PennSilverTaco's "Perfect 5-Lug Regular Cab" Build, Aspergers, and General BS MegaThread!
Discussion in '2nd Gen. Builds (2005-2015)' started by PennSilverTaco, Jul 15, 2014.
  1. Sep 5, 2016 at 6:47 PM
    #561
    T4RFTMFW
    T4RFTMFW Well-Known Member
    Best part of this story is prolific amounts of aged booze.
  2. Sep 5, 2016 at 6:52 PM
    #562
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    Wait a minute...is this another drunk Gramps story?
    03f5sp and Maticuno like this.
  3. Sep 5, 2016 at 7:04 PM
    #563
    pruchai
    pruchai KAMA3
    San Diego, CA
    ‘07 Saab 9-7x 4.2i (it identifies as a Tacoma)
    Not enough...
    I hated stupid start button on my X3. thet thing was soooo damn quiet, that I just exited the car and walked away a bunch of times not realizing its still running. One time i went to the dog beach, just to come back 2 hours later and to find my car still running. Yes, I am a space cadet and yes, someone like me needs a good old key.
    PennSilverTaco[OP] likes this.
  4. Sep 5, 2016 at 7:10 PM
    #564
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C w/12TRDTacoma's Qwikchange Hub & 2.5" RIP-Modded Pulley, Roostfactor's Pulley Wrap Mod; FPR Mod; JustDSM Tune via HPT MPVI2; mightytacoman Intercooler Tank; aFe POWER Magnum FLOW Pro DRY S Air Filter; OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; NSB-AGM27F Battery w/HKB Adjustable Voltage Booster & Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Trident904's MT ADM; BFG All-Terrain T/A KO2s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; BPF TRD Skid, Tow Hook, & Cooling Panel; jsi's Locker Anytime, Up2NoGood's 2Lo Module; ramonortiz55's Always on Power Outlet Relay, ND4's Fog Light Anytime, & Crom's Speed Bleeder Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades; ThreatLevelMidnight's Wireless Charger; 4Runner 4X4 & FJ Fog Light Switches; redtaco2007-inspired LED License Plate Lights; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; loginfailed-inspired Speedhut Boost & AFR Gauges in a Lotek Pillar Pod; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; TacomaBeast Glove Box & Console Organizers; Husky Floor Liners; UltraGauge EM; mesojdm's Ultimate LED Dome & Map Lights & GASSHOLE; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Cali Raised Led Bed Stiffeners; Pop & Lock Power Tailgate Lock w/TacomaTruckParts Support Bracket; ARE Z-Series Cap, SolarGard Tint; BlendMounted & MirrorTapped Uniden R3; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
    Each successive copy (of a copy etc) degrades in accuracy/quality. Moreover, the original keys and tumblers themselves degrade with normal use.
    I've had good luck getting keys cut via VIN/code. This is done by your local dealer. If you have the original key code, they should cut a new key with few (if any questions). If they have to use your VIN to get the code from Toyota, you'll need ID and proof of ownership.
    tinker_troy and shakerhood like this.
  5. Sep 5, 2016 at 7:15 PM
    #565
    teamhypoxia
    teamhypoxia MichelinMan
    Colorado
    '12 DCSB TRD OR
    Problem one is common if you normally only use one key.
    Wife's minivan will only work with the key she's always used. The second, original key will no longer work as the key and tumblers have worn together. It will work in the passenger door lock though because that lock has hardly ever seen a key.
    Problem two is because the ac is bringing in fresh air from outside. Your door seals are probably working really well and the air has to go somewhere. It would be interesting to see whether or not it still does it when set to recirc.
  6. Sep 5, 2016 at 7:26 PM
    #566
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
  7. Sep 5, 2016 at 7:30 PM
    #567
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    I actually like to rotate my keys, truck came with 2 so I switch every year or so to prevent any issues in the future.
    PennSilverTaco[OP] and Norton like this.
  8. Sep 5, 2016 at 9:03 PM
    #568
    PennSilverTaco
    PennSilverTaco [OP] Encyclopedia of useless information...
    Charlie
    Central Bucks, Pennsylvania
    2010 Zombie Truck 2002 PT Cruiser
    No, it's something that's going on right now.
  9. Sep 5, 2016 at 9:05 PM
    #569
    PennSilverTaco
    Charlie
    Where would I get the key code? I don't think a base model Taco with rollup windows and manual locks has coded keys?
  10. Sep 5, 2016 at 10:41 PM
    #570
    Norton
    It comes on a small tag with the keys when the vehicle is delivered.
    Like I said, if you don't have it, the dealer can use your VIN to get it from Toyota. You'll need ID and proof of ownership for this process. (In addition to having them cut you a new key, make sure you GET THE CODE from them. You can use it to skip the step involving your VIN, ID, and proof of ownership in the future.)
    shakerhood likes this.
  11. Sep 5, 2016 at 11:14 PM
    #571
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Nothing is ever simple is it.
    Norton likes this.
  12. Sep 6, 2016 at 1:15 PM
    #572
    mgord
    mgord Well-Known Member
    Harrisburg, PA
    07 TRD
    K&N, Leaf Springs, Home Built Camper
    I have a key taped to the hitch with black electrical tape. I live in fear of after backpacking for a few days/weeks I'll come back to the truck and have lost my keys. Unless you know exactly where to look you won't find it. Blends in beautifully.
    Duck_Hunter likes this.
  13. Sep 6, 2016 at 8:54 PM
    #573
    PennSilverTaco
    Charlie
    I have my driver's license, but would that mean I'd have to bring the title? Or is registration and proof of insurance good enough?
  14. Sep 6, 2016 at 9:08 PM
    #574
    Norton
    My dealer wanted ID and registration. I recommend asking yours what they require.
  15. Sep 6, 2016 at 10:13 PM
    #575
    landphil
    landphil Fish are FOOD, not friends!
    BC, Canada
    RIP 2006 Tacoma DCSB
    Tundra 5.7 mod
    You're not the only one with the locks-but-won't unlock key issue. I too had the same problem with a two year old key that had worked perfectly for a year and 11 months - I started using the second key I had cut the exact same time, and problems solved. Not really any significant wear on the key having issues either.
  16. Sep 23, 2016 at 7:15 AM
    #576
    PennSilverTaco
    Charlie
    More than three years ago, I replaced my entire sound system. I bought the head unit and speakers on Crutchfield. The head unit is a Pioneer DEH-X6500BT. It has Bluetooth, USB, AUX, and CD/MP3 capability, etc. The speakers were the only Pioneer component speakers that would fit in my truck without extensive modifications. I paid $240 total for everything. Just about everybody on Tacoma World knows about my run-in with a career alcoholic in a Mercedes-Benz in October 2015. Well, after that bastard lied to his insurance company despite getting a DUI and put me through the ringer when I was getting my truck fixed, justice was still served.
    The drunk driver was ordered by the court to pay me $500. I decided to put the money to good use and buy a dashboard camera, so nobody can hit my truck and lie about it again. It would be the ultimate way to stay safe on the road and symbolically give Sir Drinks-A-Lot the middle finger.
    Also, I have had my driver's license for almost 6 years as of this post, and I have a virtually flawless driving record. I've never gotten a ticket (aside from a parking ticket in 2013) and have never even been pulled over! I rear-ended a Mustang in August 2015. Other than that I am squeaky clean. However, I haven't always been the greatest at backing up. I decided to go all-out with my restitution money and get myself a backup camera too!
    The need for a backup camera is why I have chosen to replaced my otherwise problem-free Pioneer head unit. My speakers are awesome and I have no plans to replace them, though I may add a subwoofer and an external amp in the future.
    I wanted another Pioneer head unit in the worst kind of way, but Pioneer does not make an double-DIN head units with front USB and AUX ports. Getting a Pioneer head unit would have meant plugging cords into the back and running them around to the front. Simplicity is what I am going for here. As of right now, I plug my iPod into the front of my head unit and Velcro it to my dash under the A/C vent so I can use it without taking my eyes of the road. I narrowed my options down to Jensen and Sony. The only reason I would have gotten the Jensen is because it offered built-in navigation for a ridiculously low price compared to other brands with GPS. I ultimately decided not to get built-in GPS (I have a Garmin portable GPS), and the tech support guy recommended Sony over Jensen. My first game console was a PlayStation (Christmas present in 1999), and I grew up with a 32-inch Trinitron TV in my family room, so I've always loved Sony products.
    Also, instead of selling my Pioneer head unit, I have decided to just give it to my best friend's younger sister, who plans on installing it in her 2004 Isuzu Rodeo.
    Anyway, here are the items I purchased last night:
    Head unit:
    http://www.crutchfield.com/p_158XAV650B/Sony-XAV-W650BT.html?tp=20217
    Backup camera:
    http://www.crutchfield.com/p_020CC520/Clarion-CC520.html
    Backup camera mount:
    http://www.crutchfield.com/p_020CAU002/Clarion-CAU002.html
    Dashcam:
    http://www.crutchfield.com/p_079CDR835/Cobra-CDR835.html
  17. Sep 23, 2016 at 7:34 AM
    #577
    dragorn
    dragorn Member
    2014 Spruce Mica Tacoma
    My only recommendation is that if you have a smart phone & run your maps off that (vs a garmin standalone), look at a unit that has carplay or android auto, depending on your phone. Either will give you nav on the center console, powered by your phone, and anything that supports that will also support backup cameras. Pioneer makes several models that support both, other manufacturers as well.
    Downside is it'll be a bit more expensive, probably.
  18. Sep 23, 2016 at 7:50 AM
    #578
    turbodb
    turbodb AdventureTaco
    Dan
    PNW
    2000 Tacoma Xcab 4x4 SR5 V6 TRD
    AdventureTaco
    Looks like an interesting system. I recently upgraded my setup (from a Panasonic) because I was looking for something clean(er) in the dash. Actually, the thing that bugged me the most was the background on displa of the Panasonic - there was no way to turn off all the crazy graphics and just make it black.
    I ended up going with a head unit that runs Android (JOYING JY-UL135), and it's been pretty great (and was a lot cheaper). It's nice being able to install apps, sound is good, connects to phones easily, supports backup/dash cams, etc.
    I posted about it here if you're interested: https://www.tacomaworld.com/threads/joying-android-5-1-1-double-din-thread.444640/
  19. Sep 23, 2016 at 9:02 AM
    #579
    WebberLander
    WebberLander Well-Known Member
    Mark
    Colorado
    2011 SR5 4x4
    Overlanding Rig
    X2, Android Auto and Apple Car play are great. Sync's up without any trouble everytime on my Pioneer SPH-DA120
  20. Sep 25, 2016 at 8:49 PM
    #580
    PennSilverTaco
    Charlie
    Backup camera/touch-screen head unit install!
    My neighbor did all of the hard work like running the wire for the backup camera, and all I really did was take everything apart and put it back together again. He insisted that all I have to do is buy him a new package of plastic shrink clamps at Home Depot (roughly $3 to $4) and pretty much did the work pro bono, but I bought him a 12-pack of his favorite beer anyway.
    This is my "old" stereo, installed by my friend in April 2013. It gave me 3½ years of trouble-free service. Yes, my dash bezel is being held in place with electrical tape. This was a recent addition (like two days prior to replacing the stereo). I had to slam on the brakes and my friend's dog hit the dashboard. Tully was fine, but the whole stereo assembly was knocked out of alignment and I lost one of the plastic clips while trying to fix it...
    My iPod is held in place with a piece of Velcro...
    New stereo, still in the wrapper...
    With the dash bezel removed...
    With the whole stereo removed...
    The A/C controls, hanging by a clump of wires but still fully operational. I actually drove around the corner to my house with the radio removed and the A/C controls hanging (and the A/C on) to get some snacks because I got hungry.
    IMPORTANT: Avoid disconnecting the digital clock/passenger airbag/seatbelt warning display. Doing so will cause the airbag warning light to come on. My neighbor and I couldn't figure out how to shut it off and wound up having to totally disconnect the battery to reset the entire truck...
    My neighbor splicing the wiring harness together...
    Running the wire for the backup camera...
    Running the wiring to the backup camera was much easier than I thought. Ryan did all of the hard work while I watched and learned...
    There was a hole in the floorpan where various electrical guts went through, and it had a rubber grommet. This meant we did not have to drill a new hole in the floor to run the camera wire...
    NewStereo 017.jpg NewStereo 018.jpg NewStereo 019.jpg NewStereo 020.jpg NewStereo 021.jpg
    Using the Greenlee snake to pull the wire through the stereo opening...
    IT LIVES!!!
    Installing the mounting bracket...
    Closer look at backup camera:
    Almost done:
    And DONE:
    Blasting my favorite song:
    And I was under the impression that the backup camera would not work until it was wired into the computer (which my neighbor will be doing this Thursday). Imagine my surprise when just out of curiosity I pressed "Camera" on the head unit's touch screen and the thing actually turned on! That's my parents' driveway and my dad's Pilot:
