Passenger side footwell leak
Discussion in '1st Gen. Tacomas (1995-2004)' started by Dabates, Jul 28, 2009.
  1. Jul 28, 2009 at 6:05 AM
    Dabates
    Dabates [OP] Well-Known Member
    Guelph, Ontario
    2001 TRD
    So I've had my '01 Tacoma for a week now and I think it's a pretty killer machine, however, we had a shit-ton of rain here this weekend and it appears the truck has a bit of a leak. I think that what's happening is that water is pooling somewhere underneath the black plastic grille at the bottom of the windshield outside the truck. I would presume that this would have a drain somewhere, however, before I picked the truck up, Toyota did a full underbody and frame spray and I'm wondering if they may have plugged up a drainage pipe leading to it any pooling overflowing into the cab. It only seems to drip if it's being sitting for a while, (lot's of rain pooling) or when the cab rolls, sharp turns left or right, heavy braking or driving up hill (as if water is spilling over an edge and into the footwell) it also sounds as though it might be landing on the A/C compressor because I get a hissing noise from the water when I'm turning to the left...
    Does anyone know of a location of drainage a hole in this instance?
    I haven't taken anything apart to further investigate yet, it's been dry for a couple days now and nothing is leaking so...
    Anyone?
  2. Jul 28, 2009 at 6:07 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    If they plugged the tube for the AC, its on the passenger side, and extends about an inch or two out of the firewall into the engine bay. Its a 1" diameter rubber hose....
  3. Jul 28, 2009 at 6:14 AM
    Dabates
    Guelph, Ontario
    2001 TRD
    Should I be able to see it from above or would it only be visible from beneath the truck? This sounds like it could be the issue given that I don't have a similar problem on the driver's side...
  4. Jul 28, 2009 at 6:15 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    It will be more easilly seen from under the truck, behind the passenger fron tire, and looking up at the fire wall.
  5. Jul 28, 2009 at 6:23 AM
    Dabates
    Guelph, Ontario
    2001 TRD
    ok, I'll check into it tonight...
    Just in case, do you have any idea where those plastic grilles drain out to?
  6. Jul 28, 2009 at 6:29 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    They drain to the outside of the truck. I belive on your year, they are tucked into/ near the body pannels.
  7. Jul 28, 2009 at 6:37 AM
    Dabates
    Guelph, Ontario
    2001 TRD
    to the insides of the front fenders? That's how it worked on my old Jetta...
