Passenger Window Not Operable
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Hard Taco2, Jun 15, 2011.
  1. Jun 15, 2011 at 1:04 PM
    Hard Taco2
    Hard Taco2 [OP] Active Member
    British Columbia
    06 TDR Off Road
    Cal me stupid! I put one of those hockey fan flags on the glass and closed the window. Now it is jammed! probably, (hopefully) burned out the fuse, hopefully nothing more, but i need to get that bloody window down! can you a) offer suggestions, and b) tell me which fuse it is, as the handbook does not show it. And i hope it's not the same fuse as the driver window, because that one is still working and that would mean. . . . .
  2. Jun 15, 2011 at 1:05 PM
    wiscdave
    wiscdave Lets Do It!
    Northern Wisconsin
    Tundra Rock Warrior
    Past ride - 3" OME 885s&Shocks/ TSB 1.5AAL/ AX184 Rims 285 Firestone destination ATs/ 2 Shallow mount P310s in Supercrew Box - Punch 601s, Beefed up Hunter Brush guard, Tint, Fog light mod, AFE Drop in, AC and Fog light mods, scangauge
    Might be stupid but did you accidentally lock the window switch?
  3. Jun 15, 2011 at 1:13 PM
    dexterdog
    dexterdog My pee parts itch
    Oly WA
    2012 F150
    usually windows aren't separated on different fuses so I wouldn't think a fuse is your issue. Do you hear the motor at all when you push the button?
  4. Jun 15, 2011 at 1:19 PM
    BradleyScottETC
    BradleyScottETC Class IV Category 8 Elite VIP Member (Only)
    Bradley
    Lake County, FL
    10 4.0 AC 4x4
    Your best bet is going to be to remove the door panel and begin troubleshooting. I'd start with unbolting the assembly and lowering the window manually to see if you've jammed or lodged it somehow. Next, I would disconnect and ohm the window motor.
  5. Jun 15, 2011 at 6:18 PM
    azchris
    azchris Well-Known Member
    Phoenix
    2013 Magnetic Grey Dbl Cab 4x4 TRD OffRoad
    Click sig for build thread
    Yep, all the windows have different fuses. They're in the box below the driver's side A/C vent, Double Cabs have 4 and Access Cabs have 2. They're labelled so you can try switching them and see if the window works then.
  6. Jun 15, 2011 at 6:26 PM
    azchris
    Phoenix
    Took a picture of the fuses:
    P FR = Passenger Front
    P RR = Passenger Rear
    D FR = Driver Front
    D RR = Driver Rear
  7. Jun 16, 2011 at 6:18 AM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    Open the door, put one hand on inside and the other on the outside(squeeze), with someone else working the button, pull the glass down, carefully.
  8. Jun 16, 2011 at 7:04 AM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
  9. Jun 16, 2011 at 8:57 AM
    aficianado
    aficianado Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR
    back to bone stock.
    this is always the best first step. dont force anything.
  10. Jun 16, 2011 at 10:53 PM
    Hard Taco2
    British Columbia
    06 TDR Off Road
    Thanks from a dumb old guy to you younger smarter guys. Great ideas, but my neighbour solved the problem, as the first replier said: the lock out button somehow got pressed! Didn't know what that button was, despite the clear drawing of a window! My wife said she had one of those buttons on her Mazda3 and didn't know what it was either, but she's got ten years fewer excuses. I'm discovering many things about age as I age! Thanks all.
  11. Jun 17, 2011 at 4:14 AM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    :laughing:
    Got to love those simple fixes.
  12. Jun 17, 2011 at 4:38 AM
    fletch aka
    fletch aka www.BeLikeBrit.org
    Gary
    Left Coast
    09 Magnetic Gray TRD OffRoad
    TRD cat back exhaust, TRD Cold Air Intake, differential breather mod' Hellwig rear sway bar, 16x8 TRD Ivan Stewart's, Michelin LTX A/T2, DTRL Stealth Mode Mod, custom "Texas Edition" shift knob, Sock's "Classic" bedside decals, MetalMiller custom grill emblem, 20% front tinted windows, tinted taillights, Viper alarm, ScanGauge II, Flyzeye Designs V2W Tacoma Interior LED lighting, de-mud flapped, de-badged, extra D-rings under bed bolts, WeatherTech ED floor mats, G4 Elite Fold a Cover ,Toyota bed mat, tailgate theft deterrent device and absolutely no plasti-dip!
    This ^^
  13. Jun 17, 2011 at 4:39 AM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    ^^ Should read the whole thread. (3 posts up)
    :p
  14. Aug 4, 2012 at 1:53 PM
    Taco-NB
    Taco-NB MMMMM Taco's
    New Brunswick
    '09 4X4 SR5 Access Cab V6 - Black Sand Pearl
    Damn .... I just did the same thing. I pressed the freekin' window lock while I was installing my brake controller. I was thinking .... how the heck did I screw up the passenger window just installing a brake controller!!!! I figured I must have accidentally pulled out a wire. I was freeking out and figured it was going to cost me a fortune!!!!! Did a quick search and found this thread. Feel like an idiot but the window is working and my trailer break is working too!!!
    I wonder how many people show up at the dealership with this problem LOL.
    Cheers. :D
