PDF template for splash guard / fender liner thingies
Discussion in '1st Gen. Tacomas (1995-2004)' started by cazinpa, Feb 26, 2020.
  1. Mar 1, 2020 at 6:37 PM
    tacoma_ca
    tacoma_ca Well-Known Member
    23 Taco OR; ̶0̶4̶ ̶4̶X̶4̶ ̶T̶a̶c̶o̶ ̶S̶R̶5̶; ̶9̶4̶ ̶4̶X̶4̶ ̶P̶i̶c̶k̶u̶p̶; ̶9̶3̶ ̶4̶-̶R̶u̶n̶n̶e̶r̶ ̶S̶R̶5̶
    Edit: Don't use EPDM.
    0xDEADBEEF likes this.
  2. Mar 1, 2020 at 6:38 PM
    tacoma_ca
    LOL I need to get a set of Kings all around so I can check into that someday.
  3. Mar 1, 2020 at 7:03 PM
    4xdog
    4xdog Well-Known Member
    Santa Fe, NM
    03 DC TRD OR, 15 DC TRD OR, 08 RX350, 62 TR3B
    That sounds *seriously* expensive, and EPDM is sensitive to oil and gasoline.
    I've bought a number of 5 x 7 sheets of checkerplate rubber from Costco for $99. I use it for workshop and garage shop flooring and to cut floormats. It's an approx 1/8" thick blend of SBR, nitrile, and natural rubber, which works well for what I've used it for but might not be best for fender seals due to likely oil and fuel sensitivity. But $2.83/ft2 is a lot better than $8.33/ft2 and checkerplate might be a nifty look.
    I also have some 1/8" rubber sheet drawer liner from Menard's that might work well. It seems to be a sheet bonded from grain-of-sand-sized pieces of recycled rubber. It's not available any longer, but there are other 1/8" sheets of drawer liner that might work, and at $0.78/ft2 the price is sure right.
  4. Mar 1, 2020 at 7:06 PM
    1997tacomav6
    Denver
  5. Mar 1, 2020 at 7:07 PM
    tacoma_ca
    Good call about EPDM being sensitive to hydrocarbons. Yep, bad idea, post edited. Thanks.
  6. Mar 1, 2020 at 10:30 PM
    jonesbt
    jonesbt Well-Known Member
    Brett
    Monroe, La
    01 3.4L DC PreRunner—>4WD
    TRD Headers TRD Supercharger Custom Cavalry Blue Paint
    I have a big roll of mass loaded vinyl. I wonder if it would hold up? Although using it for this application would seem like a waste of some really expensive material.
  7. Mar 2, 2020 at 2:57 AM
    cazinpa
    cazinpa [OP] Well-Known Member
    Andy
    Lancaster, PA
    '96 Tacoma
    A few tweaks
    Looking on eBay it seems a lot of rubber is 12" wide. Maybe I can tweak it to fit a 12" material.
  8. Mar 2, 2020 at 3:00 AM
    cazinpa
    Andy
    Lancaster, PA
    '96 Tacoma
    A few tweaks
    You shouldn't unless you have a body lift.
    If you want to try them without spending for rubber you can cut them from something else to test.
    I had a bunch of foam underlayment from a house flooring project that I used to check my dimensions.
  9. Mar 2, 2020 at 7:22 AM
    4xdog
    Santa Fe, NM
    @cazinpa, my truck is a few states away this winter which prevents me from confirming the details, but IIRC, my 2003 DC 4WD TRD has three pieces in its fender seals. A big odd-shaped one like your template on the left, and two smaller, separate, pieces on the right.
    Any idea why Toyota used a two-piece seal? A different shape between the two sides doesn't seem needed. I'm assuming your dual-fit template has been tried for both sides on later 4WD Gen 1 trucks, yes?
    Left/driver side:
    Right/passenger side:
  10. Mar 2, 2020 at 7:28 AM
    cazinpa
    Andy
    Lancaster, PA
    '96 Tacoma
    A few tweaks
    My truck is a 96. I have not tried on anything else! My passenger side was a single piece and a mirror image of the driver's side.
    4xdog likes this.
  11. Mar 2, 2020 at 8:14 AM
    Gyrkin
    Gyrkin Well-Known Member
    Wyoming
    2000 Tacoma TRD v6 5-speed
    You could use the rubber from a truck inner tube. It would be a little thin, but probably work fairly well. Less expensive than other options. Might even be able to get a used one from a tire shop for free.
  12. Mar 4, 2020 at 6:13 PM
    jdmstuff
    jdmstuff Well-Known Member
    Derrick
    Torrance, CA and Las Vegas, NV
    '18 TRD OR DCSB AT, '08 TRD Sport DCSB AT, '03 TRD 3.4l 4x4 MT Supercharged
    Thanks for this!
  13. Mar 23, 2020 at 5:42 AM
    mluckey
    mluckey Well-Known Member
    Arkansas
    2004 AND 2003 2.7L Tacoma PreRunner, AT, Ext. Cab
    billybop90 and 1997tacomav6 like this.
  14. Mar 23, 2020 at 3:17 PM
    trdracing5
    trdracing5 Well-Known Member
    Elizabeth City, NC
    2003 Tacoma SR5
    I used Dorman 963-017D clips to hold my splash shield on.
    IMO they work better than the Toyota ones plus they are readily available at any auto parts store.
    1997tacomav6 and Gyrkin like this.
