Personal Defense ammo....
Discussion in 'Guns & Hunting' started by chris4x4, May 9, 2010.
  1. May 11, 2010 at 5:59 PM
    #41
    chris4x4
    chris4x4 [OP] With sufficient thrust, pigs fly just fine. Moderator
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Dont forget Ammoman.com :) For accesorise, Check out 44mag.com
  2. May 11, 2010 at 6:12 PM
    #42
    Fire931
    Fire931 Well-Known Member Vendor
    VA
    00 4Runner
    my carry ammo is speer gold dots.. forget what weight but they are the heaviest i could find for 9mm.... the 500 stays loaded with just regular old buckshot....
  3. May 11, 2010 at 6:14 PM
    #43
    Sullyman
    Sullyman Crusty ole' conservative fart
    Augusta, Georgia area
    2010 Black TRD Sport
    Cat-back exhaust, BluLogic, Back-up Camera, Extang Solid Fold Tonnau cover, Pop-n-Lock PL8521 electronic tailgate lock, Illuminated 4x4 switch, Smittybuilt Nerf Step Bars, Toyota bed mat, Tinted the windows darker, CB with custom fab'd antenna mount, Grillcraft grill, AFE Pro Dry S filter with secondary filter removed. Differential breather relocation mod. Bridgestone Dueler AT/Revo 3 tires Weathertech mats Spec-D HID Halo's Bilstein 5100s front set at 2.5" w/OEM springs 4-leaf TSB w/ SkyJacker add-a-leaf 2" block lift 1.5" wheel spacers Freedom Off-Road upper control arms .5" coil spacers ATOTO A6 Android double-din head unit
    I shoot whatever's cheap...ball ammo at the range and then load the mag with JHP for carry...If you put enough rounds in center mass...bullet weight isn't so important ;-)
  4. May 12, 2010 at 6:56 PM
    #44
    0801
    0801 Well-Known Member
    San Diego
    Front: Icon coilovers, Rear: bilstein 5100s + 3 leaf AAL
    Corbon 230gr .45
    Super-x 00 buck or birdshot
    M193 and M855
  5. May 12, 2010 at 8:21 PM
    #45
    NUKEWORKER_69
    NUKEWORKER_69 Well-Known Member
    Surprise AZ
    09 SR5 4x4
  6. May 13, 2010 at 2:58 PM
    #46
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Awsome!!! ^^^
  7. May 13, 2010 at 3:09 PM
    #47
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I have used that method before. Seems the spray adheasive works the best still.....
  8. May 17, 2010 at 8:58 PM
    #48
    TunnelDV
    TunnelDV Well-Known Member
    Derek
    Denver
    10 4Dr Tacoma White
    Grizzly Xtreme 9mm +P. This stuff is evil.
    Derek V
  9. May 19, 2010 at 7:04 PM
    #49
    tussery
    tussery Well-Known Member
    Corpus Christi, Tx
    09 PreRunner SR5
    Magnaflow muffler, TRD CAI.
    I am keeping a couple 30 rd mags full of 75 gr TAP FPD around now. I need to invest some handgun rounds.
