Parts Catalog Finally Updated - Information
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Jeff Lange, Aug 19, 2015.
  1. Jul 13, 2016 at 2:23 PM
    #341
    solscooter
    solscooter Sh!t Outta Luck
    Brian
    Minnesota
    2016 TRD OR DCSB 4x4
    Thank you sir
  2. Jul 13, 2016 at 2:25 PM
    #342
    Jeff Lange
    Jeff Lange [OP] Well-Known Member
    Calgary, Canada
    '86 AE86, '05 NCP13, '11 GSE21
    No worries, I was just confused, lol. In that case, I agree, it should be 4260B-04060.
    Jeff
  3. Jul 17, 2016 at 2:21 PM
    #343
    sly1
    sly1 Member
    Pat
    2016 Tacoma SR
    Hey Jeff, is this for the access cab, or does it apply to both?
  4. Jul 17, 2016 at 5:25 PM
    #344
    Z50king
    Z50king DCLBOR4X4FTW
    Eric
    Southern California
    2016 DCLB Off Road 4x4 Super White
    Stock and loving it
    do you know if the DC brake light is red? I think you are going to need a red bulb
  5. Jul 17, 2016 at 10:01 PM
    #345
    Jeff Lange
    Calgary, Canada
    The double cab light assembly has LED's instead of bulbs. It comes as an assembly.
    Jeff
  6. Jul 17, 2016 at 10:02 PM
    #346
    Jeff Lange
    Calgary, Canada
    I believe it's both, but would have to double check.
    Jeff
  7. Jul 17, 2016 at 11:19 PM
    #347
    nilepoc
    nilepoc Active Member
    Craig
    16 TRD OR AC
    TRD rims, spacer leveling
    Read through this thread and did not see the part I am looking for.
    The rear panel for the SR trim when the seats are deleted in the access cab.
    Thank you in advance.
  8. Jul 18, 2016 at 10:19 AM
    #348
    Jeff Lange
    Calgary, Canada
    64270-04140-C0
    Jeff
  9. Jul 18, 2016 at 1:06 PM
    #349
    nilepoc
    Craig
    16 TRD OR AC
    Thank you.
  10. Aug 4, 2016 at 5:03 PM
    #350
    Z50king
    Eric
    Southern California
    Stock and loving it
    Dearest Jeff,
    does Toyota offer a lens for the tail light or is the lens attached to the whole unit?
    Respectively yours,
    Eric
  11. Aug 5, 2016 at 11:02 PM
    #351
    Jeff Lange
    Calgary, Canada
    Whole unit only, unfortunately.
    Jeff
  12. Aug 6, 2016 at 6:30 PM
    #352
    Greenbean
    Greenbean B.S. Goodwrench
    Zack
    Western NC
    2015 AC 2.7L 5-spd 4x4 Utility Package
    Is the distance between the bed rails the same?
    It seems yes it's deeper than the 2nd Gen but what about width wise?
    I have a Toyota bed box, the large one and am wondering if it would fit on the 3rd Gen.
    I'm trying to be hopeful about it!
  13. Aug 6, 2016 at 6:51 PM
    #353
    Elmo
    Elmo Well-Known Member
    Harvey
    Cramerton, N.C.
    2016 OR AC TRD
    Rigid 20 LED Light Bar Weather Tech mats Toyota Mudguards
    Anyone know the part number for the front bed rail and also does it bolt up to existing holes or bolts?
  14. Aug 6, 2016 at 7:10 PM
    #354
    Murrayb4
    Murrayb4 Internet Toyota Tech
    Downingtown, PA
    2017 Blazing Blue TRD Sport DCSB with 3 pedals
    Custom cracked windshield
    ExplorHer and Elmo[QUOTED] like this.
  15. Aug 9, 2016 at 4:43 AM
    #355
    TRDPro4x4
    TRDPro4x4 Well-Known Member
    Jeff,
    Do you have any info on the 2 screws that hold in the fog light assembly (size/threads)? I bought mine second hand and they didn't come with the screws.
    Thanks.
  16. Aug 9, 2016 at 6:12 AM
    #356
    Z50king
    Eric
    Southern California
    Stock and loving it
    Thank you. I found the assembly on parts website for less
  17. Aug 15, 2016 at 9:13 PM
    #357
    hirod
    hirod Well-Known Member
    hawaii
    16 double cab short bed OR
    Anybody have the pn for the crankcase vent hose. Trying to setup my catch can and want to see if i can use oem hoses.
  18. Sep 13, 2016 at 9:21 AM
    #358
    Nitori
    Nitori Well-Known Member
    Maricopa AZ
    2021 T4R SR5
    @Jeff Lange , wondering if you might have the parts catalog wizardry for this...
    Do you know what P/N to buy for a replacement terminal wire, as in just one wire and the metal locking tab that clicks in and secures it inside of a plastic connector... specifically, the plastic connector P/N 90980-12909.
    Explanation follows:
    I've been trying to figure out a way to seamlessly integrate fog lights into an SR model- that is, using 100% (or close to) OEM parts and no add-a-fuse or splicing.
    I started by verifying that the SR has all the "necessary parts" for fog lights. Looks like almost everything is actually already there, except for a simple ground switch on pin 26 into this connector:
    Everything else- harness connections, relay wiring, fuses, even the wire for the ground signal out from the body ECU is there, but there's just no way to trigger it because... because reasons.:notsure: I dunno why Toyota would make a special harness to gimp functionality when everything else is ostensibly the same, but hey, I'm no engineer.
    As far as I can tell from the wiring diagrams, ground signal goes into body ECU, ground signal comes out to fog relay (except for when high beams are on yadda yadda) and lights them up. So basically all I would have to do would be insert a wire in there, run it to a 2015 or equivalent dash switch, ground the other side of the switch, and boom, fog lights that control exactly like OEM!
    ExplorHer and 2016Tacoman like this.
  19. Sep 13, 2016 at 10:12 AM
    #359
    2016Tacoman
    2016Tacoman Well-Known Member
    J
    2016 Tacoma 4x4 V6 Metallic
    Nice work hunting that connector down. Did you ground the cavity with maybe a paper clip or something to see if your logic is correct? Kind of risky unless you are absolutely sure. Keep us updated. Good work.
  20. Sep 13, 2016 at 10:58 AM
    #360
    cactushead
    cactushead Well-Known Member
    San Diego
    2017 MGM DCSB 4x4 TRDOR
    Front hitch, 5100's, 885's, Snugtop XV, Slimline II, Sumos, bed platform, AAL, interior LED lights in cab and bed, exterior camp/backup LED's, Rigid DOT Fogs and D2 Pro Spots, Mega Ultra +130 bulbs, heavy-duty fog light, spot light, and low beam wiring harness, Weathertech mats, Re-routed dif breather and A/C drip line, dash cam, front and side cameras, anytime rear camera and nav, Blue Seas fused bus bars to cab and bed, heavy-duty bus bar w/Anderson quick disconnects under the hood for powering winch, solar, air compressor, and other accessories.
    You can buy pins for connector at most electronics store, such as Radio Shack. You will have to check, but it is probably this type of pin. If you can't determine the type of pin used in the connector, you may need to buy a pin extractor tool so you can remove one of the existing wires.
