Patrick's Samurai Build
Discussion in 'Trail Toys' started by SMKYTXN, Jan 7, 2019.
  1. Feb 16, 2019 at 1:27 PM
    SMKYTXN
    SMKYTXN [OP] If it can't be overdone it's not worth doing Vendor
    Nathan
    Houston
    11, 4dr, TRD Sport, 6sp
    DCFB
    With the uptravel in the rear it's become obvious that the rear is going to have to be doved. The back half of the cage will be reworked as well. So, to make life a little easier the back half of the tub got the chop.
    With the rear tub gone it was time to knock out the rear frame.
    Photo Feb 07, 1 26 48 PM.jpg Photo Feb 07, 1 26 52 PM.jpg Photo Feb 07, 1 26 55 PM.jpg Photo Feb 07, 3 41 31 PM.jpg Photo Feb 07, 4 13 03 PM.jpg Photo Feb 07, 4 13 10 PM.jpg Photo Feb 07, 4 13 16 PM.jpg Photo Feb 08, 8 48 38 PM.jpg
    Slashaar and bigmw like this.
  2. Feb 16, 2019 at 1:28 PM
    SMKYTXN
    Nathan
    Houston
    DCFB
    I knocked out the tierods today. The ram is behind the steering arm mount which gave me a nearly perpendicular tierod at full lock. I haven't had any issues with the tierod going negative on my previous build, but this should result in less stress on the steering arm.
    Photo Feb 09, 1 21 10 PM.jpg Photo Feb 09, 1 21 16 PM.jpg Photo Feb 09, 1 21 20 PM.jpg Photo Feb 09, 1 22 07 PM.jpg Photo Feb 09, 1 22 10 PM.jpg Photo Feb 09, 1 22 15 PM.jpg Photo Feb 09, 1 22 23 PM.jpg
  3. Feb 16, 2019 at 1:29 PM
    SMKYTXN
    Nathan
    Houston
    DCFB
    With the tub out of the way and the new tires mounted it was high time to see what she was going to look like. biggrin_127035e842e5dd48052fb9139f75c20526cfff9a.gif
    Skyway, Slashaar and bigmw like this.
  4. Feb 16, 2019 at 1:30 PM
    SMKYTXN
    Nathan
    Houston
    DCFB
    The front frame plates are in. With the added stiffness from the front clip that's coming the frame isn't going to go anywhere.
    Photo Feb 11, 2 12 32 PM.jpg Photo Feb 11, 2 12 37 PM.jpg Photo Feb 11, 4 06 18 PM.jpg Photo Feb 11, 4 06 24 PM.jpg
  5. Feb 16, 2019 at 1:32 PM
    SMKYTXN
    Nathan
    Houston
    DCFB
    I dropped the front axle while I worked on the frame plates so I started welding out the truss. In order not to warp anything I had three different areas to weld on through the day. Both sides of the frame and the truss.
  6. Feb 16, 2019 at 1:33 PM
    SMKYTXN
    Nathan
    Houston
    DCFB
    Now that I have the front frame plates in I can knock out the new motor mounts. I don't know about you, but I like to use what I have laying around the shop. So the cross member mount kit that's been sitting on the shelf got used.
    Yes the oil filter will come out just fine and I can still get an impact on the bolt for the bushing.
    Photo Feb 13, 11 21 10 AM.jpg Photo Feb 13, 11 21 14 AM.jpg Photo Feb 13, 11 26 10 AM.jpg Photo Feb 13, 11 26 23 AM.jpg Photo Feb 13, 12 11 46 PM.jpg Photo Feb 13, 4 22 54 PM.jpg Photo Feb 13, 4 23 19 PM.jpg
  7. Feb 16, 2019 at 1:34 PM
    SMKYTXN
    Nathan
    Houston
    DCFB
    The shock towers are in and the ruffstuff axle mounts are on. So the back end is pretty much wrapped up at this point, minus some bump stops.
    Photo Feb 13, 7 20 02 PM.jpg Photo Feb 13, 7 20 07 PM.jpg Photo Feb 13, 7 20 13 PM.jpg Photo Feb 13, 8 02 52 PM.jpg Photo Feb 13, 8 03 00 PM.jpg Photo Feb 14, 12 40 50 PM.jpg
  8. Feb 16, 2019 at 1:35 PM
    SMKYTXN
    Nathan
    Houston
    DCFB
    What do you guys think of the paint color?
    Photo Feb 14, 12 24 35 PM.jpg Photo Feb 14, 12 24 42 PM.jpg Photo Feb 14, 12 40 37 PM.jpg
  9. Feb 26, 2019 at 2:03 PM
    Slashaar
    Slashaar Trail Limo Supreme & Certified Hole Massager
    Josh
    Kansas City, MO
    2015 Tacoma TRD-Sport DC LB
    Coastal HC Front, 6112s+650lb King Coils, JD 62 Swap + 14" Fox 2.0s
    I can dig it! :thumbsup:
    Looking good!:headbang:
    SMKYTXN[QUOTED][OP] likes this.
  10. Feb 28, 2019 at 8:02 AM
    SMKYTXN
    Nathan
    Houston
    DCFB
    I wasn't going to pull the tub, but it sure does make welding out the subframe easier.
    Photo Feb 18, 11 52 32 AM.jpg Photo Feb 18, 11 52 42 AM.jpg Photo Feb 18, 9 37 27 PM.jpg Photo Feb 18, 9 37 45 PM.jpg Photo Feb 18, 9 37 20 PM.jpg
    Slashaar likes this.
  11. Feb 28, 2019 at 8:03 AM
    SMKYTXN
    Nathan
    Houston
    DCFB
    And to make life even easier the drivetrain came out. I built a new transfercase cross member above the belly before pulling everything out. I'll get some finished pictures of that this week.
    Photo Feb 18, 9 30 41 PM.jpg Photo Feb 18, 9 30 46 PM.jpg Photo Feb 18, 9 37 56 PM.jpg Photo Feb 18, 9 38 02 PM.jpg Photo Feb 18, 9 38 08 PM.jpg
    Bigdaddy4760 and Slashaar like this.
  12. Feb 28, 2019 at 8:04 AM
    SMKYTXN
    Nathan
    Houston
    DCFB
    Flipping the frame to weld the bottom of the subframe sure was nice. I also added an additional brace on the sliders. The front link mounts will be tied into the middle slider tube this week.
    Photo Feb 19, 1 08 53 PM.jpg Photo Feb 19, 5 10 47 PM.jpg Photo Feb 20, 10 10 17 AM.jpg Photo Feb 20, 12 43 06 PM.jpg
  13. Feb 28, 2019 at 8:05 AM
    BamaTaco56
    BamaTaco56 Well-Known Member
    Trey
  14. Feb 28, 2019 at 8:06 AM
    SMKYTXN
    Nathan
    Houston
    DCFB
    She's officially a roller. I was able to flex her out a bit and confirm that the links work the way I expected them too. Of course the front end isn't going to droop out as much as the pictures show, but it was fun to do it anyways.
  15. Feb 28, 2019 at 8:19 AM
    #35
    JBTacoma
    JBTacoma Well-Known Member
    Jeff
    Cullman Alabama
    2000 SR5, 2003 Double Cab and a Suzuki Samurai
    He is building a tank :eek: :thumbsup:
    SMKYTXN[OP] and Slashaar like this.
  16. Feb 28, 2019 at 8:27 AM
    #36
    Rons01TRD
    Rons01TRD Well-Known Member
    Ron
    Virginia Beach, VA
    2007 4Runner 4WD
    The work looks awesome, just wondering if the motor has enough power to move that tank?o_O
  17. Feb 28, 2019 at 8:49 AM
    #37
    Rob Daman
    Rob Daman The Taco Formerly Known as Hard Shell Taco
    Rob
    So Cal
    17 OR 6MT
    a lot
    that's a cool build. I wish I could fabricate.
  18. Feb 28, 2019 at 8:51 AM
    #38
    JBTacoma
    Jeff
    Cullman Alabama
    That crawl box will move it
  19. Feb 28, 2019 at 7:45 PM
    #39
    SMKYTXN
    Nathan
    Houston
    DCFB
    There's a hairdryer going on the little 1.6 to help out with that, but the dual cases will move her just fine.
    JBTacoma[QUOTED] and Slashaar like this.
  20. Mar 3, 2019 at 10:38 AM
    #40
    SMKYTXN
    Nathan
    Houston
    DCFB
    I rolled her outside to see what the grey really looked like. I'm digging the color.
    The front driveshaft will ride on a carrier bearing to clear the new belly. Even without the belly there it would have needed a carrier bearing. That's a long ways from the front output to the axle.
    The driveshaft will just clear the lower at full bump.
    Photo Feb 26, 12 28 51 PM.jpg Photo Feb 26, 12 31 06 PM.jpg Photo Feb 26, 12 34 01 PM.jpg
    I put the tub back on so I could start laying out the front clip. First things first though, that hood is way too wide for the tires and travel.
    Photo Feb 27, 10 42 40 AM.jpg Photo Feb 27, 10 42 57 AM.jpg Photo Feb 27, 11 15 06 AM.jpg
    bdbrown and Slashaar like this.
