Pelfreybilt Off-Road
Discussion in 'Pelfreybilt Off-Road' started by Socalduckslayer, Apr 16, 2012.
Thread Status:
Not open for further replies.
  1. Jul 31, 2018 at 12:21 PM
    #6661
    Tom mike
    Tom mike Well-Known Member
    Tom
    2016 tacoma trd sport
    Damn I’ll prob go w the steel
  2. Jul 31, 2018 at 1:36 PM
    #6662
    ETXTacoma
    ETXTacoma Someone gave me a plasma cutter.
    Steven
    Tyler, Texas
    2014 DCSB Tacoma TRD OR
    Yea, does anyone know the exact weight different between the steel and aluminum ones and is the weight savings for the bottle really worth it price wise in the end?
  3. Jul 31, 2018 at 1:42 PM
    #6663
    desertjunkie760
    desertjunkie760 @DesertJunkie760 (IG)
    Shane
    2011 MGM DCSB TRD Sport 4x4
    Check My Sig.
    For $170, I immediately say no.
  4. Jul 31, 2018 at 1:46 PM
    #6664
    ETXTacoma
    Steven
    Tyler, Texas
    Same lol.
  5. Jul 31, 2018 at 1:57 PM
    #6665
    Chux
    Chux Pura Vida
    NJ beaches
    2013 TRD O/R Beach Buggy
    Click on my Build
    Just an fyi, it’s not just about the weight, it’s longevity as well. The propane shop near me will actually decline filling a tank if they see too much corrosion on it. They say the tanks rust from the inside out, so if you see a little on the outside their is most likely a lot on the inside. With the aluminum tank you will never have corrosion. I believe my tank was $179 at the time I purchased it. Along with buying a tank that will last forever, I also wanted the size and dimensions of that particular tank. Weight of aluminum was just a third bonus.
  6. Jul 31, 2018 at 2:01 PM
    #6666
    ETXTacoma
    Steven
    Tyler, Texas
    Good to know on that. I guess if you at least kept it in good condition it should last longer I would expect?
  7. Jul 31, 2018 at 5:59 PM
    #6667
    Chux
    Chux Pura Vida
    NJ beaches
    Click on my Build
    As long as you don’t puncture the tank it’ll last literally forever.
    ETXTacoma[QUOTED] likes this.
  8. Jul 31, 2018 at 7:14 PM
    #6668
    ETXTacoma
    Steven
    Tyler, Texas
    Dang, guess I can't use mine as target practice then.
    Had a thought about OBW... I need to get with waterport and see if the new waterport can be mounted vertically and still function as intended with the pressurized setup or not. Or if not, if the driver side swing out would have enough space to put the waterport in the horizontal position. Would eliminate the need for a jerrycan and water pump setup and could be made portable and easily removable and so forth. For about the same price as Jerry can holder, can, and pump and all that jazz I bet. A little less capacity, but easily refillable if needed and able to pressurize it again.
    itaro and Pelfreybilt like this.
  9. Aug 1, 2018 at 5:07 AM
    #6669
    Chux
    Chux Pura Vida
    NJ beaches
    Click on my Build
  10. Aug 1, 2018 at 5:40 AM
    #6670
    ETXTacoma
    Steven
    Tyler, Texas
    Ok fun police.
  11. Aug 3, 2018 at 8:13 AM
    #6671
    trekker
    trekker I like tacos
    Brandon
    Pocatello, ID
    '14 DCSB TRD OR MGM
    floor mats and a beer switch
    I use a 20lb tank with a milk crate (also stash tent stakes and other slender items in the corners of the crate to maximize the usable space), but that's mainly because I use propane for stoves, water heater, and tent heater... so I can go through a fair bit of propane on an extended trip.
    If I'm going solo and don't need to run the heater I'd love to strap a smaller tank to the outside like @Chux
    ETXTacoma likes this.
  12. Aug 3, 2018 at 1:27 PM
    #6672
    Chux
    Chux Pura Vida
    NJ beaches
    Click on my Build
    I originally made a mount for putting my Rotos on the spare.
    After sometime thinking where/how to mount the 6lb tank it just hit me to use the spare mount. So I added an additional plate to the spare mount that would hold the propane tank. It all worked out so well, everything fits snug but doesn't interfere with each other..
    Crom, deadhed61, Toyotico and 4 others like this.
  13. Aug 3, 2018 at 1:46 PM
    #6673
    ETXTacoma
    Steven
    Tyler, Texas
    So how long would it take for you to remove that to be able to get your spare down and such?
  14. Aug 3, 2018 at 1:51 PM
    #6674
    Chux
    Chux Pura Vida
    NJ beaches
    Click on my Build
    Not long at all... the same three lugs I need to remove to get the spare off are holding the Rotos and propane tank mounts. They are bolted together so I’d lift them off as one to get my spare off. Sorry no yard sale....
  15. Aug 3, 2018 at 2:10 PM
    #6675
    ETXTacoma
    Steven
    Tyler, Texas
    Lol, just wondering, what all does that weight when the rotos are full and everything?
  16. Aug 3, 2018 at 5:00 PM
    #6676
    Naveronski
    Naveronski Well-Known Member
    Fort Worth
    2014 MGM DCSB TRD:OR
    Thanks for posting!
    Also, which tap is that for your water jug?
  17. Aug 3, 2018 at 5:37 PM
    #6677
    ETXTacoma
    Steven
    Tyler, Texas
    Shoot, I did not even see that at first... that is a great idea...
    Chux likes this.
  18. Aug 3, 2018 at 6:16 PM
    #6678
    apocataco2015
    apocataco2015 Well-Known Member
    Clayton
    Salado, TX
    2017 Tacoma TRD OR 4x4
    Fox/OME/Icon lift. TRD Beadlocks. Toyo MT’s. Pelfreybilt, RCI, Mobtown armor.
    Added the front skid. Love it! Very well made and bolted on perfectly. Also added the sticker to my cooler :)
    Pelfreybilt likes this.
  19. Aug 4, 2018 at 5:48 PM
    #6679
    Chux
    Chux Pura Vida
    NJ beaches
    Click on my Build
    Umm some math would be..
    2 - 5gal jerrys (full): 80lbs
    2 - 4gal rotos (full): 64lbs
    34" spare on stock 17" steel wheel: ??
    Propane tank (full): 13lbs
    Trasharoo w/ miscellaneous gear: ??
    Spare tyre chainsaw and mount: ??
    Equals: Alot!
    Its called a bulkhead fitting. Found it researching rain barrel taps. Should be able to find at the hardware stores..
  20. Aug 8, 2018 at 12:25 PM
    #6680
    Tom mike
    Tom
    How long is “soon”
    Pelfreybilt[QUOTED] and Chux like this.
Thread Status:
