PennSilverTaco's "Perfect 5-Lug Regular Cab" Build, Aspergers, and General BS MegaThread!
Discussion in '2nd Gen. Builds (2005-2015)' started by PennSilverTaco, Jul 15, 2014.
  1. Oct 20, 2017 at 12:33 PM
    #5001
    black coffee
    black coffee A is A.
    Glenn
    509
    2010 AC 4x4 SR5 V6
    How many frame threads are already on TW?
    PennSilverTaco[OP] likes this.
  2. Oct 20, 2017 at 12:35 PM
    #5002
    crolison
    crolison Well-Known Member
    Ar vah da, CO
    POS
    +/- all of them
    Hartford and PennSilverTaco[OP] like this.
  3. Oct 20, 2017 at 4:21 PM
    #5003
    PennSilverTaco
    PennSilverTaco [OP] Encyclopedia of useless information...
    Charlie
    Central Bucks, Pennsylvania
    2010 Zombie Truck 2002 PT Cruiser
    @floodedkiwi
    Didn't want to post a whole bunch of unrelated photos in the "What have you done to your 2nd Gen today?" thread...
  4. Oct 20, 2017 at 5:05 PM
    #5004
    MikeCB600F
    MikeCB600F 4 Cylenders of angry fury
    Plainfield, IL.
    2012 Reg Cab 2.7L 4x4
    Extang Trifecta Tonneau cover
    Love the shifter knob. :cheers:
    I know what I want for Christmas
  5. Oct 20, 2017 at 6:42 PM
    #5005
    JohnWR
    JohnWR Active Member
    2006 Indigo Ink base Access Cab 2.7L 4X4
    You should never have to worry about your frame i've worked for toyota since 2011 and i have seen less then 10 2wd second gen tacoma's need frames. As for the undercoat it is what it is there is definitely better out there.
    They should have been added all sprays and frames get them this time around. i am actually going to see if i can order a set for my frame and install them.
  6. Oct 20, 2017 at 8:27 PM
    #5006
    tomwil
    tomwil Well-Known Member
    East Coast USA
    2014 Reg Cab 4x4
  7. Oct 21, 2017 at 1:19 AM
    #5007
    Fitz235
    Fitz235 Well-Known Member
    Rob
    New Hampshire
    Black '22 DCSB TRD Offroad 4WD
    - TRD T4R Pro Wheels - TRD Lift Kit - TRD Skid Plate - 265/70/17 Toyo Open Country 3's - OEM Bed Lights - OEM Bed mat - Alpharex Tail Lights - TacomaBeast LED Interior Lights - Green Lane Offroad Aluminum Sliders - Place Holder for More Bad Financial Decisions...
    As @JohnWR already mentioned, if they put the snot on your frame, part of that process is to install the plugs, so you should already have them. Most obvious place to check is on the frame right behind the front wheels. There are a few holes there, from what I remember. That way you don't have to crawl under the truck.
    Link to parts for anyone interested:
    https://toyotaparts.bochtoyotasouth.com/oem-parts/toyota-plug-kit-0400207104
  8. Oct 21, 2017 at 6:41 PM
    #5008
    JohnWR
    Thanks i know this i'm a tech for a toyota dealer. My frame was replaced back in 2014 before i owned it. As for the plug i'm after is the huge one that closes off where the frame goes from box to c channel. Third gens have this and we are installing during the H0F process and all new replacement frames come with this already installed. Also the amount of plugs they include this time around is amazing toyota is really trying to make these frames air tight from moister.
  9. Oct 21, 2017 at 6:50 PM
    #5009
    757yotas
    757yotas Well-Known Member
    Virginia
    2007 TRD Sport
    ICI Magnum front bumer Rigid LED lighting OME lift 285/70 Nitto Exos 17" Fuel Hostage TRD Exhaust TonnauPro Cover Oil Catch Can Tint Pioneer Nav system Sound System LED lighting Euro headlights Paint
    Fluid Film and duck tape over holes seems to work well for alot of people
  10. Oct 21, 2017 at 8:46 PM
    #5010
    DANGERMONEY
    DANGERMONEY Well-Known Member
    I gave seen where the inside of the frames are treated. Check with who treated it or could treat inside the frame, door panels and hood.
    You are in a salt state so you'll have rust issues. That said, treat it, enjoy it and check it every spring and fall.
    I don't think your screwed...just something you have to work with.
  11. Oct 21, 2017 at 8:47 PM
    #5011
    Balockay
    Balockay Well-Known Member
    Blake
    Cleburne, TX
    2017 4Runner TRD ORP
    Just look at the build thread
    Probably, yes.
  12. Oct 21, 2017 at 8:52 PM
    #5012
    trdsport6
    trdsport6 Well-Known Member
    West NC
    2015 Super White access cab TRD
    bilstein 5100 @2.5 front and rear Method NV BFG KO2 275/70/17
    Dealer did this to my very first truck and a few weeks later walked out in the driveway to find chunks of "rhino snot" laying on the ground for further weeks after! until eventually most of it fell off. If it isn't prepped or if the rust isn't stripped off then the rust will fall off with the stuff with it... After it all fell off I went back and drill bit wire brushed it off then coated it myself.
  13. Oct 22, 2017 at 5:17 PM
    #5013
    aillon
    aillon Member
    I have a 2008 Double Cab TRD. The under coating was done (for free) 2 years ago. I was just told that I qualify for frame replacement. To be honest, the frame looks pretty good to me, but I will take the free one. Ironically, I also got a new transmission (long story) for free at 70k, plus new frame at 120k = a fairly new truck.
    I also received (for free), new front bearings and new leaf springs. I have no reason to buy a new Tacoma, but I kinda wish i could
    wheeliest and PennSilverTaco[OP] like this.
  14. Oct 23, 2017 at 1:22 AM
    #5014
    tillmbil
    tillmbil Wild Bill
    Bill
    Tampa, Fl
    05 Tacoma access cab
    Toytec Ultimate 3" lift
    Mine goes from really cold to less cold quite often and it is not acceleration related. I took it to an A/C shop and everything checked out fine but they evacuated the system and recharged it anyway for my piece if mind. It still does the same thing, and to me it is bothersome. My wife's 2015 Mazda 1.8L never stops blowing cold.
  15. Oct 23, 2017 at 3:04 PM
    #5015
    replica9000
    replica9000 Das ist no bueno
    Lake Chargoggagoggmanchauggagoggchaubunagungamaugg
    2019 T4R ORP
    Can you refuse the coating, and have the frame inspected again?
    I can't say if I have the hole forming in the frame yet, but there are other areas that are rough on my frame. Throwing a coat of anything won't fix it. And if the hole starts from the inside out, the coating is useless anyways.
    lynyrd3 likes this.
  16. Oct 24, 2017 at 1:06 PM
    #5016
    Schaffer
    Schaffer Well-Known Member
    PA
    2015 Access Cab
    I'm also in PA, a friend of mine is getting his frame replaced. Toyota told him it will be about 6 months. Luckily Toyota is providing him with a 4 runner for the time being.
  17. Oct 24, 2017 at 1:13 PM
    #5017
    TacomaUSA
    TacomaUSA Cross Country Tacoma
    PA
    2007 Tacoma TRD Sport 4x4 Access Cab- 6 speed
    Are you all getting a new card in the mail even after Toyota applied the undercoat?
    My frame passed the inspection 01/16 and got undercoated. I'd like to have it tested again to see if I'm eligible for a new frame. I don't remember seeing another card in the mail though...
  18. Oct 24, 2017 at 1:26 PM
    #5018
    ss79camino
    ss79camino New Member
    anthony
    2005 tacoma Trd double cab short bed
    My 05 was originally passed 2 days ago. But called to tell me today they found a hole in the frame today!
    So now im getting a new frame ! dealer told me at least 1 to 2 months as frame has to be ordered.
    I have a brand new 1794 Tundra with 10,000 miles in the mean time to use. might not keep it as it has no cover on the bed , have no where to keep my work stuff.
    Has anybody had a frame change yet?
  19. Oct 24, 2017 at 3:40 PM
    #5019
    PennSilverTaco
    Charlie
    6 months until what? They can get the frame in? I was told at my dealership it would be about a 2-month wait, but that if my frame needed to be replaced they'd give my truck back and let me continue driving it as long as the frame wasn't rusted so bad to the point of being unsafe to drive...
    And I'm jealous! All they have for loaners at my dealer are Camrys and Corollas!
  20. Oct 24, 2017 at 3:42 PM
    #5020
    T4RFTMFW
    T4RFTMFW Well-Known Member
    If they are replacing the frame, it’s unsafe to drive.
    I don’t know anybody who got new frame and was allowed to drive the truck until it came in - that’s a huge liability.
