Payload increase?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by FreidTaco, Dec 27, 2011.
  1. Dec 27, 2011 at 2:21 PM
    FreidTaco
    FreidTaco [OP] boost
    jeff
    Panhandle of Wyoming
    06 Tacoma TRD OffRoad SR5
    URD Stage 3 SC. 35" duratracs LT
    So i am deciding what is better to pull something home with. Our 2007 chevrolet silverado (automatic) or my 2006 tacoma with a Toytec 2" AAL (6spd manual)? Does anyone know the the payload increase with my AAL?
  2. Dec 27, 2011 at 2:23 PM
    Jdaniel1274
    Jdaniel1274 Well-Known Member
    Daniel
    Orange County, Ca
    01 DC TRD 4X4
    PIAA lights, OMD leaf spring mod, magna flow muffler, oil filter relocation kit
    Silverado!
  3. Dec 27, 2011 at 2:25 PM
    FreidTaco
    jeff
    Isn't that the same as an increase?
  4. Dec 27, 2011 at 2:28 PM
    OZ-T
    OZ-T You are going backwards
    Peter North
    British Columbia
    X2
  5. Dec 27, 2011 at 2:29 PM
    FreidTaco
    jeff
    Well my decision comes into play because the tongue weight is 1,200lbs for what i will be pulling.
  6. Dec 27, 2011 at 2:30 PM
    Defined
    Defined Well-Known Member
    mike
    southern california
    silverado for sure
  7. Dec 27, 2011 at 2:39 PM
    FreidTaco
    jeff
    Have you ever seen the "silverado squat"? That wonderfully luxurious ride squats like a son of a gun with any sort of load at all. When compared to my tacoma, my tacoma hardly squats at all.
  8. Dec 27, 2011 at 3:02 PM
    mattg43
    mattg43 Well-Known Member
    Texas
    08 Prerunner SR5 DC
    SwingCase, driver side. PVC Bike rack. Aftermarket stereo.
    If you are pulling something with a 1200lb tongue weight, you need to rent a bigger truck than a half ton with a class III hitch (silvarado). A tacoma with a class III is not going to cut it either.
  9. Dec 27, 2011 at 7:27 PM
    landphil
    landphil Fish are FOOD, not friends!
    BC, Canada
    RIP 2006 Tacoma DCSB
    Tundra 5.7 mod
    This would be the correct answer. If the trailer is loaded correctly with a 1200 lb tongue weight it will gross 12,000 lbs, way far over and above what either of your options can handle. Borrow, beg, or rent a one ton with a WD hitch, it's not worth killing your truck, yourself, or someone else over.
  10. Dec 27, 2011 at 8:57 PM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    He hasn't listed what the gross trailer weight is yet. Odds are, the trailer weighs too much for either truck.
  11. Dec 27, 2011 at 9:00 PM
    jflan
    jflan Well-Known Member
    Vancouver, WA
    09 Access 4x4 2.7L manual SR5
    SnugTop SuperSport Sportsman keyless cap Weathertech mats - OEM skidplate - OEM hitch
    :eek:
  12. Dec 27, 2011 at 9:07 PM
    GuapOh
    GuapOh Well-Known Member
    Nor Cal
    2011 SR5 4x4 MT
    Skid Plate, Hood Protector, Wheel Locks, Snugtop XV, Yakima Rack, Weathertechs, Sick Speed Shifter, Avid Bumper, Avid Sliders, Bilstien 5100's, TSB Spring packs
    Having owned a 5.3 Z71 Silverado, I can attest that the Chevy will pull a whole lot more than a Taco.
  13. Dec 27, 2011 at 9:10 PM
    MonkeyProof
    MonkeyProof Power Top
    SoCal- SGV
    :eek::eek:
    how do you plan on stopping!!!
    i often tow my rockcrawler and i have trouble stopping, even with trailer brakes..and thats being around the 500lb tongue limit
  14. Dec 28, 2011 at 12:47 AM
    FreidTaco
    jeff
    And who said that the thing I would be pulling is even a trailer? People jumping to conclusions. Tisk. Tisk. The weight is only 7,650 lbs.
    Its a grain cart. http://www.jm-inc.com/specifications/grain_cart_spec_750-16.html This one, to be precise.
  15. Dec 28, 2011 at 12:50 AM
    S.B.
    S.B. Well-Known Member
    Sean
    San Diego
    15 Taco
    LT, Glass, CBI Front bumper, NWTI Rear bumper, 35s
    isn't that over the limits of the chevy also? It is definatly way too much for the taco for sure.
  16. Dec 28, 2011 at 12:54 AM
    FreidTaco
    jeff
    And top speed with one of these bad boys is about 35 before they get a lope going.
  17. Dec 28, 2011 at 12:54 AM
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    BSP '10 4x4 TRD Off-Road DC
    See build thread in signature
    Poorly designed trailer. That said, I'm sure the taco will pull it but it's over the limit. No matter what vehicle you use, slow down and use extra breaking distance for sure.
  18. Dec 28, 2011 at 2:43 AM
    2008taco
    2008taco Well-Known Member
    chris
    san diego
    I had 1200 pounds of concrete in my bed and was an inch off my bumpstops. That was WITH and AAL and balanced on all four wheels. That much weight on the back of either vehicle will more than likely bottom out the suspension and remove way too much weight from the front of the vehicle to drive home safely.
  19. Dec 28, 2011 at 2:59 AM
    skytower
    Dave
    virginia
    08 Tacoma 4x4
    The legal limit for a truck pulling any trailer, in most states, is 1000lbs without trailer brakes.
    I don't care what you are pulling. 7600 will push you through whatever you are trying to stop fast for. I have pulled fully loaded hay wagons with a gmc 3500 and a chevy 1500. The gmc handled it better than the chevy, but neither would stop on a dime. The chevy was overloaded, but it was necessary.
    Leave the big stuff for the one ton trucks. That's that they are made for. Anything smaller, and you will either find a ditch, or the middle of trouble.
    Get a bigger truck!
  20. Dec 28, 2011 at 3:04 AM
    skytower
    Dave
    virginia
    08 Tacoma 4x4
    Shit, forget everything I have posted on this, you need a much bigger truck!
    Did you read the specs? Tongue weight loaded is 2700 lbs. You need a friggin tractor; I forget which class it is, but you're looking at a 4500+ truck for that load.
