Pelfreybilt Off-Road
Discussion in 'Pelfreybilt Off-Road' started by Socalduckslayer, Apr 16, 2012.
Thread Status:
Not open for further replies.
  1. Feb 26, 2016 at 3:36 PM
    #5081
    Karate1993
    Karate1993 Well-Known Member
    coloRADo
    '14 TRD Off-road DCSB
    @Spixelz I'm in the process of getting my X2O winch installed in my Pelfreybilt bumper as well. I saw that you said you didn't need to relocate the control box. Did you mount it on the motor of the winch? Thanks.
    Spixelz likes this.
  2. Feb 26, 2016 at 3:38 PM
    #5082
    Spixelz
    Spixelz Well-Known Member
    Jesse
    Forest Grove, Oregon
    2015 White 6spd DCSB OR
    Icon Stage 4 w/Dakar Leafs
    Yes, mount it on the motor and it will sit just perfect.
    Karate1993[QUOTED] likes this.
  3. Feb 26, 2016 at 3:43 PM
    #5083
    mwc273
    mwc273 Nothing is as it seems.
    Smittybilt shackles are fat.
  4. Feb 26, 2016 at 3:54 PM
    #5084
    deadhed61
    deadhed61 :notsure:
    Santa Barbara, Ca
    The Black Pearl
    A little lift and a little armor
    See above. From a few pages back
  5. Feb 26, 2016 at 3:55 PM
    #5085
    THE CALICO
    THE CALICO Well-Known Member
    Colton
    Nashville
    Black 2014 TRD SPORT ACCESS CAB
    The winch comes with little black brackets to mount the controller to the left of the housing. That's what I used.
    Karate1993[QUOTED] and Spixelz like this.
  6. Feb 26, 2016 at 4:00 PM
    #5086
    WormSquirts
    WormSquirts Armageddon
    Braeden
    BC
    awesome thanks so much!
  7. Feb 26, 2016 at 4:21 PM
    #5087
    Rudder
    Rudder Well-Known Member
    Robin
    Central Arkansas
    2009 01E7 Silver Streak Mica Taco DC SR5+ 4x4 Long Bed
    BackRack Cab Protector, Debadged, Vent Visors, Tinted windows JBL w/Sub, Ventura Wheels, Kumho Road Venture 2 MT 285 75R16 Tires
    Does your 05-16 Tacoma IFS Skid fit under a Draw-Tite Front Mount Trailer Hitch Receiver - Custom Fit - 2"Square Tube
    Code: 65070? There are only two Front mounted hitches available for the Taco, and the Curtis cannot be used with a skid.
  8. Feb 26, 2016 at 4:51 PM
    #5088
    Karate1993
    coloRADo
    Awesome! Thanks. Just want to make sure I have all my ducks in a row before starting the install.
  9. Feb 26, 2016 at 11:24 PM
    #5089
    goblue82
    goblue82 Well-Known Member
    The Dude Abides
    Southern California
    Click muh sig
    I won't ever let another person weld on my rig. Being a Navy Engineer I've seen plenty of Navy welders work. You're right there with them. I hate re work and I need it done right the first time. You're the SD guy. Hands down. Navy seal of approval
    Speed Freek[QUOTED] likes this.
  10. Feb 27, 2016 at 6:18 AM
    #5090
    YotaBum
    YotaBum Not So Well-Known Member
    Alex
    North Georgia
    2015 TRD Sport DCSB
    Blacked Out-887-Dakars-LR UCA-FJ Trail Team wheels-285 BFG KO2
    Started installing mine last night... Not as easy as I had read about it being!
    Did a test fit and everything looked good. So I put in my light bar and fogs and went to put it back on and realized The fogs weren't clearing the support under the headlights.
    Had to cut and fold that back like it said in the directions. Problem is that where I trimmed, is the same place where the lower headlight trim bracket is located... Going to try and drill the bracket down now.
    Next issue I have is that that the support brackets that bolt in on the back side are not lined up enough for me to get the bolt through! They are probably a good 1/4" to 1/2" off on both brackets... It's like the opening doesn't have enough room. I'll be leaving those off for the time being I guess.
    Also I am trying trying to use the factory "skid" for the time being. I removed so I would have better access to the sway bar bolts. When I went to put the skid back on, I realized that I don't have access to front hangers. Anybody else running into this problem?
  11. Feb 27, 2016 at 6:28 AM
    #5091
    greeneggsnspam
    greeneggsnspam ಠ_ಠ
    Houston, TX
    .gif
    Too poor to list anything interesting.
    Are y'all tightening up the sway bar bolts first and then trying to do the long grade 8 bolt?
  12. Feb 27, 2016 at 8:03 AM
    #5092
    THE CALICO
    Colton
    Nashville
    I had mine just setting up there when I first found it and still off. It reall looks like the adjustable slot is going the wrong direction.
  13. Feb 27, 2016 at 8:24 AM
    #5093
    Spixelz
    Jesse
    If you trim right at where the trim pieces mount under the head light and fold up what you can the fog's will still fit without moving or drilling that trim bracket. I cut and folded what I could and my lights clear. I do think the instructions could use a update for the 2012+ :)
  14. Feb 27, 2016 at 8:56 AM
    #5094
    YotaBum
    Alex
    North Georgia
    2015 TRD Sport DCSB
    I tried both ways... I got the bolt somewhat through, but then the sway bar relocate didn't want to line up with the frame holes.
    ^ This! That's exactly what I told my GF. It would be much easier if the slot was vertical and not horizontal on that end.
  15. Feb 27, 2016 at 9:00 AM
    #5095
    YotaBum
    Alex
    North Georgia
    2015 TRD Sport DCSB
    I ended up dremeling off the trim piece bracket where it bends downward. Clears the light and still holds the trim piece fine. I may use a small screw or a zip tie just to be on the safe side.
  16. Feb 27, 2016 at 9:14 AM
    #5096
    YotaBum
    Alex
    North Georgia
    2015 TRD Sport DCSB
    Finally got it on...
    52FCF5A1-8AA8-4261-81C3-9FE27543320B_zps_1200b7a8944b8a56d3fe8599fb7c13add16e016a.jpg
    Need to straighten it up a little more and figure out the support bracket, but it is good enough for now.
    Used zip ties to pull the fender liners up out of the way.
    A74E433D-CAF2-4ED2-916E-6F5F79841981_zps_fad4b19fa7d7073bf592a151a1f0793a540581d5.jpg
    Used a dremel tool to take off about a 1/4" off the rigid fog harness and the factory Toyota harness fit right in. Wrapped it up in electrical tape and zip tied up out of the way.
    Got the light bar wired, but need a new switch that fits better than the Rigid supplied switch... Probably go with an AOB one.
    83E8D7AB-EAEF-43EA-962D-4BA14411818B_zps_d902fc1b374ec0e261092e55afae7602aaf3ac76.jpg
    Wat3rdog, BenTheMan and DrFunker like this.
  17. Feb 27, 2016 at 9:21 AM
    #5097
    deadhed61
    deadhed61 :notsure:
    Santa Barbara, Ca
    The Black Pearl
    The slots should be perpendicular with the frame. If so, they are correct.
  18. Feb 27, 2016 at 9:22 AM
    #5098
    deadhed61
    deadhed61 :notsure:
    Santa Barbara, Ca
    The Black Pearl
    Looks killer :thumbsup:
    YotaBum[QUOTED] likes this.
  19. Feb 27, 2016 at 9:22 AM
    #5099
    DrFunker
    DrFunker Well-Known Member
    Looks great!
  20. Feb 27, 2016 at 10:02 AM
    #5100
    Speed Freek
    Speed Freek Tacoma Whisperer!
    Vista, Ca, Lake Havasu, Az.
    98 Tacoma V8 (LS1) swap
    LS1-T56 swap, Z06 ported heads, cam, Titanium valves, Kevlar clutch. Now building a forged stroker (383) and all the ponies! Old setup was rod-knockin on heaven's door...
    Thank you buddy! I try to give the same work I would expect if I ever let anybody touch any of my stuff. I appreciate the recommendation, it means a lot hearing this from my customers and friends.
    Now today I have to test out my own truck after building the motor and fixing the transmission.
    Not much beats a 400+hp V8 in a little first gen, lol.
    I put the long bolt through the frame and plate before I tighten anything, it will seem like its not perfectly straight, however when you tighten it down it will self-center itself.
    But to answer your question, yes, I loosely put it together and then tighten the sway bar bolts while pushing the bracket forward toward the frame and then tighten the long bolt. Or sometimes depending on fit (since all trucks have a slight variance) I'll tighten the long bolt as much as I can while still being able to get the sway bar bolts in.
    Did that just sound more confusing than helpful?? Haha
Thread Status:
