Performance tune
Discussion in 'Performance and Tuning' started by Tarpon24, Jun 23, 2012.
  1. Jun 26, 2012 at 11:26 AM
    Amo-cat3
    Amo-cat3 Wizard Sleeve Master
    Maui, Hawaii
    07 TRD Blown dubcab
    TRD Supercharged 4.0 w/ 2.5" Quick change Pulley, UCON EMS, URD 7th injector, AFE Stage II intake, DT Longtubes, MBRP 2.5" dual exhaust w/ Vibrant Ultra resonator, URD Y-pipe w/ vibrant v-bands (Cat free), Walboro 255 fuel pump, SS Oil catch can, Aeroforce gauges, Icon CDC 2.5 coilover set at 3", 1.5" Wleelers Progressive aal, Light racing uca, 17x8.5 Fuel Anza 4.5" backspace/-6 mm offset, Kelly Safari a/t 265/70/17, scanguage 2, AMP electric steps, bed extender, Low-pro tonneau cover, 20% tinted windows/headlights/taillights, tacoma seat covers, Image dynamic sound system w/ Pinoneer avh3200 head, assrtd stickers................
    Hey OP, in your truck description you say you have flowmaster true duals - so you probably don't have any cats in your exhaust. Without you cats your probably not running at optimal fuel effeiciency.
  2. Jun 26, 2012 at 11:28 AM
    Tarpon24
    Tarpon24 [OP] Well-Known Member
    Frankie
    Fl
    Trd
    Leveling kit, 20 in rims, flowmaster true duals, bullying watch dog,
    Yea well u know what u can kiss my ass Huge 31.5 pound rims and I'm sorry but I have a buddy that has the same truck with a 6 in lift and 35 he gets 13 city so excuse me wondering if anyone else had a gas mileage problem. And last time I checked terra grapplers are a/t. So if u don't like it don't look at it I hate stuck up asshole like you because I'm sure If u asked a question about something you would want and anwser not Prius or pussy mod.
  3. Jun 26, 2012 at 11:29 AM
    Tarpon24
    Frankie
    Fl
    Trd
    Thanks I will try that today.
  4. Jun 26, 2012 at 11:30 AM
    Tarpon24
    Frankie
    Fl
    Trd
    No I had him run the duals from each cat back.
  5. Jun 26, 2012 at 11:43 AM
    Tarpon24
    Frankie
    Fl
    Trd
    Yea I forgot the guy I took my truck to I had asked for true duals but he put in a x pipe by accident. Could the x pipe affect it
  6. Jun 26, 2012 at 11:46 AM
    Tarpon24
    Frankie
    Fl
    Trd
    Why would the 20 in rims Jill fuell economy their only just under 3 lb heavier a rim.
  7. Jun 26, 2012 at 11:49 AM
    mjp2
    Milton Juevo Portimous II
    NJ
    Current: '21 Bronco Badlands. Previous: '06 TRD Access Cab, v6, 6-speed
    Easy starting point: What are ALL of the differences between your truck and your buddy's?
    And relax, man. Fuel economy questions come up all the time, but the reality is that you're driving a truck, not a car, and your calculations are going to be very off if you're going by your odometer since you swapped tire sizes.
  8. Jun 26, 2012 at 11:56 AM
    Tarpon24
    Frankie
    Fl
    Trd
    Well we have the same exhaust. He has the 6 in procomp lift He has 20s with 35s And he has a cold air intake. Which I will have as soon and the company I ordered from decides to ship it. But I have the 3 inch leveling kit with 33s on 20's.
  9. Jun 26, 2012 at 12:03 PM
    mjp2
    NJ
    Same engine, same transmission, same year, same cab, same bed, same amount of crap in the bed, etc?
  10. Jun 26, 2012 at 12:50 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    X pipe aids in scavenging and efficiency. Not the problem. Would you mind posting up pics of your exhaust work done?
  11. Jun 26, 2012 at 3:58 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    I agree with you, that on some vehicles a aftermarket intake doesn't do much if anything. On the 1GR Tacomas however, it does. Op, if you want an intake that is known and proven to work well on the 1GR get the 1st Gen TRD intake, AFe Stage 2 intake, or the URD intake. Just check out www.urdusa.com
  12. Jun 26, 2012 at 4:04 PM
    Aw9d
    Aw9d That one guy
    My stock OR rims are 22lbs a pop w/out tires. You sure this is right with a 20inch rim AND a tire?
  13. Jun 26, 2012 at 4:08 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    There is another thread for that whipper. Not going to clutter his thread with that. Besides. What experience do you have with one on this truck?
  14. Jun 26, 2012 at 4:41 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    In that case, I will rephrase my comment. The TRD style, and yes it does make noise, is bounds better than a K&N style. Due mainly to the fact of engine bay heat saturation of the K&N style since they are not in an enclosed container in the engine bay. The trd style is, and draws its air from the fender well.
    It is less restrictive than factory in the simple fact, that its design is basically a smooth straight line. Compared to the factory one which has many turns and ripples throughout.
    They won't hurt your MPG, and gains will be limited in MPG, when adding a good one. Still depends on how heavy the foot is as well as other factors.
    The three I mentioned will give you a gain in HP and torque, proven by dynos, but nothing that will make a significant butt dyno feel, if you drive like Miss Daisy.
    Increasing your tire pressure by 5 psi, will help, if yours is low. However, that will require some testing as well.
  15. Jun 27, 2012 at 9:25 AM
    #35
    Tarpon24
    Frankie
    Fl
    Trd
    I did buy the afe stage 2 with the dry filter looked like everyone liked it the best. An I increased my tire psi from 32 to 40 psi 2 days ago and I think that was the problem brought my mpg from 11 to 15. I just checked it when I filled up last night.
  16. Jun 27, 2012 at 9:42 AM
    #36
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Good deal. Lots of people easily overlook the tire pressure. Mainly because they just forget about it. I have done it as well. Your rolling resistance increases significantly as your tires get wider. Even more compounded as the tire pressure goes lower.
    I believe that it is an average of 1-2 MPG loss, per 5 psi decrease in pressure. Of course, that will also vary on tire width. Wider obviously having a greater affect than narrower, as well as tread patterns.
    www.southwestresearch.com. They have data analysis for different size tires and pressures, if you feel inclined to look it up.
    I am glad you found some MPG and performance.
    Also, have you been accounting for the difference in you tire size, and it throwing your mileage off?
  17. Jun 27, 2012 at 3:14 PM
    #37
    Tarpon24
    Frankie
    Fl
    Trd
    Yea thank a bunch. I'm actually around 17 now pretty happy. And I didn't need the " Prius" mod.
  18. Jun 27, 2012 at 3:18 PM
    #38
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Glad to have helped. :thumbsup:
