Pepboys just made my 6-lug into a 5 lugger
Discussion in '2nd Gen. Tacomas (2005-2015)' started by GEORGE STRAIT, Nov 5, 2012.
  1. Nov 6, 2012 at 10:56 AM
    #61
    aficianado
    aficianado Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR + 2023 TRD off-road.
    back to bone stock.
    glad they fixed the problem.
  2. Nov 6, 2012 at 2:46 PM
    #62
    V5ioV
    V5ioV My drinking team has a wheeling problem
    V5ioV
    Out n 'bout
    '13 Pewp Water Slut
    King 2.5 Rem Resi Ext Travel w/comp adj w/700# springs, TC Uni-Ball UCAs, ARB/OME Dakar Leaf Springs w/ King 2.5 Rem Resi w/comp adj and custm eyelets, Stealth Custom Series F-5 Wheels wrapped on: 285/75/16 Fierce Attitudes, BORA 2.25 wheel spacers, GOODRIDGE extended Brake lines, Triple-6" Double Row LED Light Bars behind lower grill, ATFL MOD, TRD Ball Type Shift Knob, Husky WeatherBeater Floor Liners, 60'' HiLift Xtreme, 4xInnovations Bolt-On Sliders w/Kickout, Spring Hanger Skid, Custom BlackPipe Fabs CMC and custom FYL Bed Rack, CVT Mt. Shasta RTT, Trasharoo, 4xInnovations HiLift Bedside Mounts, 4xInnovations Front Skid Plate, TOYWERX Ghost Raptor thin-lip Satoshi Grill, RedLine Hood Struts, 4xInnovations Transmission Skid and T-Case Skid Plates, Wheelers Rear SuperBumps Bump Stops, All-Pro Off Road U-Bolt Flip Kit, UltraGauge, ARB OBA, Pelfreybilt HC rear Bumper, Rotopax system (Single Mounting Plate and Bed Rail Mounting Plate both with LOX handles.
    prolly free break check or some bs like that
  3. Nov 6, 2012 at 4:13 PM
    #63
    jandrews
    '09 FourDubDee TRD OR
    You can cut the cost of your oil change in *half*. Also, you won't have to worry about stupid mistakes or travel time to/from the lube joint.
    0w-20 is only expensive if you buy it from the wrong places.
  4. Dec 14, 2012 at 12:13 AM
    #64
    03f5sp
    03f5sp Well-Known Member
    Bill
    Wisconsin
    2011 TRD Off Road dcsb
    Front 5100s @ 2.5, 1.5 AAL, 265/75-16 all terrains
    A thinner oil viscosity will not last longer. Whoever told you that is dumb as a rock. And 0w20 isn't any more expensive than 5w30.
