Pelfreybilt Off-Road
Discussion in 'Pelfreybilt Off-Road' started by Socalduckslayer, Apr 16, 2012.
Thread Status:
Not open for further replies.
  1. Oct 3, 2012 at 11:24 AM
    #601
    Socalduckslayer
    Socalduckslayer [OP] Pelfreybilt Off-Road
    Tyler
    San Diego, Ca
    12 Tacoma
    Odds and Ends
    Hitch and electrical are a bit close, difficult to get it all in there because of the rear bracing behind the receiver but going to try to move it out a bit, good eye. This is the prototype and it will work but these are the little things that I am sorting out as I go.
    Hi-lift cutouts are directly to the rear and they will stay that way, there is not a corner portion that will be there, its basically a 90º
    Material is A-36 Steel, 3/8" direct to the frame and all other is 3/16". Tire gate is 3" x 2" x .120" tube and a 4140 Chromolloy spindle assembly.
    The entire thing is 1 piece, bolt on sides would not cut it in my opinoion.
    The shackle mounts are one piece, extensions of the frame mounts that extend thru the face of the bumper. They have 3/4" wide tubes welded inside them that are .250" wall DOM.
  2. Oct 3, 2012 at 12:03 PM
    #602
    Desert Drifter
    Desert Drifter Well-Known Member
    Bill
    Central Arizona
    Tacoma 4x4, SR5
    Icon MT suspension, Pelfreybuilt front bumper, Relentless skids, Avid sliders, Avid custom rack. Pelfreybilt HC Rear bumper.
    I like the way Tyler thinks.
  3. Oct 3, 2012 at 12:14 PM
    #603
    Mach375
    Mach375 Habitual Violator of Wheeling Rule #2
    Sathington "Alowicious Devadander Abercrombie" Willoughby (but you can call me Mud)
    '11 DCLB 4x4 TRD Sport
    Too much to list, but enough to get me in trouble. Repeatedly.
    x2.
    Is why I'll be making him my source for all things metal.
  4. Oct 3, 2012 at 5:04 PM
    #604
    DWreck
    DWreck Famous Retrieval Vendor
    Derek
    Las Vegas, NV
    2004 Tacoma Smurf Truck
    Plasti-dip paint, TRD S/C, MCM Fab LT kit, bunches of my fab
    Looks similar to the one I just made. Looks good!
  5. Oct 4, 2012 at 10:25 AM
    #605
    Mach375
    I've been following TacoDoc1's Demello Offroad Rear Bumper Project thread because his is the absolute closest thing I've come across to what I'm envisioning for my HCRB. He *just* got it done, and is out testing it before the Mountain Rendezvous.
    I would prefer to take my business to Pelfreybilt here.
    Following the progress with TacoDoc1 has me seeing some issues I'm wondering if you've thought about?
    In particular, the tendency of HCRBs with swing-outs to crack around the pivot? One solution is to build the swing-out and everything attached to it from aluminum (which also helps with weight in general). I wonder if there are other options? Including reinforcing the bumper, maybe with extra gussets, or perhaps by "boxing" the bumper (not sure how to call it: basically, more-or-less sealing up the bumper by welding a plate on the backside), or maybe extending the pivot all the way through the bumper to the bottom?
    Another concern is total weight. Building everything from steel (HCRB + swingout + mounts for everything) is going to put an assload of tonnage as far from the axle as possible, and that's before any accessories are added (for me, I'll be adding one or two water cans, two or four fuel cans, Hi-Lift, trail tools, probably recovery bag, and a few other lightweight items).
    Just trying to help you out in design considerations. I'm not a welder or a metallugist, so I don't know the first thing about fabrication or metal properties. But I do know how to keep an eye out for possible design flaws, and also good designs. Just trying to provide constructive criticism.
  6. Oct 4, 2012 at 10:38 AM
    #606
    Mach375
    Wondering if you've thought about offering an undermount spare tire skidplate? It's not something I've seen anyone else have, and not even really sure it's something that exists at all.
    Here's my thinking: Some people will never mount their spare anywhere but under the bed, yet will still go wheeling in areas that might puncture the tire. Other people will choose to stick with the undermount to keep weight more evenly distributed (more of my angle). Still others might have some other reasoning. At any rate, keeping the spare in its stock location can put it in danger of sidewall punctures, especially if the tire mounted is large.
    The plate could be mounted with the tire via the tire's stock retraction cable. Or it could be extended out to the frame on either side, thereby adding structural integrity to the truck. It could also be mounted to a high-clearance rear bumper. If frame- or HCRB-mounted, there would need to be some kind of quick-release mechanism to access the tire without spending time turning a wrench. In all methods, there would need to be an oval notch to allow valvestem access for various wheel sizes.
    Just a thought. I could be way over-thinking the spare's vulnerability.
  7. Oct 4, 2012 at 10:41 AM
    #607
    Mach375
    (Yeah, I know. Being a bit of a post whore here. Meh.)
    You need to add yourself to the TW Vendor list. Or move/include this thread in the B/S/T section. Or something. I can never remember to find it in SoCal Regional Discussions.
  8. Oct 4, 2012 at 10:42 AM
    #608
    Leoffensive
    Leoffensive Well-Known Member
    Leo
    San Diego, CA
    2007 prerunner TRD sport
    Icon 2.5 coilovers with resi, Custom OMD rear leaf pack, Pelfreybilt IFS skid, Magnaflow muffler
    hahaha
    +1
    i think tyler might remember my spare getting jacked at truck haven lol
    definitely something to consider. but it would have to be easily and quickly removable.
  9. Oct 4, 2012 at 10:47 AM
    #609
    mike89
    mike89 Well-Known Member
    Mikey
    San Diego
    07 TRD Sport 4x4
    Radio Kenwood DNX890HD Two 10in JL 10w1s Upper control arms Donahoe Racing 2.5 adjustable front coil over's Donahoe Racing rear remote reservoir Deaver Add a leaf 33" Nitto Terra Grappler tires Custom 17" seven spoke black wheels cold air intake Throttle body spacer 3" cat back exhaust Race Radio Garmin GPS TRD seat covers TRD floor mats Drilled and slotted front brake rotors Billet front grill Custom built front off road bumper Three off-road lights Hid headlights LEDS Map Lic plate running lights dome
    X2
  10. Oct 4, 2012 at 10:55 AM
    #610
    Socalduckslayer
    Tyler
    San Diego, Ca
    12 Tacoma
    Odds and Ends
    A agree, thats out fo my control however. If some guys could help me hit up the Mods perhaps I can get moved to a more convenient location, like vendors
  11. Oct 4, 2012 at 10:56 AM
    #611
    Socalduckslayer
    Tyler
    San Diego, Ca
    12 Tacoma
    Odds and Ends
    I will put some thought into this, I like your thinking.
  12. Oct 4, 2012 at 11:00 AM
    #612
    Socalduckslayer
    Tyler
    San Diego, Ca
    12 Tacoma
    Odds and Ends
    I feel pretty confident that cracking wont be an issue. The stem is welded all the way donwn the inside of the bumper and flushes with the bottom where it is welded also. It also has locating and gusseting rings around the stem that tie into the back inside face. Weight really wont be much omore than stock, more, yes but not a ton more. Adding 60 gallong of gas and water is where the weight comes in. I always appreicate you insight and input Shane.
  13. Oct 4, 2012 at 11:04 AM
    #613
    Ugly Betty
    Ugly Betty Well-Known Member
    mark
    TX
    85 extra cab on propane
    1985 ex cab, 92 toyota pickup, 95 4runner
    if you had a high clearance rear bumper i would think you wouldnt have the spare down there anymore, wouldnt the spare be lower than the HC then
  14. Oct 4, 2012 at 11:08 AM
    #614
    Socalduckslayer
    Tyler
    San Diego, Ca
    12 Tacoma
    Odds and Ends
    The hitch on the HCRB wont allow for a factory location spare. I think the skids would be for folks that have a setup that allows the factory spare to remain. That is a really vulnerable location for sure
  15. Oct 4, 2012 at 11:23 AM
    #615
    Leoffensive
    Leo
    San Diego, CA
    ask me how i know lol
    pretty pathetic but lulzy
  16. Oct 4, 2012 at 5:40 PM
    #616
    pbcolt
    pbcolt Well-Known Member
    Colton
    San Diego
    2024 F250 Tremor
    FWC Hawk
    Just picked up a bed rack today from Tyler for my RTT. Thing kicks ass. Will be getting some lights to put on the tabs he burned in and a hi-lift will be going on the side. No pictures at the moment, but I know he snapped one, so maybe he'll throw it up.
    Tyler will be getting some more of my rent money in the future for sure.
  17. Oct 4, 2012 at 8:31 PM
    #617
    Socalduckslayer
    Tyler
    San Diego, Ca
    12 Tacoma
    Odds and Ends
    Pics or it didn't happen Colton!!! Get that tent mounted up, I wanna see it. That was the main thought behind building these racks. I'm hoping someday ill be baller status like you and I can afford a tent to go on my rack :D
  18. Oct 4, 2012 at 8:40 PM
    #618
    pbcolt
    Colton
    San Diego
    2024 F250 Tremor
    FWC Hawk
    Baller status = parents rewarding you for spending 5 years and a ton of their money drinking, sleeping and questionable decision making which somehow culminated in a piece of paper with a printed signature that says I've done enough and don't have to come back.
    edit: Tent guy didn't come through today, maybe tomorrow. Then I'll put that rack to good use
  19. Oct 5, 2012 at 9:23 AM
    #619
    Ugly Betty
    mark
    TX
    :worthless:
  20. Oct 5, 2012 at 9:58 AM
    #620
    pbcolt
    Colton
    San Diego
    2024 F250 Tremor
    FWC Hawk
    fixed.
Thread Status:
