Parts Catalog Finally Updated - Information
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Jeff Lange, Aug 19, 2015.
  1. Sep 19, 2015 at 7:56 PM
    #161
    Herniator
    Herniator Well-Known Member
    Edmonton
    2016 Toyota Tacoma TRD Sport
    chrome valve stems covers
    Hopefully its simply a cheap dealer add on. Can't see the side rails not getting the way but the front ones do.
  2. Sep 19, 2015 at 11:53 PM
    #162
    forty2
    forty2 Well-Known Member
    Cascadia
    2016 DCSB OR 6MT
    Is the manual shift knob still M12 x 1.25?
  3. Sep 20, 2015 at 3:38 AM
    #163
    Frank_Zuccarini
    Frank_Zuccarini Obscure Member
    Frank
    Chicagoland
    AC-TRD-OR-4x4-Barcelona Red
    Jeff, as you so graciously confirmed, the OEM Bed Mat is unchanged from 2015 to 2016, for the short bed.
    Would you know if that is also true for the Long Bed? Is the part number still PT580-35050-LB? I ask because the spec length for the 2015 is 73.5", and for 2016 it is 73.7".
    Thanks much......................... Frank
  4. Sep 20, 2015 at 11:54 AM
    #164
    Jeff Lange
    Jeff Lange [OP] Well-Known Member
    Calgary, Canada
    '86 AE86, '05 NCP13, '11 GSE21
    I can't tell actually. The rail was never sold separately (came with the box). Interestingly, the 2016 diagram still shows it, but obviously it isn't on the new trucks. :(
    Jeff
  5. Sep 20, 2015 at 1:06 PM
    #165
    tpak
    tpak Well-Known Member
    chris
    Colorado
    '16 DCLBOR JBL 4x4 Blazing Blue FTMFW
    Over in this thread which I found after asking you it looks like maybe the part number is something like this (for 2g anyway) - maybe you can confirm if this is the Tacoma part and if they are the same for 3g vs 2g? There was some chatter in that thread if I recall about Tundra parts as well.
    PT278-35100-BH (header rail)
    and
    PT278-35100-LB for long bed and -SB for short bed.
    Should be called:
    "Truck Bed Accy, Header Rail" and "Side Rail, Long" or "Side Rail, Short"
    http://www.amazon.com/Genuine-Toyota-Accessories-PT278-35100-BH-Header/dp/B00DWVN9CK
  6. Sep 20, 2015 at 6:06 PM
    #166
    over60
    over60 Over70 & still a "Grumpy Old Guy"
    Muskoka, Ontario
    2016 Inferno (Punkin) TRD 4X4 Sport DCLB w/upgrade & tech pkg..!!
    Toyota running boards/Solid Fold 2.0/custom stickers/Anti-Dark LED light under hood/Derped grill/Scoop, etc.
    Hey Jeff... How about more practical stuff like what oil filter do I need..?? You got a part # for that...AND... do I need a special wrench to remove it..??
    THanx man...
  7. Sep 21, 2015 at 6:51 AM
    #167
    Jeff Lange
    Calgary, Canada
    Yeah, those numbers (PTxxx type) are port/dealer installed parts that wouldn't show up in the parts catalog, they are replacement parts for the rail pieces for the 2005-2015, but they aren't shown in any accessory carry-over lists, etc., (because they're not technically accessories, but they're also not technically factory parts either). Someone will have to try it, or wait for Toyota to release an option for the 2016.
    Jeff
  8. Sep 21, 2015 at 6:52 AM
    #168
    Jeff Lange
    Calgary, Canada
    04152-YZZA1
    You will need a 64mm wrench to remove the filter, like other Toyotas with this type of filter.
    Jeff
  9. Sep 21, 2015 at 7:03 AM
    #169
    Jeff Lange
    Calgary, Canada
    Should be, yes. I haven't measured it yet though, and it's not listed in the parts catalog.
    Yes, it's still the same part.
    Jeff
  10. Sep 22, 2015 at 7:44 AM
    #170
    MannyS
    MannyS Well-Known Member
    Republic of Texas
    Jeff – Are the distributor installed parts listed in the parts catalog? I want the wheels from the Texas Silver Edition package that Gulf States is installing on 2016 SR5's.
  11. Sep 22, 2015 at 8:59 AM
    #171
    Jeff Lange
    Calgary, Canada
    No, only factory parts are in the parts catalog, sorry.
    Jeff
  12. Sep 24, 2015 at 11:20 AM
    #172
    fredgoodsell
    fredgoodsell Well-Known Member
    Salt Lake, UT
    2017 DC TRD OR
    OK question for you @Jeff Lange, resident parts guru. How much of the dash would you have to replace and/or how big is the piece of the dash that includes the heated seat switches? I'm curious if someone without heated seats could add the factory switches when installing aftermarket heaters?
  13. Sep 24, 2015 at 11:38 AM
    #173
    forty2
    Cascadia
    2016 DCSB OR 6MT
    Just to piggy back on this question, If I'm not mistaken the panel with the heated seat switches contains the display for the split climate control. How much would need to be swapped out to get that going in a non-tech truck?
  14. Sep 24, 2015 at 11:45 AM
    #174
    Jeff Lange
    Calgary, Canada
    The seat heater switches, that display and the climate control is all sold as an assembly, no parts are sold separately, so you'd need the entire unit.
    Jeff
    K Mac likes this.
  15. Sep 24, 2015 at 11:57 AM
    #175
    NoDak
    NoDak Well-Known Member
    JR
    Minot, ND
    16 Tacoma TRD Sport 4x4 Blazing Blue
    and that doesn't include the cost of the seats w/ the heaters :)
    unless you go aftermarket and add them yourself.
  16. Sep 24, 2015 at 11:58 AM
    #176
    fredgoodsell
    Salt Lake, UT
    2017 DC TRD OR
    Well so much for that idea...
    Thanks Jeff!
  17. Sep 24, 2015 at 12:16 PM
    #177
    HectoRome
    HectoRome Playing Scientist In The PNW
    07 PreRunner SR5 TRD Off-Road Debadged, Icon Stuffs, MaxTrac Spindles, Dirt King LCAs, Archive Garage Shackle Flip
    59926P ICON 2.5 Remote Reservoir Front Coil Over Shocks 56103 Icon Rear Hydraulic Bump Stop Kit K53163 Icon RXT Leaf Springs Kit 58730 Icon 2.5 Front Remote Reservoir Coil overs 59926P Icon 2.5 RXT OMEGA Remote Reservoir By-Pass Shocks 58550 Icon Billet Aluminum Upper Control Arms Dirt King Steel Lower Control, 1” Uni-ball Joints Archive Garage Rear Leaf Spring Shackle Flip Kit TRD Cat Back Exhaust TRD High Flow Air Filter Kenwood Receiver + JL Audio Speakers Extended Stainless Steel Front Brake Lines Extended Stainless Steel Rear Brake Lines Electronic Locking Rear Differential Rigid LED Driving Lights LED Bar in Bumper Top Windshield LED Bar Custom TACOMA Raptor Grill w/ LED Running Lights METHOD Standard Matte Black Wheels
    Welp, this thread answered ALL of my questions regarding the swapping of all my suspnsion mods to the new 16 !
    Decisions, Decisions . . .
  18. Sep 27, 2015 at 11:17 PM
    #178
    rossdaman
    rossdaman New Member
    Honolulu, Hawaii
    08 PreRunner Sport
    Pioneer AVIC F-900BT Phoenix Gold amps DLS speakers Rockford Punch subs
    Jeff can you find out if the door handles are the same? Was planning on swapping out the chrome ones for painted when my limited get's here. Thanks in advance!
  19. Sep 28, 2015 at 3:04 PM
    #179
    tpak
    chris
    Colorado
    Just came back to follow up. Thanks for the info. After delivery if they are indeed missing I will try one if I can in fact get them for $35 on Amazon.
  20. Sep 28, 2015 at 4:27 PM
    #180
    thepinktaco
    thepinktaco Well-Known Member
    Cody
    Orange, MA
    95 SAS Tacoma, 99 4runner, 16 Tacoma.
    Most of the handles have the same part number. Unless you are getting one with smart key then they will not work since the handles have sensors in them
