Pelfreybilt Off-Road
Discussion in 'Pelfreybilt Off-Road' started by Socalduckslayer, Apr 16, 2012.
Thread Status:
Not open for further replies.
  1. Mar 12, 2015 at 6:28 PM
    #3741
    ckeene9
    ckeene9 Well-Known Member
    Chesterfield, VA
    '12 DCSB Supercharged 4x4 TRD Sport
    See Build Thread
    Not a problem, do that all the time. I've had the truck high centered on that skid before.
  2. Mar 12, 2015 at 8:57 PM
    #3742
    squint0241
    squint0241 OVRLND
    Rick
    Tropics
    '14 DCSB/Off-Road 4X4
    Bone Stock
    Mines Aluminum and I just throw a block of wood on the lift cup to spread the load. No issues at all...
  3. Mar 13, 2015 at 7:21 AM
    #3743
    velillen
    velillen Well-Known Member
    Nick
    Wyoming
    2011 Access Cab 4x4
    I picked up two of them and have to say...they are only ok mounts. But a couple bucks makes them a lot better IMO. The rail attachment piece they send with the mount is kind of crappy. Its basically just a small rectangle that as you tighten turns to engage in the rails. Easily fixed by getting a regular T-Slot nut. I had to drill my mount hole out since I had left overs from benson-X's DIY mount plans but if you got the right side bolt and thread pattern you wouldn't need to drill. I also didn't like how the only thing holding the rotopax was the single t-nut. Pushing on the bottom of the mount you can move it and have it touch the truck bedside. not a whole lot of movement but I went ahead and got a rubber stopper and attached it to the bottom of the mount so the mount plate cant really move. Just two cheap things I added that I feel give it a much nice feel.
    You could also make them yourself. Its more or less just a rectangle piece of metal with a couple holes drilled in it. Wouldn't be hard to do
  4. Mar 13, 2015 at 4:54 PM
    #3744
    Pelfreybilt
    Pelfreybilt Pelfreybilt Off-Road, Inc.
    Pelfreybilt
    El Cajon, California
    2014 4Runner
    ~ Pelfreybilt aluminum 4runner front bumper and Rocksliders coated by Line-X San Diego ~ Baja Designs- LED Lighting Grill with LED lightbar & 40" roof rack lightbar ~ Rigid Industries rock lights ~ Front Runner Outfitters roof rack, fridge slide & bottle opener ~ CVT Rooftop Tent & Awning ~ Goose Gear storage drawers ~ Katzkin Leather seat covers ~ Switch-Pro control kit ~ Factor 55 Flatlink ~ WARN VR8000-S Winch ~ Fuel Offroad Trophy Wheels ~ Goodyear Kevlar Tires ~ ICON Vehicle Dynamics Stage 5 kit. Appx 2.5" lift ~ ARB lockers, skid plates & 50qt Fridge ~ JL Audio custom stereo system
    No issue with the fitment of the Fuse Panel on the 2012 Pro
    The battery cage is designed for stock location only.
  5. Mar 13, 2015 at 4:56 PM
    #3745
    Adamar85
    Adamar85 Well-Known Member
    Adam
    Baker City, OR
    22 Ford F350 Lariat
    The Pelfreybilt blue sea fuse panel holder fits in my 14 Offroad, it mounts around the ABS module. The battery cage is meant to fit a bigger battery in the stock location. So not sure if it would work on the other side
  6. Mar 13, 2015 at 5:59 PM
    #3746
    THE CALICO
    THE CALICO Well-Known Member
    Colton
    Nashville
    Black 2014 TRD SPORT ACCESS CAB
    Any luck Satin with the measurements I sent for the 2014 automatic fuse plate?
  7. Mar 14, 2015 at 9:25 PM
    #3747
    sawbladeduller
    sawbladeduller semi-realist
    North Cal
    '15 DCSB '98 2.7L
    fully zip tied
    Hi Tyler and Satin
    Mounted the gas skid today (non ferrous) while the tank was on empty. the skid bowed slightly when I snugged up the bolt/nuts, then I filled up with 17.75 gals.
    Not sure it bows anymore than when I first mounted it, but the tank "expands" and has full surface contact to the skid, and that is as you designed it, right? Should be no issue with that contact?
    Thanks, Rodney
  8. Mar 14, 2015 at 11:19 PM
    #3748
    Adamar85
    Adam
    Baker City, OR
    22 Ford F350 Lariat
    Best way to install is on an empty tank, otherwise you get the bow. Had to use a jack to press mine on
  9. Mar 15, 2015 at 1:16 AM
    #3749
    XPOTRON
    XPOTRON Is LIVE on the GRID.
    Stefen
    Chandler, Arizona
    IG: @ST3F3NS
    DUROBUMPS Use TRON10 for 10% Off & Free Shipping
    The day I make the switch to a Pelfreybilt Hybrid....you Sir will be responsible for my empty wallet!! Very nice :cool:
  10. Mar 15, 2015 at 6:43 AM
    #3750
    Neutral
    Neutral Well-Known Member
    Fella
    Alabama
    14 SR5, 25 SR5
    14 4.5" RCD, Pelfreybilt armour, Fox coilovers/shocks, Alcan leaf springs, 4.56 gears, 35's 25 Stock
    Repped Pelfreybilt last night... :p
  11. Mar 15, 2015 at 7:02 AM
    #3751
    JPC
    JPC Well-Known Member
    JPC
    Highlands Ranch, CO.
    2011 DC SB TRD 4X4
    5100s front & rear, 2"AAL, KMC XD wheels, Hecuules Tera Trac AT II 265/65/17 tires, ARE Color Matched Topper, Thule Roof Rack, Alpine INE-W940
    good advice, thanks
  12. Mar 16, 2015 at 3:50 AM
    #3752
    orangeglo
    orangeglo ¯\_(ツ)_/¯
    Los Angeles, CA
    2011 DCSB OR
    Make sure to come back and let us know how it goes. I've been considering trying this as well.
  13. Mar 16, 2015 at 1:40 PM
    #3753
    BabyTaco
    BabyTaco Well-Known Member
    Wyoming
    2011 RC Tacoma
    That's funny because your truck was one of the reasons I chose to go with a hybrid. :laugh:
  14. Mar 16, 2015 at 7:20 PM
    #3754
    squint0241
    squint0241 OVRLND
    Rick
    Tropics
    Bone Stock
    Rocking Pelfreybilt:cool:
  15. Mar 16, 2015 at 7:34 PM
    #3755
    FreidTaco
    FreidTaco boost
    jeff
    Panhandle of Wyoming
    06 Tacoma TRD OffRoad SR5
    URD Stage 3 SC. 35" duratracs LT
    White Bumper POWER!!!
  16. Mar 18, 2015 at 3:16 AM
    #3756
    JoseyWells
    JoseyWells Well-Known Member
    Joe
    Corona, CA
    12 prerunner
    Demello sliders, Icon ext coilovers, icon rear shocks, icons UCAs, 17" Konig Countersteer Type X, 285/70/17 Nitto Trail Grapplers
    Would there be a way to mount morimoto xb led fogs to a hybrid bumper?
    COTaco93 likes this.
  17. Mar 18, 2015 at 5:26 AM
    #3757
    XPOTRON
    Stefen
    Chandler, Arizona
    IG: @ST3F3NS
    Haha I have a lot of people tell me that! :cool: I wish my hoop was alittle taller like yours, my raptor leds are kinda hidden right behind my hoop
  18. Mar 18, 2015 at 11:19 AM
    #3758
    Pelfreybilt
    Pelfreybilt
    2014 4Runner
    [FONT=&quot]The Hybrid bumpers come standard with fog light mounting tabs. Unless the morimotos are extremely large lights there will be no issue :D
    [/FONT]
  19. Mar 18, 2015 at 11:26 AM
    #3759
    deeezy
    deeezy Well-Known Member
    Dana
    Hawaii
    2013 4x4 DC, 6 spd, TRD Sport
    King ext travel coilovers, Icon tubular UCA's Rear-King "Tundra" 2.5's, Allpro Expos, TRD cat-back, Hurst/Core short shift kit, etc...
    You would have to make some sort of "L" bracket because the XB fogs mounting screw holes are horizontal. The Pelfrey tabs on the bumper need a vertical bolt to mount.
  20. Mar 18, 2015 at 3:52 PM
    #3760
    JoseyWells
    Joe
    Corona, CA
    12 prerunner
    I guess i need to get a hybrid already so i can see how it would fit
Thread Status:
