Pelfreybilt Hi-Clearance Rear Bumpers
Discussion in 'Pelfreybilt Off-Road' started by Socalduckslayer, Feb 27, 2013.
Thread Status:
Not open for further replies.
  1. Feb 27, 2013 at 11:32 AM
    Socalduckslayer
    Socalduckslayer [OP] Pelfreybilt Off-Road
    Tyler
    San Diego, Ca
    12 Tacoma
    Odds and Ends
    This is the Hi-Clearaance rear that is designed to work with a swingout. Bumpers without swingouts will be modified to be closer to the corners of the truck as the extra space for the spindles is not needed. I will post that configuration as soon as it is complete. The standard replacement rears that do not require bedside sutting will be available very soon.
    These are fully formed and welded plate. The main mounts to the frame are one piece through the bumper for ultimate strength. The main mounts are 3/8" Steel, all of the other plate components are 3/16" thick. The hidden hitch option behind the license plate is additionally supported with 2" square tubing that is 3/16" wall. The factory license plate lights are reused. Light cutouts for Rigid Flush-mounts are also optional.
    Swing outs hinges are massive 1.75" spindles with ball bearings and zerk fittings. The latch is a Synergy Suspension rotary lock that is completely fail safe. The gate is made from 1.75" x .120 Wall Tubing. The swing out automatically locks open when its fully extended using a spring lock pin. The pin rides on a stainless track to prevent corrosion and galling into steel.
    Swing out pictured is pretty standard, additional options are available at customers request.
    Base bumper 875.00
    Optional Hidden Hitch 150.00 (not rated but bombproof)
    Optional Reverse Light cutouts 50.00
    Swing out, basic starts at 450.00, includes tire carrier. Adding Nato Can holders, Rotopax mounts, etc are additional.
    Powdercoat is 150.00 for base 75.00 for swing out
  2. Feb 27, 2013 at 11:52 AM
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    Holy crap that is sexy!! Once again Tyler, you pump out an amazing product!
    ChadsPride likes this.
  3. Feb 27, 2013 at 1:07 PM
    MikeyTG
    MikeyTG Oh Herro
    Oahu
    That is a damn good looking bumper, lots of nice details really make it standout.
  4. Feb 27, 2013 at 1:10 PM
    chris5255
    chris5255 Me mber
    Renton WA
    12 Tacoma DCLB TRD Sport-'07 FJ Cruiser
    BAMF Sliders Fog light switch mod, Pelfreybilt Front bumper, Warn Zeon10 winch pinstriping for speed
  5. Feb 27, 2013 at 1:56 PM
    AZBACKCOUNTRY
    AZBACKCOUNTRY Well-Known Member
    Doug
    AZ-between the hammer and the anvil
    11' AC TRD OFF-ROAD 4x4
    Pelfreybilt front aluminum bumper,AVID off road weld on sliders, RCI Offroad IFS & transmission Skid (steel), RCI LCA skids (aluminum),upper grillcraft, relentless hi clearance bumper,OEM color matched front grill color, ARE MX camper shell, wet Okole realtree seat covers,pelfreybuilt hi lift mounts,ICON 2.5 Coil-overs extended,, ICON tubular UCA's. Allpro expo leafs, SS extended brake lines.Bilstein 110 extended rear shocks.prinsu Cabrac.dwreck pod mounts OKLED 18w cubes.Baja Designs Squadron-R Sport, LED Wide Cornering, Ambers fog/driving 20" IGGY LED Single Row bar.tepui awning,rotopax 2 gallon, TREDs and mount , 100 watt renogy solar panel.victron 20 amp Bluetooth charge controller,Pro comp wheels - cooper st maxx 285/75/16 tires. Skygear bussman fuse relay smart box. ARB 12v plug hard wired for ARB fridge. Pelfreybilt gas tank skid. Smittybilt X2O 10K winch
    Sweet bumper- that spare looks HUGH! Lol
    Az
  6. Feb 27, 2013 at 3:17 PM
    kyoung.709
    kyoung.709 Active Member
    do you ship freight to canada??????
  7. Feb 27, 2013 at 3:18 PM
    Large
    Large Red
    You should do a write up on the install, I want a HC wrap around but Idk how to cut the bed sides.. and that thing is SEKS
  8. Feb 27, 2013 at 3:22 PM
    armyoffoo
    armyoffoo Scrotie McBoogerballs
    Houston, TX
    2018 Tundra CM TRD Sport
    You're killin' me...this thing is badass!
    Time to go work the corner so I can afford this one to go with my front that I haven't finished paying for :D
  9. Feb 27, 2013 at 3:29 PM
    RelentlessFab
    RelentlessFab Eric @Relentless Fab Vendor
    Eric
    Sparks, NV
    07 AC 6mt>03 SR5 >08 Sport and 17 6MT TRD OR
    Looks pretty good. :cool:
  10. Feb 27, 2013 at 3:30 PM
    LoadedTaco
    LoadedTaco Kick A$$ Member
    Peter
    Burr Ridge Il
    2012 Red Baja
    Looks so good! I cannot wait to see the no-cut bumper!
  11. Feb 27, 2013 at 3:36 PM
    Socalduckslayer
    Tyler
    San Diego, Ca
    12 Tacoma
    Odds and Ends
    Thanks guys
    Thanks Eric, means a lot coming from you.
  12. Feb 27, 2013 at 3:41 PM
    tostidos
    tostidos Well-Known Member
    Apple Valley, CA
    07 LT 6spd
    Tyler looks bad ass! I like the spare tire mount alot!
  13. Mar 4, 2013 at 10:08 AM
    Socalduckslayer
    Tyler
    San Diego, Ca
    12 Tacoma
    Odds and Ends
    Thanks Chris, I'm really happy with the results and look forward to getting the standard, no cut version going.
  14. Mar 4, 2013 at 10:14 AM
    RockyMtnTRD
    RockyMtnTRD Wanderlust.
    Noah
    Colorado
    '11 TRD OR
    hack job
    :drool: savin my pennies ;)
  15. Mar 31, 2013 at 4:45 PM
    ckeene9
    ckeene9 Well-Known Member
    Chesterfield, VA
    '12 DCSB Supercharged 4x4 TRD Sport
    See Build Thread
    Can the swing out be ordered separately down the line?
  16. Apr 2, 2013 at 2:39 PM
    VolcomTacoma
    Jeff
    NorCal
    Yea I'm wondering about this as well...
  17. Apr 3, 2013 at 7:24 AM
    Socalduckslayer
    Tyler
    San Diego, Ca
    12 Tacoma
    Odds and Ends
    It could be ordered separately but the spindle and latch mechanism would need to be welded into the base on the first part of the order. Those are a major part of the swing out cost.
  18. Apr 3, 2013 at 7:46 AM
    VolcomTacoma
    Jeff
    NorCal
    Awwww so there's no way to have just the base bumper made..have that on the truck fr a month or a few months, then come back and have the swing out installed? Even if you have to leave a hole or something for the spindle lol
  19. Apr 3, 2013 at 11:54 AM
    Desert Drifter
    Desert Drifter Well-Known Member
    Bill
    Central Arizona
    Tacoma 4x4, SR5
    Icon MT suspension, Pelfreybuilt front bumper, Relentless skids, Avid sliders, Avid custom rack. Pelfreybilt HC Rear bumper.
    Just buy it full up, you know you want it! (I want one too, but probably without the swing-out as I can't handle the rear visibility loss of that big tire in the rear view mirror or loss of the nifty rear view camera..)
  20. Apr 5, 2013 at 6:38 PM
    ckeene9
    Chesterfield, VA
    See Build Thread
    Another question, where are you hooking your chains up when towing?
Thread Status:
