Parts Catalog Finally Updated - Information
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Jeff Lange, Aug 19, 2015.
  1. Sep 13, 2016 at 11:42 AM
    #361
    2016Tacoman
    2016Tacoman Well-Known Member
    J
    2016 Tacoma 4x4 V6 Metallic
    Or get a connector from a junkyard. Appears older cars use the same connector.
  2. Sep 13, 2016 at 1:21 PM
    #362
    cactushead
    cactushead Well-Known Member
    San Diego
    2017 MGM DCSB 4x4 TRDOR
    Front hitch, 5100's, 885's, Snugtop XV, Slimline II, Sumos, bed platform, AAL, interior LED lights in cab and bed, exterior camp/backup LED's, Rigid DOT Fogs and D2 Pro Spots, Mega Ultra +130 bulbs, heavy-duty fog light, spot light, and low beam wiring harness, Weathertech mats, Re-routed dif breather and A/C drip line, dash cam, front and side cameras, anytime rear camera and nav, Blue Seas fused bus bars to cab and bed, heavy-duty bus bar w/Anderson quick disconnects under the hood for powering winch, solar, air compressor, and other accessories.
    the way I read it, he wants to add a wire to the existing connector.
  3. Sep 13, 2016 at 2:14 PM
    #363
    Nitori
    Nitori Well-Known Member
    Maricopa AZ
    2021 T4R SR5
    Yeah, but if I nab a junkyard connector I can pull out one of the junkyard connector's wires to add to the existing one. ;)
    I'll have to see. I'm a bit apprehensive about all this because I'm gonna feel dumb if it doesn't work, but at the same time EVERY part number and tech manual I can find says that's the pinout, it's just not wired on an SR.
    ExplorHer and 2016Tacoman like this.
  4. Sep 13, 2016 at 2:32 PM
    #364
    2016Tacoman
    J
    Extract the pin with the wire from the junk connector and splice to the wire.
  5. Sep 13, 2016 at 2:39 PM
    #365
    2016Tacoman
    J
    I wouldn't feel dumb if it doesn't work, you just don't want to short something. If you put the fog relay in the fuse block, and touch that pin to ground, it should click the relay on. Save a trip to the junkyard by probing the cavity with a paper clip. I see it is pin 26 on the main ecu diagram I have, question is I don't know if what you are showing in the photo is the main ecu connector.
  6. Sep 13, 2016 at 7:51 PM
    #366
    Nitori
    Maricopa AZ
    2021 T4R SR5
    I would feel dumb if it lets the magic smoke out. :p
    Talked to my father who is a lifetime electronics engineer, he said that a good idea would be to stick in a resistor instead of a paper clip, with hopes that if pin 26 is magically some super important thing that should never be grounded, the circuit protection will have more of an opportunity to safely blow a fuse before anything happens. He's a smart guy, I would have just jumpered that sucker straight to ground and prayed a little.:thumbsup:
    Too late to try anything tonight, but I will report back and I will definitely do a write up on it with part numbers and all that if I'm successful.
  7. Sep 13, 2016 at 9:22 PM
    #367
    cactushead
    San Diego
    It comes down to: 1) what is your time worth and 2) do you want something that looks clean and professional or something that looks ghetto? Seems like a lot of effort to go to the junk yard just for a piece of wire when you can buy a bag of pins for a couple of dollars. Plus, he said "...no add-a-fuse or splicing".
  8. Sep 14, 2016 at 4:32 AM
    #368
    2016Tacoman
    J
    Do you have the stock number for the pins ? $2 highly doubtful. Nothing is $2 from toyota. I could inline splice it with shrink and you would probably never notice. Ever put a maestro in with I data link harness for the new $1200 pioneer radios with steering wheel interface or any other aftermarket radio install for that matter with maestro ? Get back with us how many splices are on the harness lol ! You're funny.
  9. Sep 14, 2016 at 8:18 AM
    #369
    Nitori
    Maricopa AZ
    2021 T4R SR5
    Right now my "best guess" is that the PN is 82998-24300, for a single extra wire that will clip into the harness.
    $11 from partznet.
    Sounds crazy at first, but I checked w/ the chain of salvage yards I usually use, the closest yard to me only has up to '06 Toyotas. A much further one has a 2011 Corolla which is probably my best shot, but it's yard date was late July, which means it could be pretty well picked over by now.
    Honestly after the gas to the yard (farther yard with the 2011 is 75 miles!!), admission to the yard ($3 to get in, x2 if I bring my friend), and however much I convince them to let me buy a length of wire for? It might be a wash.
  10. Sep 14, 2016 at 9:14 AM
    #370
    2016Tacoman
    J
    Back to testing with a 1kohm with a paper clip maybe? :)
  11. Sep 14, 2016 at 9:24 AM
    #371
    2016Tacoman
    J
    You do realize there are millions of different types of pins, keepers, etc in use today and you think that shit shack part will fit ????? Wow.
    If you read Toyotas factory service manuals they even have a method spelled out for splicing.:facepalm:
  12. Sep 14, 2016 at 9:46 AM
    #372
    cactushead
    San Diego
    I wish you could read as well as you can smack talk. Re-read my initial post: "You can buy pins for connector at most electronics store, such as Radio Shack. You will have to check, but it is probably this type of pin. If you can't determine the type of pin used in the connector, you may need to buy a pin extractor tool so you can remove one of the existing wires." Based on the picture, it appears to be the same style of connector, so yes, I think it will fit. But as I said, he would have to check first.
  13. Sep 14, 2016 at 10:05 AM
    #373
    2016Tacoman
    J
    Based on the picture it is the same type of connector? at Radio Shack. Really ????
    :facepalm::facepalm::facepalm:
  14. Sep 14, 2016 at 10:26 AM
    #374
    Nitori
    Maricopa AZ
    2021 T4R SR5
    Guys calm down, it's not worth getting excited over.
    Cactus, the pin pitch on what you linked looks pretty big- these pins are like, literally a millimeter or less wide. Thank you for the link, but I don't think that will work.
    My thumb got in the way but this should give you a sense of scale. The pins are maybe 1/32" across?
    ANYWAYS,
    It's looking more promising! I haven't switched it to ground yet to see if a relay clicks, but I busted out the DVM and checked the terminal as per the repair manual:
    She's giving me 11.something V with the ignition off (and no fog light switch installed which is close enough) so there's a signal there!
    Right now I need something slender enough to get down that hole. Paperclips are too thick, believe it or not.
  15. Sep 14, 2016 at 10:28 AM
    #375
    2016Tacoman
    J
    Use a strand of wire or center of a coax works for me a lot of times.
  16. Sep 14, 2016 at 11:57 AM
    #376
    tehsexehnes
    tehsexehnes Active Member
    Canada
    2017 TRD Pro Manual Cement
    Sorry to go way back in time guys but I'm wondering if anybody has any idea how to get a hold of the connector for this fog light switch? None of the junk yards around my area have an IQ or TC to steal the harness out of. I assume there's no part # for the connector itself as its a part of a whole much larger electrical harness.
    Thanks for your help.
  17. Sep 14, 2016 at 12:30 PM
    #377
    Siblue
    Siblue Well-Known Member
    So Cal
    25 Tundra TRD pro
    @tehsexehnes I've been looking for that connector for years now still no luck. I know many scions are prewired for it including FR-S(now 86) and 2nd gen xB.
    Good luck.
  18. Sep 14, 2016 at 1:35 PM
    #378
    2016Tacoman
    J
    Do you have the relay installed in the fuse/relay compartment. If it didn't come with fogs its not there. All the wiring is good to the relay socket I have found out from probing before. If not you could just put a resistor of proper coil value across those terminals in there for the time being and monitor the voltage.
  19. Sep 14, 2016 at 6:48 PM
    #379
    Nitori
    Maricopa AZ
    2021 T4R SR5
    :headbang::headbang::headbang:
    Oh yeah, my little hack works! Lights up the dash icon for "fog lights" and everything!!
    Man, that was a serious pain in my ass though... so I'm testing it... it keeps registering 12V high when it shouldn't... this would mean the fogs would always be on, which is wrong!
    "Why the f***motherf***ing ****** thing keeps ***** going high" I'm saying to myself...
    I was testing with the door open.:frusty: The fogs are courtesy lights that light up when you open the door.:frusty:
    (Ghost edit like a year later... as far as I can tell it was actually because I had done some un-plug/re-plugs on the body ECU while the door was open which made some funny business happen.)
    :anonymous: I felt REALLY stupid after cussing up a storm over that one.
    So now my last order of business is finding the appropriate wire terminal, and then I can put all this together!:bananadance:
    Greenbean, ExplorHer and 2016Tacoman like this.
  20. Sep 14, 2016 at 6:52 PM
    #380
    2016Tacoman
    J
    YOU ARE THE MAN !!!!!!
    You need to write this up in a separate thread its that good. Good work my man !
