PDF template for splash guard / fender liner thingies
Discussion in '1st Gen. Tacomas (1995-2004)' started by cazinpa, Feb 26, 2020.
  1. Feb 26, 2020 at 6:17 AM
    cazinpa
    cazinpa [OP] Well-Known Member
    Andy
    Lancaster, PA
    '96 Tacoma
    A few tweaks
    A while back I made new inner fender liner gasket things because mine were pretty bad.
    I posted a template on my build thread, but no one ever goes there so I figured I should start a post here.
    I drew in CAD, printed out and tested with some foam underlayment stuff I had in the basement. After about 5 revisions, I came up with this design. It tucks in a littlecloser than the factory ones did - also extends to where the washer bottle used to be on the passenger side. If you still have the factory washer bottle you simply trim off the front.
    Attached is a zip file with all of the PDFs. You can print 1:1 on 8-1/2 x 11 sheets of paper and tape together to get a full sized template. CAD drawing also attached if you would like to build on my work.
    I found a sheet of rubber at the hardware store and cut them from that. It's held up fine for a few years now.
    Would love feedback if anyone tries it.
    grambo911, HacimXD, treyus30 and 21 others like this.
  2. Feb 26, 2020 at 7:30 AM
    billybop90
    billybop90 Well-Known Member
    Bill
    Black Hills SD
    1996 Taco, 2.7, 4WD, 5 spd
    Thats really cool, thank you.
    Just got the green beastie running again this month and this was just another item that needed to be serviced/replaced. Hopefully within the next 2/3 weeks I should have this done and will post results.
    cazinpa[OP] and cruiserguy like this.
  3. Feb 26, 2020 at 7:30 AM
    Icon_Adrian
    Icon_Adrian Well-Known Member Vendor
    Adrian
    Riverside CA
    2004 Tacoma Pre-Runner
    Icon Bypasses & Coilovers Long Travel Front & Rear Supercharged 3.4L
  4. Feb 26, 2020 at 9:56 AM
    2004Taco
    2004Taco Financially Irresponsible
    Lou
    California
    04 Double Cab PreRunner SR5 TRD
  5. Feb 26, 2020 at 10:29 AM
    cazinpa
    Andy
    Lancaster, PA
    '96 Tacoma
    A few tweaks
  6. Feb 26, 2020 at 1:58 PM
    Actionjackson
    Actionjackson Well-Known Member
    Jack
    MA
    2004 Tacoma
    I got a set from rad rubber. All started ok but about 2 years later, they are all cracked up and falling apart. If you are gonna make these yourself, use some good quality epdm rubber or I once made a set out of PVC roofing membrane and they seemed to last. It is really important to have these in the rust belt......
    GQ7227 and tacoma_ca like this.
  7. Feb 26, 2020 at 3:50 PM
    wolfgang123
    wolfgang123 Well-Known Member
    Skyler
    Charlotte, NC
    1997 TACOMA - 4x4
    s
    same
  8. Feb 26, 2020 at 10:18 PM
    Tacotimer
    Tacotimer Shade tree mechanic in training
    Harry
    OR
    01 DC SR5 4x4
    Hey Thanks cazinpa! This is great! I wanted to make a template myself but I've got missing chunks in my splash guards. I'm gonna give your template a try. I'm hoping the pattern is the same for an 01 Taco.
    cazinpa[OP] likes this.
  9. Feb 26, 2020 at 11:57 PM
    CrippledOldMan
    CrippledOldMan Well-Known Member
    David
    Salisbury North Carolina
    2003 TRD Crew Cab
    None
    does anyone know the part number for the fastners. I've looked at the usual auto parts stores, and they don't have them.
  10. Feb 27, 2020 at 1:41 AM
    cazinpa
    Andy
    Lancaster, PA
    '96 Tacoma
    A few tweaks
  11. Feb 27, 2020 at 5:35 AM
    4xdog
    4xdog Well-Known Member
    Santa Fe, NM
    03 DC TRD OR, 15 DC TRD OR, 08 RX350, 62 TR3B
    I bought a box of generic ones a year and a half ago that have held up perfectly since then. I'm home early next week and will edit this post with details then.
    The original nylon retainers for the fender seals are Toyota 90080-46327, I believe. I got a set of fifty generic ones by Auveco for $9 from Amazon (vendor clipsandfasteners) a couple of years ago and they worked perfectly.
    Hamer95USA and cazinpa[OP] like this.
  12. Feb 27, 2020 at 10:45 AM
    tacoma_ca
    tacoma_ca Well-Known Member
    23 Taco OR; ̶0̶4̶ ̶4̶X̶4̶ ̶T̶a̶c̶o̶ ̶S̶R̶5̶; ̶9̶4̶ ̶4̶X̶4̶ ̶P̶i̶c̶k̶u̶p̶; ̶9̶3̶ ̶4̶-̶R̶u̶n̶n̶e̶r̶ ̶S̶R̶5̶
    I like these ones with a larger diameter head, they pop in perfectly
  13. Feb 28, 2020 at 1:55 PM
    OneWheelPeel
    OneWheelPeel Well-Known Member
    Phoenix, AZ
    Oh these are money, thank you OP for freely sharing!
    I'll have to find the right type of rubber now.
  14. Mar 1, 2020 at 3:18 PM
    1997tacomav6
    Denver
    Any links for good quality rubber sheets?
    Or stores with makers name.
    Don’t want the thin layer stuff that tears easily.
  15. Mar 1, 2020 at 3:22 PM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    I was looking at this, haven't tried it yet.
    https://www.amazon.com/dp/B01CGY40U...olid=1SGVDF9Q296E9&psc=1&ref_=lv_ov_lig_dp_it
    1997tacomav6[QUOTED] likes this.
  16. Mar 1, 2020 at 3:41 PM
    1997tacomav6
    Denver
    If the sheets of paper are 8.5” on this diagram and there are two sheets needed, the one size would have to be close to 15” tho?
  17. Mar 1, 2020 at 4:14 PM
    0xDEADBEEF
    Ah yeah, good catch. I bet they have bigger ones.
    Seems like something with a durometer in the 60-70 range would be good.
  18. Mar 1, 2020 at 5:56 PM
    GQ7227
    GQ7227 mw survivor
    J A Y
    are the OEM sized ones adequate?
  19. Mar 1, 2020 at 6:27 PM
    tacoma_ca
    Since OP was kind enough to post his .dwg file, below is a screenshot which indicates the minimum dimensions required to cut from a single rectangle. The dimension units are in inches.
  20. Mar 1, 2020 at 6:35 PM
    1997tacomav6
    Denver
    So I have king coils and struts that lift it 1.5” in the front.
    So I guessing I need a taller footprint?
