Passanger side mirror... a stupid question
Discussion in '1st Gen. Tacomas (1995-2004)' started by meatman, May 16, 2013.
  1. May 16, 2013 at 4:09 PM
    meatman
    meatman [OP] I deal with dead animals
    Greg
    Murphy N.C.
    (built) 04 Tacoma SR5 4x4 and 01 TRD 4x4 DD
    More than the wife knows!
    O.K. so my passanger side mirror had a mirror replaced in it by the PO and was not the right size. It would only adjust side to side as it was sitting flush on the top and bottom. I purchased a set of OEM mirrors and as i was getting ready to sand down the pass. side one i was able to pop out the mirror so i thought cool i will just replace the mirror part and not the whole assy. To make a long story short got the mirror pieces changed out only to find out that it only adjusts side to side and not up or down.... Is the motor shot or is this is the way it is? they are electric mirrors BTW
  2. May 17, 2013 at 10:34 AM
    Blindsider
    Blindsider Well-Known Member
    Craig
    Upstate NY
    12 DCLB TRD SPORT
    Just plug in the replacement without mounting it and see if that adjusts up and down.
  3. May 17, 2013 at 2:26 PM
    meatman
    Greg
    Murphy N.C.
    I did and it looks like i gonna have to change out the assy. I wasn't sure if i had to take the door pannel off to reach the plug, that is why i asked
  4. May 17, 2013 at 7:30 PM
    TacoDell
    TacoDell Truck ~n~ Tow
    SoCal
    '00 Tacoma SR5 4X
    Donahoe CO's, Deaver leaf paks, Lockright Locker, All Pro body armor ( sliders, front and rear bumpers ), All Pro under belly skids, Warn M8K w/Masterpull synthetic line, Dual Optima battery system, 4 ea LightForce Striker 170 offroad lights, 8 ea wired rock lights, and plenty more I'm sure
    I don't know squat about the powered mirrors...
    But if both old an new mirrors are dysfunctional in their vertical up and down movement...
    yet both will adjust horizontally (in/out)...
    I might began to suspect the mirror's control switch / e-connection as faulty.
    Possibly the prior OP wired them incorrectly...
    Or the switch has gone bad !?
    Do you hear the mirror motor run when the switch is toggled for that L-R adjustment ?
  5. Jan 19, 2015 at 12:20 PM
    tacomatt602
    tacomatt602 Well-Known Member
    Phoenix
    '97 5-Lug Regular Cab
    Doetsch 3" spindles, Fabtech AAL, 4Crawler 1.5" body lift, 225/70-15 Firestone LE2s, 15x7 U.S.Wheel Stealth Stars, 4x4/Prerunner grille, Kobalt low-profile toolbox, Pioneer AVH-X1600DVD
    I had to replace my manual mirror on my '97 and after installing it, I came to find out that it also only moved side to side, not up or down. I pulled that replacement mirror off a '97-00 at a salvage yard. Obviously I didn't think to check if the first one moved the same way. Reading this makes me think that all Taco passenger mirrors worked that way. :(
