Pelfreybilt ::: Front & Rear Bumper Options ::: 2nd Gen (05-15)
Discussion in 'Pelfreybilt Off-Road' started by Pelfreybilt, Jan 20, 2015.
Thread Status:
Not open for further replies.
  1. Apr 30, 2017 at 4:11 PM
    #381
    DougsGraphics
    DougsGraphics Duck Hunter!
    Doug
    Northern New Mexico
    2015 Pyrite Mica DCSB TRD OR
    3" Revtech Level, ARB Deluxe Bull Bar front bumper with WARN 9.5XP Winch and KC Pro-Sport LED Driving Lights, black Diamond Back HD tonneau cover, 4 cameras through Entunes display with capacity for two more, LED interior lights with map lights tied to dome, Bussman auxiliary fuse/relay box with 100 amp breaker/disconnect under hood.
    I saw this post and the image of Datsik's truck and they track, but I know when I ordered the reference is now to Baja Design's S2 flush mount, which appears to have a four-hole pattern (but I can't find mounting specs or template for the flush mount design). Have you changed the cutouts? I want to pick out some lights, but could use a bit better info before I shell out $$. Thanks!
  2. May 1, 2017 at 4:25 PM
    #382
    Pelfreybilt
    Pelfreybilt [OP] Pelfreybilt Off-Road, Inc.
    Pelfreybilt
    El Cajon, California
    2014 4Runner
    ~ Pelfreybilt aluminum 4runner front bumper and Rocksliders coated by Line-X San Diego ~ Baja Designs- LED Lighting Grill with LED lightbar & 40" roof rack lightbar ~ Rigid Industries rock lights ~ Front Runner Outfitters roof rack, fridge slide & bottle opener ~ CVT Rooftop Tent & Awning ~ Goose Gear storage drawers ~ Katzkin Leather seat covers ~ Switch-Pro control kit ~ Factor 55 Flatlink ~ WARN VR8000-S Winch ~ Fuel Offroad Trophy Wheels ~ Goodyear Kevlar Tires ~ ICON Vehicle Dynamics Stage 5 kit. Appx 2.5" lift ~ ARB lockers, skid plates & 50qt Fridge ~ JL Audio custom stereo system
    The new bumper utilizes the Baja Designs S2 pro or sport flushmounts.
  3. May 20, 2017 at 10:44 PM
    #383
    santas212
    santas212 I'm on a boat!
    Georgetown, CT
    '09 DCLB, TRD Sport, Barcelona Red
    Mostly miscellaneous electronic mods.... -2 spare Electrical fuse blocks hard wired to the battery with a key on relay. -Hard Wired Radar detector over rearview mirror. -2 Dual Whelen Avenger blue LED emergency lights, one on each side of the rearview mirror. -EP911 Blue LED Light Bar & Traffic Advisor, Rear Windows. -4 corner amber strobes in stock lights. -Hardwired RF Scanner with external speaker under center console. -Huskyliner front splash guards -Fireband 2 way radio in center console. -Herculiner painted on hitch and skid plate. -Switch to power one 12v socket when truck is off. -AntiDark LED strip under hood with switch. -Timbren Rubber Springs - Rear -MBRP Offroad Cat-Back with Resonator -Duratrac's -Provisor -Color matched hood bug shield
    I wish you had a rear bumper that keeps the stock tow hitch...
  4. May 20, 2017 at 11:02 PM
    #384
    hoarder23
    hoarder23 Truck fell over
    Shay
    NJ
    15 Pyrite Mica DCSB Sport
    Scratches
    I've used the built in hitch to tow several times and trust it as much as the stock hitch. Getting rid of the stock anchor is great, less weight, more clearance and a better solution for the wiring harness.
    300AACTaco likes this.
  5. May 20, 2017 at 11:02 PM
    #385
    TXTaco13
    TXTaco13 Taco/T4R Enthusiast
    Dallas, Texas
    4TH GEN V8 4X4 T4R
    '83 CJ7 '19 MT 07
    WHY
    StOrMyThEtAcO likes this.
  6. May 20, 2017 at 11:54 PM
    #386
    santas212
    Georgetown, CT
    For starters I feel like with a flip up plate a cop in my area could take that as reason to stop me while hauling my boat. And you know I'll probably have at least a beer or two while fishing.
    I don't like that you have to reach up & under to pin it in.
    And it's not rated. I know that it's built like a brick shit house but if anything ever happened and someone found out you were towing on an unrated hitch on the highway.
    I don't off-road much. I don't need the extra clearance. I don't want to have to get a drop hitch to get me back down to normal hitch height. And the 35lbs that the stock hitch probably weighs doesn't make a difference to me.
    Don't get me wrong it's clean and it looks good. Moving the trailer plug up to the bumper is a big plus. Just not for me in it's current config.
  7. Jun 2, 2017 at 6:47 PM
    #387
    amontances
    amontances Well-Known Member
    2017 White Tacoma OR
    TRD Pipes | 18" Fuel Assault | Roof Rack | Tint | Steps | Husky Floor Liners | Bed Liner | LED Interior Lights | Swing Arm Bed Storage |
    bsm sensor support, dual swing arm, table option for both sides, extra tire on right side, high clearance overland style, jerry can options, rear camera relocation kit, mounting options for jacks/etc.
  8. Jun 3, 2017 at 8:30 AM
    #388
    The Boat Oar
    The Boat Oar Well-Known Member
    2014 Blacked Out TRD Off-Road
    Will the stock skid plate on a 2014 TRD OR still fit with this bumper installed?
  9. Jun 3, 2017 at 8:33 AM
    #389
    oni06
    oni06 Well-Known Member
    It should. The install instructions for the bumper say you may need to modify some tabs on he stock skid though.
    From the instructions "Factory skid plates may need tabs trimmed for installation. "
  10. Jun 3, 2017 at 11:14 AM
    #390
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    I had to trim off the entire front portion that curves upward. Pretty easy with a sawzall if you don't care about clean straight lines. Probably 10 minutes max with a cut off wheel to make it look nice.
  11. Jun 5, 2017 at 5:22 AM
    #391
    bnv
    bnv Boy I say, use CRAWL to sneak up on that dawg!
    Bruce
    San Diego
    2016 Access Cab TRD Off Road 4X4 Quick Sand
    Kings adj, TC UCA, Zeon 10s, PB bumper, BD 30" light bar, BD cornering lights, Line-X Grill, Wheels, Tires Duratracs, tint, gate lettering, glove box lettering, ARB compressor
    Love my new bumper! Thanks Tyler Pelfrey.
    - Pelfrey Aluminum bumper with center hoop.
    - 30 inch light bar Baja Designs S8
    - Squadron Sport Amber wide-cornering lights from Baja Designs
    - Flipster v2 plate holder hiding my new Winch - Warn Zeon 10s.
    - TRD CAI
    - TRD Skid-plate
    Good bye my old friend - Tacoma Chin.
  12. Jun 6, 2017 at 3:14 PM
    #392
    Pelfreybilt
    Pelfreybilt
    2014 4Runner
    Looking good my man!
    bnv[QUOTED] likes this.
  13. Jun 15, 2017 at 12:11 PM
    #393
    BraskaTaco
    BraskaTaco Well-Known Member
    Midwest
    2013 Tacoma TRD OR
    My rear swingout should be getting here anytime now! I've never used rotapax before.. is it just a standard mount that I'll need to get to screw into the plate on the bumper?
  14. Jun 15, 2017 at 1:41 PM
    #394
    Sleipnir
    Sleipnir Still havent found that stupid snipe
    I'm a horse
    Asgard
    Furd Rangero Ecoboost
    @Pelfreybilt can I use the warn Gen II VR12-S winch in the hybrid bumper for the 2012-2015? I've started saving up for that bumper :D
  15. Jun 16, 2017 at 9:24 AM
    #395
    imjustabill1970
    imjustabill1970 Twitter: imjustabill1970
    bill
    clarksville, tn
    2017 TRD Off Road DCSB
    SUSPENSION: Icon Stage 4 with tubular UCAs WHEELS: Black ProComp 69 TIRES: BFG KO2s at 265/75/16 Partially debadged Diaz Fabrication Model T up front
    Someday....that's the bumper for me!
    Later.
  16. Jun 23, 2017 at 6:19 PM
    #396
    shawn_free
    shawn_free Well-Known Member
    Shawn
    2016 Tacoma TRD Off Road
    Just starting
    Here's and updated front bumper pic after the LT. Love the PB Armor!
    kgarrett11, Toynado, Mtnflyer and 6 others like this.
  17. Jun 23, 2017 at 9:31 PM
    #397
    Ulysiss
    Ulysiss Well-Known Member
    Ulysiss
    La Puente, SGV
    2013 Long Bed, PreRunner, TRD Sport
    Pelfreybilt[OP] likes this.
  18. Jun 24, 2017 at 2:19 AM
    #398
    300AACTaco
    300AACTaco Well-Known Member
    Alaska
    Black '15 DCSB TRD Off Road 4x4
    ARB Old Man Emu 90000s and 60091s OME 886s, Trim Packer, Icon Tubular Uniball UCAs, CMC, Invisible Sway Bar, Dakar Rear Leaf Packs, Timbren Rear Bumpstops, All Pro U-bolt flip up kit, Method Race Wheels NV 16X8 4.5BS, Cooper ST Maxx LT285/75/16, DEPO Black Tail Lights, Weathertech Floormats, Cascadia Vehicle Tents Mt. Shasta in Earth Tone Green, Custom Green Tree Fabrication Bed Rack, N-Fab Spare Tire Bed Mount
    Alright who wants to trade their '05+ swingout bumper for my standard plate? :D
  19. Jun 24, 2017 at 10:07 PM
    #399
    300AACTaco
    Alaska
    Anybody know if you can fit a 33" spare under the bed in the factory spare tire mount with the rear standard plate? Does it free up more space since it gets rid of the factory hitch?
  20. Jun 25, 2017 at 12:18 AM
    #400
    StOrMyThEtAcO
    StOrMyThEtAcO @stormythetaco
    Cody
    CO
    18 TRD Sport mom bus
    All of them
    I don't know if it will change the front though since it's the factory cable holding it it will still probably be to close on the front side of the tire.
    No idea though just saying..
Thread Status:
