PERFECT LIFT....????
Discussion in '1st Gen. Tacomas (1995-2004)' started by bowhunter11199, Apr 19, 2011.
  1. Apr 19, 2011 at 8:45 PM
    bowhunter11199
    bowhunter11199 [OP] Well-Known Member
    what are your guys thoughts on these lifts. please explain as much as possible.... THANKS FOR TAKING YOUR TIME TO READ AND RESPOND....
    3" skyjacker coilover/new leaf pack:-$1360coma Skyjacker Ckyjacker Coil-Over Lift System
    http://www.topguncustomz.com/Store/G...view=129365666
    4" procomp lift(put wheres the rear lift componets???)-$1787 kinda spendy
    http://www.topguncustomz.com/Store/G...view=207382196
    5" tuffcountry ( i kinda like this one except for the blocks in the back)-$1440
    http://www.topguncustomz.com/Store/G...iview=38467866
    3" tuffcountry ( looks kinda cheezez)-$304
    http://www.topguncustomz.com/Store/G...view=133988416
    2.5" blisten ( I dont know much about these lifts)-$290
    http://www.topguncustomz.com/Store/G...view=237130145
    2.5" rough country(looks kinda cheeze too and i kinda want a 3" lift or bigger)- $240
    http://www.topguncustomz.com/Store/G...view=133989386
    EDIT:
    ome 3" lift- $ 1100 (i would get the new leaf pack)
    or other sugestions.....???
  2. Apr 19, 2011 at 8:47 PM
    chvymechanic
    chvymechanic Well-Known Member
    Thomas
    New Hampshire
    04 Limited TRD Off Road 4x4 Xtra Cab
    Stuff and Thangs
  3. Apr 19, 2011 at 8:47 PM
    ColtsTRD
    ColtsTRD Well-Known Member
    Scott
    AZ
    Bilstein from those choices
  4. Apr 19, 2011 at 9:12 PM
    bowhunter11199
    i added OME lift in there
  5. Apr 19, 2011 at 9:15 PM
    Blue
    Blue You're my boy blue
    Dylan
    Sierras
    ex 99 current 04 TRD
    Eibach coils- 149
    Bilstein 5100's set at 0- 185
    Bistein 5125 in the back - 160
    All Pro 3" leaf springs - 349
  6. Apr 19, 2011 at 9:16 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
  7. Apr 19, 2011 at 9:19 PM
    bowhunter11199
    can you explain why you say OME???
  8. Apr 19, 2011 at 9:22 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Sure. The OME Shocks are perfectly dampened for their springs, and have been tried and proven off road. If your looking for the best performing suspension, out of those you listed, the OME beats them hands down.
  9. Apr 19, 2011 at 9:23 PM
    Unknown
    Unknown He who angers you conquers you
    Brian
    Los Angeles
    Unknown
    Unknown
    His suspension now
  10. Apr 19, 2011 at 9:24 PM
    bowhunter11199
    hey!!!!! what the hell man????
  11. Apr 19, 2011 at 9:28 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Is that an old Trail Master lift??
  12. Apr 19, 2011 at 9:29 PM
    bowhunter11199
    umm....nooooooo..... mabey........dame you caught me...... yup it is...:(. but it was on when i bought it
  13. Apr 19, 2011 at 9:31 PM
    Blue
    Dylan
    Sierras
    are you looking for a new lift for your current truck? Your sig says it will be for sale soon
    :notsure:
  14. Apr 19, 2011 at 9:36 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    If your gonna dump that POS TM lift, with a 3" lift, your gonna need to re weld in a new cross member, and get some new UCA's.
  15. Apr 19, 2011 at 9:37 PM
    bowhunter11199
    yup..... sadly it will be for sale in late may early june....:(.... but i want another taco and i trying to figure out what lift i want
  16. Apr 19, 2011 at 9:41 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 SCv6 AutoTrans With Lots of Mods ADS COs w/Compression Adjusters Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Plastics Guy Front Bumpstops Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren Bumpstops 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Black 17x8 Konig Countersteer Type X 285/70r17 Falken A/T3w Gunmetal 16x8 SCS Ray10s 255/85r16 Maxxis Bighorns Limited Edition (Relentless) Elite Front Bumper Smittybilt X2O 10K Winch Diode Dynamics SS3 Sport Selective Yellow Fog Lights in the Bumper Diode Dynamics SS3 Pro 4,000 Kelvin SAE Driving Lights with Clear Lenses on the Bumper Morimoto D2S Projectors XB35 Ballasts + 4300K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Dometic CFX 55im Fridge/Freezer Alpha II Hardshell RTT Badland Custom Bed Rack Denso 210-0461 105 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Magnuson MP62 Supercharger w/2.37" Pulley Haltech Elite 2000 Standalone ECU Denso 650cc Fuel Injectors Doug Thorley Headers Aeromotive Stealth 340 Fuel Pump TransGo A340F Reprogramming Shift Kit Magnaflow Hi-Flow CAT, Magnaflow 18" Muffler w/Vibrant Resonator 13WL Brake Calipers Braided Steel Brake Lines ScanGauge II OBDII Scanner Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    I don't think you can do make any of those lifts you listed work. At least, not without a lot of work. To install the traildissaster lift, the cross memeber that supports the front diff had to be removed, cut out and replaced with a dropped bracket.
    Its been done, weld in an original cross member, but a lot of effort and expense.
  17. Apr 19, 2011 at 9:42 PM
    bowhunter11199
    did you read this ^^^^^
  18. Apr 19, 2011 at 9:47 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I didnt see that. Get teh OME.
  19. Apr 19, 2011 at 9:52 PM
    bowhunter11199
    i was just asnswer dig....
  20. Apr 19, 2011 at 9:53 PM
    bowhunter11199
    what about if i want a lift bigger than 3"s ???
