Parts Catalog Finally Updated - Information
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Jeff Lange, Aug 19, 2015.
  1. May 24, 2016 at 6:11 PM
    #321
    AgnstAllOdds21
    AgnstAllOdds21 Active Member
    Thomas
    2016 MGM Tacoma OR DCLB
    SunTek Window Tint, LED Interior and license plate Lights, FabFours Premium Front Bumper
    Do you happen to know if they come pre-wired for the rear sensors or not?
  2. May 26, 2016 at 11:25 AM
    #322
    glider_guider
    glider_guider Well-Known Member
    2016 Red Tacoma TRD OR 4x4
    Jeff,
    Just an update ... it isn't 90080-34016 either. I'm at a loss. Do you have any suggestions on how to get a replacement fill plug for the transmission when the parts diagram is so confusing that no one can determine which plug I need?
    Sorry to bother you again, and thanks again for everything you do for this forum!
  3. May 26, 2016 at 2:16 PM
    #323
    LiquidDragon
    LiquidDragon Well-Known Member
    Michael
    Williamsburg, Va but now in the Philippines
    2021 Toyota Hilux Conquest 4x2
    none yet
    Unfortunately I am currently deployed and my truck is thousands of miles away so I can't check to see if there is a plug or not. Toyota usually uses the same harness for all trim levels and these things can usually be added later without any issues. I am keeping my fingers crossed that I can just add the harness that is located on the back of the bumper and the four sensors located in the bumper itself. I will probably also have to add the reverse sensor switch that is located in the cab that turns the system on and off as well.
  4. May 26, 2016 at 4:11 PM
    #324
    Jeff Lange
    Jeff Lange [OP] Well-Known Member
    Calgary, Canada
    '86 AE86, '05 NCP13, '11 GSE21
    The only other plug in the diagram is 90341-14011. It's shown going into the transmission in a different spot, but perhaps you can give it a shot?
    Jeff
  5. May 26, 2016 at 6:54 PM
    #325
    glider_guider
    Awesome! Thanks! I'll give it a shot.
  6. Jun 19, 2016 at 6:51 PM
    #326
    Bean&Cheese
    Bean&Cheese Well-Known Member
    San Antonio Texas
    How the heck do you get that part out?
  7. Jul 4, 2016 at 7:46 AM
    #327
    Beto
    Beto Member
    Peter
    CT
    16 Inferno TRD Sport Access Cab / Manual
    debadged destickered 20% tint
    Grille assembly 53100-04500-xx :
    Jeff, how do you know if grille surround/molding is black instead of chrome? Looks like SR-trim is black and SR5-trim is chrome. Same part number? (btw C5 = C8 for black?)
    Just want to replace my TRD Sport grille with SR/Limited grille with black trim.
  8. Jul 4, 2016 at 10:58 AM
    #328
    Jeff Lange
    Calgary, Canada
  9. Jul 4, 2016 at 11:37 AM
    #329
    Beto
    Beto Member
    Peter
    CT
    My truck is inferno. But I'm just looking for the grille insert and moulding: both black.
    Realize that kit comes with surround. Don't think SR kit 52711-04010 is available in inferno. Am I right. If so, great. If not, just going to order it in black.
    Thanks for the quick response. Much appreciated.
  10. Jul 4, 2016 at 2:46 PM
    #330
    Jeff Lange
    Calgary, Canada
    Yes, order 53100-04500-C5, it will come with the black grille insert and the black moulding. You can swap these pieces onto your Inferno surround.
    Jeff
  11. Jul 4, 2016 at 10:56 PM
    #331
    Beto
    Beto Member
    Peter
    CT
    Excellent!! Thanks Jeff.
  12. Jul 12, 2016 at 4:30 PM
    #332
    solscooter
    solscooter Sh!t Outta Luck
    Brian
    Minnesota
    2016 TRD OR DCSB 4x4
    I'm having a hard time finding the answer to this
    What is the part number for the red tabs/pins on the back of the rear storage bins?
    Thanks Jeff
  13. Jul 12, 2016 at 8:34 PM
    #333
    Jeff Lange
    Calgary, Canada
    In the bed or in the cab? Do you have a picture?
    Jeff
  14. Jul 12, 2016 at 10:27 PM
    #334
    DNasty777
    DNasty777 HEATMISER
    Dave
    Rochester, NY
    '16MGMDCLBTRDS4X4
    Possibly pn# 4260B-04060
  15. Jul 13, 2016 at 8:07 AM
    #335
    Jeff Lange
    Calgary, Canada
    That's a wheel center cap? Was this in reply to someone else in the thread?
    Jeff
  16. Jul 13, 2016 at 8:22 AM
    #336
    VIMAI
    VIMAI Well-Known Member
    Victor
    San Benito, TX
    16 TRD Offroad
    I have an access cab with a red third brake light...Would anyone have the part number for the double cab clear brake light?
  17. Jul 13, 2016 at 8:27 AM
    #337
    Siblue
    Siblue Well-Known Member
    So Cal
    25 Tundra TRD pro
    @VIMAI High mount lamp for doublecab is 81570-04040
  18. Jul 13, 2016 at 2:12 PM
    #338
    solscooter
    Brian
    Minnesota
    Sorry I wasn't more specific. It's the red clips used to hold and align the rear storage bins in a double cab. Behind the rear seats in the cab.
    These kind.
    On the back of this.
    Thanks for the help Jeff.
  19. Jul 13, 2016 at 2:20 PM
    #339
    Jeff Lange
    Calgary, Canada
    Should be 90467-09240.
    Jeff
  20. Jul 13, 2016 at 2:22 PM
    #340
    DNasty777
    DNasty777 HEATMISER
    Dave
    Rochester, NY
    '16MGMDCLBTRDS4X4
    Sorry Jeff, forgot the quote.
    @stan23
