Parts Catalog Finally Updated - Information
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Jeff Lange, Aug 19, 2015.
  1. Feb 2, 2016 at 5:36 PM
    #281
    tekoma
    tekoma Member
    Apex, NC
    24 Tacoma TRD Off Road Manual
    Method MR318 17x8.5 Bronze BF Goodrich KO3 285/70R17 XPEL Partial PPF XPEL 70% tint windshield XPEL 35% tint front sides
    I asked in another thread and not sure that I got the right part number. Jeff, are you able to confirm the TRD off road / SR5 lower black unpainted valance? The part number I previously got was pulling up a cost of around $600. This doesn't seem right...
  2. Feb 2, 2016 at 6:12 PM
    #282
    thepinktaco
    thepinktaco Well-Known Member
    Cody
    Orange, MA
    95 SAS Tacoma, 99 4runner, 16 Tacoma.
    I was wondering the same thing. You would need to know if the body control module is the same. They list many different ones and are a pain to track down the correct part numbers. Plus you would have to see if it was prewired. Im picking up my truck tomorrow, was planning on looking to see at some point if it was doable.
  3. Feb 2, 2016 at 6:49 PM
    #283
    hirod
    hirod Well-Known Member
    hawaii
    16 double cab short bed OR
    Does anyone know if there is a vinyl floor liner for double cabs? They are available for 2nd gen access can work trucks.
  4. Feb 2, 2016 at 7:14 PM
    #284
    Sawick
    Sawick Still not worthy!
    JB MDL, NJ
    16 TRD Sport
    T4R TRD Pro Wheels, LED lights, Tonneau Cover, ICI running boards, AVS window/bug
    This is the other piece I was speaking about (along with the side flares) that go on the OR in black.
  5. Feb 2, 2016 at 7:54 PM
    #285
    bruce_d
    bruce_d Well-Known Member
    Davis, Ca
    2016 Tacoma DCSB SR5
    Hi - Can you list the part number for the OR/Sport shift knob (Auto trans). Apparently it is Leather and different from the SR5 vinyl.
    Thanks
  6. Feb 3, 2016 at 12:10 PM
    #286
    nevadabugle
    nevadabugle Desert Rat
    Elko, NV
    2016 DCSB TRDOR manual in quicksand
    Well then why does it take my 15 minutes of idling or 10 miles of driving in the morning for my truck to blow warm air? Am I doing something wrong, is my truck broken, or is this only on the premium and tech package trucks?
  7. Feb 3, 2016 at 12:18 PM
    #287
    fredgoodsell
    fredgoodsell Well-Known Member
    Salt Lake, UT
    2017 DC TRD OR
    Have you tried this? Not sure if Tacomas have the exact same criteria to kick on the electric heater:
    "Positive Temperature Coefficient (PTC) heater is a small electrical heater located in the heater core and is used on vehicles equipped for cold areas. See Fig. 78 . PTC heater may be turned on if all of the following conditions exist: temperature control switch is at MAX HOT position, engine speed is more than 1050 RPM, engine coolant temperature is less than 176°F (80°C) and generator power ratio is less than 95 percent. PTC heater may also be turned on and off depending on generator power ratio."
  8. Feb 3, 2016 at 12:32 PM
    #288
    nevadabugle
    Elko, NV
    Yeah while driving to work at below zero all those things are being met. Some mornings I swear my diesel Duramax blows warm air sooner than my 2016 Taco. That's why I was surprised to hear that it has this special feature.
  9. Feb 3, 2016 at 12:34 PM
    #289
    nevadabugle
    Elko, NV
    Does max hot include having the cabin recirculation on? Maybe that is where I am messing up?
  10. Feb 3, 2016 at 7:36 PM
    #290
    qnyla
    qnyla Well-Known Member
    NM
    2006 & 2016 DCSB TRD Off Road 6-Speed
    How can you tell if your truck is equipped with a PTC heater?
  11. Feb 3, 2016 at 7:53 PM
    #291
    nevadabugle
    Elko, NV
    According to @Jeff Lange all the v6 models have it. I just must not be doing something right because mine does not seem to blow warm air until the engine temperature is up. What am I missing? It has been miserable cold this winter!!!!
  12. Feb 3, 2016 at 8:25 PM
    #292
    qnyla
    NM
    Hmm, my truck seems to warm up fast, much fast than my 2nd Gen. Certainly faster than 10 miles (more like 2).
  13. Feb 3, 2016 at 8:36 PM
    #293
    nevadabugle
    Elko, NV
    Do you have the recirculation button on or off?
  14. Feb 3, 2016 at 9:04 PM
    #294
    qnyla
    NM
    Off.
  15. Feb 3, 2016 at 9:06 PM
    #295
    nevadabugle
    Elko, NV
    I'm confused. Maybe I am expecting it to warm up too fast at sub zero temps. I'll hop in cold in the morning and reset the trip odometer and see how far it takes to blow warm.
  16. Feb 3, 2016 at 9:16 PM
    #296
    Herniator
    Herniator Well-Known Member
    Edmonton
    2016 Toyota Tacoma TRD Sport
    chrome valve stems covers
    Try setting your temp to the hottest setting.
  17. Feb 4, 2016 at 5:34 AM
    #297
    nevadabugle
    Elko, NV
    I do. Every morning. I
  18. Feb 4, 2016 at 6:07 PM
    #298
    Elmo
    Elmo Well-Known Member
    Harvey
    Cramerton, N.C.
    2016 OR AC TRD
    Rigid 20 LED Light Bar Weather Tech mats Toyota Mudguards
    Bad thermostat?
  19. Feb 4, 2016 at 6:24 PM
    #299
    nevadabugle
    Elko, NV
    Don't think so. It does warm up. Just not much different than any other truck I have driven that did not have this feature.
    Elmo[QUOTED] likes this.
  20. Feb 4, 2016 at 6:30 PM
    #300
    forty2
    forty2 Well-Known Member
    Cascadia
    2016 DCSB OR 6MT
    I cranked mine up this morning (~35°) just to see, definitely a little bit of heat just pissing against the cold. I could smell it more than feel it though, fairly certain it's the first time the PTC has been active as it was cook off I was smelling.
