PCV Hose Question
Discussion in '1st Gen. Tacomas (1995-2004)' started by Swivot, Aug 16, 2017.
  1. Aug 16, 2017 at 3:24 PM
    Swivot
    Swivot [OP] Well-Known Member
    I am in the middle of my PCV Hose replacement. And I noticed where the grommet sits in the engine its pretty sludgy inside. Is this a problem? Should I clean it out before i put the new grommet and hose to the hole? Or is it supposed to be a bit dirty and sludgy in there? Thanks!
    See Pic...
  2. Aug 17, 2017 at 12:17 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    I am guessing you just bought this truck !!
    I don`t know at this point how much cleaning will help .
    Mine just has a little oil
  3. Aug 17, 2017 at 7:42 AM
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    95 extended cab sr5
    cxr turbo, fic6, methanol injection, king coilovers, jba uca, skyjacker leafs, rear 12" 5125s, no-slip rear locker, 35" grabber x3, magnaflow muffler, retrofit headlights, trans cooler, bed lined exterior, etc...
    dear god has the oil been changed within the last 10 year?
  4. Aug 17, 2017 at 9:24 AM
    christsay
    christsay Well-Known Member
    chris
    Austin, TX / Santa Fe, NM
    2021 Army Green DCLB TRD 4x4
    JB Grand Raid Evo XXL mounted on an Alu-Cab. 5.29 gears.
    If you are going to clean it you are going to want to pull the valve cover. What you are looking at is the back of "windage tray" mounted to the valve cover.
    -chris
  5. Aug 17, 2017 at 3:24 PM
    Wyoming09
    New Tripoli Pa
    Super Springs
    Looking at that again it reminds me of what you got mixing the Early Synthetic oils with Regular oils
  6. Aug 21, 2017 at 3:03 PM
    Swivot
  7. Aug 21, 2017 at 3:05 PM
    Swivot
    Ok thanks. Yeah I just bought this one 5 months ago. I actually just changed the oil 4000k miles ago. And I used Synthetic Blend Valvoline to change the oil.
