04900 - Front RH (Painted Type, Requires Painting)
    75872-04900 - Front LH (Painted Type, Requires Painting)
    75873-04900 - Rear RH (Painted Type, Requires Painting)
    75874-04900 - Rear LH (Painted Type, Requires Painting)
    These do not come painted, you would need to have that done yourself.
    Jeff
  13. Nov 21, 2015 at 7:06 PM
    #213
    MannyS
    Republic of Texas
    Thanks Jeff. Also, did you receive the item?
  14. Nov 22, 2015 at 10:28 AM
    #214
    jarury
    jarury Well-Known Member
    jacob
    alvin tx
    2012 corolla s
    can you get the roof rack part number please, and is it the same as the 2nd gen?
    thanks
  15. Nov 22, 2015 at 10:48 AM
    #215
    Garyji
    Garyji Well-Known Member
    Gary
    Western North Carolina
    2016 BR SR5 DCSB V6 4WD. TRD Pro 17's, BFG KO2's
    Hey Jeff. Thanks for all your help here. I'm looking for the part numbers for the TPMS sensors on the TRD Sport alloys. I changed to alloys from the steel's and did the "turn them upside down" swap with the steel sensors. I'd like to eventually get it right. I currently don't have each tire pressure readout. The yellow light is out though.
    Thanks,
    G.
  16. Nov 22, 2015 at 11:10 AM
    #216
    Rt4623
    Rt4623 New Member
    Robert
    2016Tacoma Trd
    None
    Anyone know where to get a high performance air flow sensor
  17. Nov 23, 2015 at 8:27 AM
    #217
    Jeff Lange
    Calgary, Canada
    I did last week, yeah! Many thanks man!
    PT278-35140, it is the same as the 2015.
    42607-06030 - Alloy Wheels and Plain Steel Wheels
    42607-04020 - Styled Steel Wheels
    Nope.
    Jeff
    jarury[QUOTED] likes this.
  18. Nov 23, 2015 at 11:38 AM
    #218
    jarury
    jacob
    alvin tx
    2012 corolla s
    Thanks!!
  19. Nov 25, 2015 at 3:13 PM
    #219
    Elmo
    Elmo Well-Known Member
    Harvey
    Cramerton, N.C.
    2016 OR AC TRD
    Rigid 20 LED Light Bar Weather Tech mats Toyota Mudguards
    Costs?
  20. Nov 26, 2015 at 9:25 AM
    #220
    RM61188
    RM61188 Drives a 4Runner on a tercel budget
    Rodney
    New Orleans
    2017 T4R TRD OFF ROAD
    So, Jeff. I hear you can help me with a small problem i have. Ive got a 3rd gen trd off road and somehow managed to lose a center cap off the rear wheel after installing a set of spacers. Could you hook me up with a part number or a link to where i can order one? Ive tried endless searches for hours and Im only finding 2nd gen caps. Any help with this matter is greatly appreciated. get-attachment.aspx-13.jpg
