PcBuilder's 2014 Honda CRF250L Build
Discussion in 'Other Builds' started by PcBuilder14, Jun 28, 2014.
  1. Sep 7, 2014 at 9:11 AM
    #541
    joshipps
    joshipps Well-Known Member
    Josh
    Wyoming
    95 Tacoma 4x4
    Sick dent
    That should be a nice setup indeed, the torque difference will be noticeable thats for sure. I heard somewhere that changing the front sprocket down 1 tooth is similar to knocking 3-4 teeth off the rear. I bought my bike with a 14/51 setup and i switched it to 13/53 which was a stump puller. 13/51 is purrrrrfect. Plenty of torque :burnrubber:
  2. Sep 7, 2014 at 12:31 PM
    #542
    Sacrifice
    Sacrifice Motorcycle Goon
    KS
    DCSB OR 4X4 LT
    Pelfreybilt Front Bumper,BAMF sliders, Airflow Snorkel,Mini D2S Retrofits, ADS Rear Shocks, Deaver U402 Leafsprings, 35s, AllPro +2LT
    1 tooth down is the same as 3 up in the rear. Motomummy has a good faq about sprockets and chains that id suggest anyone to read. I'm tempted to do -1/+2 on my cbr sometime soon.
  3. Sep 7, 2014 at 12:40 PM
    #543
    t4daddy
    t4daddy Well-Known Member
    North Alabama
    2008 PreRunner Double Cab
    Depends on the ratio from front to rear. But that's a good rule of thumb.
  4. Sep 7, 2014 at 5:55 PM
    #544
    joshipps
    Josh
    Wyoming
    95 Tacoma 4x4
    Sick dent
    Yup you're right, i was still half asleep when i was posting lol
    I intended to say -1 = +3
    Not -1 = -3
  5. Sep 7, 2014 at 6:45 PM
    #545
    t4daddy
    North Alabama
    Your above gearing ratios are closer to 1f=4r. Again, it depends on your ratios.
    14/51= one tooth front equals 3.64 teeth rear
    13/53= one tooth front equals 4.07 teeth rear
    13/51= one tooth front equals 3.92 teeth rear
  6. Sep 7, 2014 at 9:37 PM
    #546
    PcBuilder14
    PcBuilder14 [OP] Well-Known Member
    Brent
    Nor Cal
    2018 Tacoma TRD Off Road 4x4
    Gonna change up the tuning some. Found some recommended settings from a guy that is apparently the end all be all person when it comes to the EJK tuner and these bikes.
    Interested to see if I can push more out of this thing, but I may lose my low backfiring sound when engine braking that I like so much... Haha :(
    The more I modify this thing the more I want to get the big bore kit in the future... :anonymous:
    Either that or buy a WR450F and convert it once this thing's paid off. :notsure:
  7. Sep 7, 2014 at 9:45 PM
    #547
    AR15xAR10
    2013 TRD Sport 4x4 V6 ACLBFTMFW
    Trade up once its paid off
  8. Sep 7, 2014 at 9:48 PM
    #548
    PcBuilder14
    Brent
    Nor Cal
    Yeah, we'll see.
    I should have it paid off by July.
    Then I'll either keep it until I get the WR450F/CRF450R I want street legal, or keep it so the gf has a bike.
  9. Sep 8, 2014 at 3:07 AM
    #549
    t4daddy
    North Alabama
    I'm a Honda guy but, the WR makes a better street conversion because it uses stainless valves, the CRF uses titanium (so does the YZF) that are not suited for constant RPMs, like cruising the highways. Check in over on ThumperTalk.com and read till your hearts content.
  10. Sep 8, 2014 at 4:02 AM
    #550
    PcBuilder14
    Brent
    Nor Cal
    Good to know...
    I'll definitely be reading up when the time comes to make a purchase.
    WR's also have better aftermarket support, also cheaper if I decide to start with a new bike :spy:
  11. Sep 19, 2014 at 10:40 PM
    #551
    PcBuilder14
    Brent
    Nor Cal
    Got the 42T rear sprocket thrown on today.
    Was expecting a loss of top-end. But I can get to 85 much quicker/easier now.
    Makes wheelies slightly better too :D
  12. Sep 19, 2014 at 11:10 PM
    #552
    AR15xAR10
    Do we have video proof of your "wheelies" ?
  13. Sep 19, 2014 at 11:13 PM
    #553
    PcBuilder14
    Brent
    Nor Cal
    Nope.
    By wheelies I mean getting the tire up over a foot off the ground and then coming back down. Not holding it out.
  14. Sep 19, 2014 at 11:16 PM
    #554
    AR15xAR10
    Not to be a dick, but i didn't expet much more than that. :)
    You think i jumped on a bicycle and could wheelie 1-5th gear all of the sudden? Naw bro. Couldn't even.
  15. Sep 19, 2014 at 11:18 PM
    #555
    PcBuilder14
    Brent
    Nor Cal
    I'm not expecting to be a wheelie pro either. Especially with so little miles under my belt. So not exactly sure what you're getting at haha :notsure:
    The bike's more than capable enough to wheelie in 1st and 2nd, I just have to get over my fear and throttle out. Once I get that out of the way I'll start shifting up.
  16. Sep 19, 2014 at 11:21 PM
    #556
    AR15xAR10
    I mean I didn't figure you would be doing 12oclock wheelies and chasers all the way to 4th gear....
    Balance point is also tricky esspecially with something much so heavier tham a bicycle :eek:
  17. Sep 19, 2014 at 11:24 PM
    #557
    PcBuilder14
    Brent
    Nor Cal
    Oh definitely. I'd love to at some point, but I don't see this bike being able to hold a wheelie past 3rd.
    I still haven't found a good place to practice, only empty roads/areas are dirt which doesn't work haha
    I've come close to my balance point once, it's scary when you feel it haha
    I tend to forget to scoot back on the seat before I try to wheelie :anonymous:
  18. Sep 27, 2014 at 2:10 PM
    #558
    PcBuilder14
    Brent
    Nor Cal
    Bent my brake lever all the way back... Haha
    Not being able to use your rear brakes on a ride definitely makes you realize how often you use them.
  19. Oct 10, 2014 at 8:34 PM
    #559
    PcBuilder14
    Brent
    Nor Cal
    Got the Pro Taper bars and pillow top grips installed today.
    Had to get new bars because the bike got knocked over when the forks were locked. Bent the oem bars bad enough that it chipped the black coating and caused stress cracks in the bars....
    Once I get the hand guards re-installed tomorrow I'm hoping to do a little riding...
    Also had to replace the rear brake pedal. Gave it some gas to get over a log and on the other side was a stump. Came in a little too hot and it bent it back pretty good... Haha
  20. Oct 10, 2014 at 8:41 PM
    #560
    AR15xAR10
    Damn dude, you've been straight reckless on that hoe
