phone mount for center vents in 08 Tacoma
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ebordeaux, Dec 5, 2020.
  1. Dec 5, 2020 at 7:18 AM
    ebordeaux
    ebordeaux [OP] New Member
    2008 Tacoma w/ cap & bedliner
    Hi, I'm trying to find a decent phone mount for the center vents in my 08 Tacoma. The one I use in my other cars doesn't stay securely in place. I am not interested in dashboard, windshield, cup holder, or left vent mounts. What do you have that works well for you?
    Thanks!
    JoeTacoma02 likes this.
  2. Dec 5, 2020 at 7:52 AM
    CTSpruceMica
    CTSpruceMica Is a hotdog a sandwich?
    Dennis
    2014 Spruce Mica
    JoeTacoma02 and Rmtomasin like this.
  3. Dec 5, 2020 at 8:26 AM
    ebordeaux
  4. Dec 5, 2020 at 8:29 AM
    Rmtomasin
    Rmtomasin Well-Known Member
    2011 Super White Tacoma Access Cab V6 6SPD
  5. Dec 5, 2020 at 8:37 AM
    JoeTacoma02
    JoeTacoma02 Well-Known Member
    This is what I use in my 2005 Taco. Have been using it since June of 2019. It has wireless charge capability but my phone case is too thick I guess so it doesn't work unless I take it off but now that I've seen the CD mount option I'm gonna look for more options.
    https://www.amazon.com/dp/B079L4TRW1/ref=cm_sw_r_cp_apa_fabc_Ny7YFb0VGGFE0?_encoding=UTF8&psc=1
    Whoa I didn't know these exist! Definitely gonna look for more options of these. I want one that has a holder on the bottom too for your phone to rest on like the one I have in the link. Thanks for sharing!
  6. Dec 5, 2020 at 8:44 AM
    CTSpruceMica
    Dennis
    2014 Spruce Mica
    I'm using it with a Pixel4 in a Otterbox case. Easy one hand in/out as it's spring loaded.
  7. Dec 5, 2020 at 11:29 AM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    I have two of these from different vendors. Both pop out when off-roading unless you remember to tighten the knob every 30 min or so, depending on trail conditions.
    Similar issue with vent holders, and on hot days, it will interfere with the AC air. The best solution for me was a windshield mount with a long arm; it rests on the dash and extends down over the CD player. Not the prettiest but it stays in place and has never fallen off the windshield.
  8. Dec 5, 2020 at 12:29 PM
    igno1tus
    igno1tus Small member
    Lehigh Valley Area , PA
    '07 Tacoma Access Cab TRD Off Road
    Ram mount parts and ram x grip, with ProClip mount to the center console . I can have my arm resting on the arm rest and operate the phone . Very ridged and sturdy and all heavy duty . About $60 in parts doesn’t obstruct any controls and passenger (wife) still has room in the pass seat
    edit also might I add it isn’t really affected by heat and cold . The company of the mount to the console doesn’t recommend what they call pedestal type mounts being used as the say it will “wear out the mount faster” (which is the type shown here) but I don’t see what might wear out , I guess only time will tell
  9. Dec 5, 2020 at 1:14 PM
    jeffbofd
    jeffbofd Member
    Jeff
    2013 DCLB
    Stock
  10. Dec 5, 2020 at 2:27 PM
    Regnar
    Regnar Well-Known Member
    Kodiak,AK
    2014 DCSB PreRunner SR5
    After trying multiple mounts I ended up making my own to fit the CD slot that I have never used. I have been pretty happy with it. I have had an IPad mounted to it and it didn’t budge a bit.
  11. Dec 5, 2020 at 2:46 PM
    ABNFDC
    ABNFDC Well-Known Member
    Granite State
    2008 4WD Access Cab TRD OR "Rugged Trail"
    265/75/16 Wildpeaks, Dakar rear, HS 2.5" front coils
    I have tried a half dozen random mounts to include vent mounts. All had issues. The vent mounts would not hold the phone at the proper angle--I did save them for whenever I rent a car though.
    I went with a glue on X-Grip mount. The glue didn't hold too well in the heat where I used to live, so I epoxied it to the dash--it's going nowhere.
  12. Dec 6, 2020 at 2:35 AM
    ThaiChillyTaco
    ThaiChillyTaco David aka Chilly aka Booty Freak
    David
    Goose Creek - South Carolina
    2021 Cement Grey TRD Off-road 4x4 Longbed
    Rough Country 3.5 Lift SCS BR6 wheels rolling in 285/70/17 Falken Wildpeaks
    I'm not a fan of phones in front of vents. Cold air can cause your smart phone to get water damaged
    from condensation. And can over heat in the winter when blowing hot air.
  13. Dec 6, 2020 at 8:46 AM
    TACOMA2NDGEN
    TACOMA2NDGEN Well-Known Member
    ROLAND
    new jersey
    2010 dcsb silver sport trd
    baja squadron pros
    I have mine in the cubby. I also have apple CarPlay so it doesn’t need to be in front of me5CBB4CD5-4211-47E6-9DCA-BF9541BB5F9B.jpg
  14. Dec 6, 2020 at 8:54 AM
    dbbd1
    dbbd1 Well-Known Member
    Not likely damaged from cold air. If you're thinking a/c, it's already dehumidified. And the cooler air will extend the life of your battery.
    Heat? Yes. Heat is bad for electronics.
  15. Dec 6, 2020 at 9:05 AM
    ryfox0276
    ryfox0276 Well-Known Member
    Montana
    2013 RC 4x4
  16. Dec 6, 2020 at 9:32 AM
    dbbd1
    I'm curious, do you have any pics or dimensions of the cd slot part?
  17. Dec 6, 2020 at 11:02 AM
    FlamingTacoBro
    FlamingTacoBro Taco Junkie
    So CA
    2012 TRD Sport 2wd DCSB Pyrite Mica
    my "new to me" 2012 TRD Sport has one of these and it is stuck on tight!....maybe the dude superglued it??.....any ideas how to remove it without damaging my dash???
  18. Dec 6, 2020 at 11:04 AM
    ryfox0276
    Montana
    2013 RC 4x4
    I'd start with mild heat. Hair dryer on low and wobble/ pry it off. Mine have fallen off on 100+ degree days and hotter than hell in the cab.
  19. Dec 6, 2020 at 11:14 AM
    FlamingTacoBro
    So CA
    thanks for the tip and I'll try that!.....the interior is in great shape and I just don't want to mess up the dash doing something stupid!......I just keep my phone in the long "cubby" next to the shifter....it has an otterbox case so the mount won't work anyway.....
