Parts Catalog Finally Updated - Information
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Jeff Lange, Aug 19, 2015.
  1. Aug 31, 2015 at 5:20 PM
    #101
    Jeff Lange
    Jeff Lange [OP] Well-Known Member
    Calgary, Canada
    '86 AE86, '05 NCP13, '11 GSE21
    You could buy the replacement parts, but it is not currently an add-on accessory, it is factory-installed only.
    This may change in the future, but currently that's how it is.
    Also, I believe earlier I gave the part numbers for the parts, but there are actually a few other parts that are different on the truck if you order it with the factory tonneau cover, such as the plastic body side panel top protectors. So there will may be other things that are different as well.
    66248-04060 - Protector, RH (6-ft Box)
    66248-04070 - Protector, RH (5-ft Box)
    66249-04060 - Protector, LH (6-ft Box)
    66249-04070 - Protector, RH (5-ft Box)
    Jeff
  2. Sep 1, 2015 at 12:37 PM
    #102
    JohnTheLuck
    JohnTheLuck Well-Known Member
    Montreal, Canada
    Only a few months before buying!
    Jeff, is the part catalog you are consulting contains only Toyota part description or also provides the manufacturer description? I am asking this since I would probably not be able to get a DC TRD Off-road in Canada, I would like to upgrade some parts of a DC TRD Sport to something similar to the TRD off-road.
  3. Sep 1, 2015 at 1:23 PM
    #103
    Jeff Lange
    Calgary, Canada
    I am a bit confused as to what you're asking. What exactly are you looking to find out?
    Jeff
  4. Sep 1, 2015 at 1:46 PM
    #104
    JohnTheLuck
    Montreal, Canada
    Jeff, I am looking too buy a TRD Sport but modify the suspension and others things with the same parts that Toyota is using for the TRD off-road. Is the catalog you are using contains the manufacturer of shocks per example (I know it is Blistein but which model).
  5. Sep 1, 2015 at 2:01 PM
    #105
    TacoJonn
    TacoJonn Well-Known Member
    Jon
    Laramie, Wyoming
    '13 DCLB Sport 4x4, '78 FJ40
    Any word on if rear door has changed? Seatbelt Mike said door was raised .5 inches but I take whatever he says with a huge grain of salt.
  6. Sep 1, 2015 at 2:54 PM
    #106
    Jeff Lange
    Calgary, Canada
    Toyota doesn't typically list the manufacturer of components in their parts catalogs unfortunately, all I have are part numbers.
    Jeff
  7. Sep 1, 2015 at 4:05 PM
    #107
    Z50king
    Z50king DCLBOR4X4FTW
    Eric
    Southern California
    2016 DCLB Off Road 4x4 Super White
    Stock and loving it
    Nope. The skin and glass are the same. They raised the whole truck
  8. Sep 1, 2015 at 5:07 PM
    #108
    MannyS
    MannyS Well-Known Member
    Republic of Texas
    Jeff - Is the chrome trim surrounding the limited fog light an individual part or is the chrome trim part of the entire lower grill? I like the bezel.
  9. Sep 2, 2015 at 9:13 AM
    #109
    Jeff Lange
    Calgary, Canada
    The chrome bezel is a separate part, however it doesn't fit onto the fog surround not meant for it. So you'd need the fog surround and the chrome bezel.
    52127-04030 - RH Fog Surround
    52128-04030 - LH Fog Surround
    52125-04030 - RH Chrome Bezel
    52126-04030 - LH Chrome Bezel
    Jeff
  10. Sep 2, 2015 at 9:17 AM
    #110
    TRDPro4x4
    TRDPro4x4 Well-Known Member
    Jeff,
    Do you have the part numbers for the unpainted overfenders front and rear?
    thanks.
  11. Sep 2, 2015 at 9:18 AM
    #111
    MannyS
    Republic of Texas
    Thanks Jeff
  12. Sep 2, 2015 at 9:26 AM
    #112
    Jeff Lange
    Calgary, Canada
    75871-04060 - Flare, RH Front (Unpainted)
    75872-04060 - Flare, LH Front (Unpainted)
    75873-04090 - Flare, RH Rear (Unpainted)
    75874-04090 - Flare, LH Rear (Unpainted)
    Jeff
  13. Sep 2, 2015 at 10:25 AM
    #113
    TRDPro4x4
    Thanks Jeff.
  14. Sep 2, 2015 at 11:09 AM
    #114
    TRDPro4x4
    Jeff,
    Would you confirm that the center smoked gray chrome portion of the TRD grille is removable? Or is the whole
    body colored nose cap/chrome surround bezel/center grille one single piece?
    Thank you.
  15. Sep 2, 2015 at 11:54 AM
    #115
    Jeff Lange
    Calgary, Canada
    I believe it is all once piece, but I can't say with 100% certainty just from the parts catalog. All I can tell is that Toyota sells it all as once piece.
    Jeff
  16. Sep 2, 2015 at 12:21 PM
    #116
    NoDak
    NoDak Well-Known Member
    JR
    Minot, ND
    16 Tacoma TRD Sport 4x4 Blazing Blue
    anyone have a part # for the new 2016 homelink mirror? :)
  17. Sep 2, 2015 at 12:26 PM
    #117
    Jeff Lange
    Calgary, Canada
    87810-04110
    Jeff
  18. Sep 2, 2015 at 12:34 PM
    #118
    NoDak
    JR
    Minot, ND
    thanks.
  19. Sep 2, 2015 at 2:45 PM
    #119
    NoDak
    JR
    Minot, ND
    just wanted to ask, these part numbers you are posting are from the OEM part catalog that the Toyota parts counter has access to? they should be able to lookup that part number and order a replacement so to speak correct?
  20. Sep 2, 2015 at 3:08 PM
    #120
    Jeff Lange
    Calgary, Canada
    Yes.
    Jeff
